Hey guys,
so yesterday I’ve installed OpenHAB 2 on my disk station, from Synology, together with Java. I already syccesfully connected my TV with the OpenHAB via my laptop. However, I want to connect the openHAB app on ios to it. I need to create an account on openHAB for that. Therefore I need an UUID and Secret. I already finded the UUID in: REST API → uuid
but where is the Secret??
It hasn’t got anything to do with the binding. I need to login with my openHAB account on the official OpenHAB-app but to make a openHAB account I need to fill in an UUID and Secret… See this image:
Which system do you mean? The openHAB system or the Synology system? Because I’ve read almost every piece of info about it but the problem where I get stuck is to look up these paths…
Ehhh @Bruce_Osborne I can understand a non dev getting confused about that part.
The doc for cloud only documents the “Regular Installation” and “APT Installation”, but since Synology is neither of those I can understand getting lost in that process.
Know your tools and know your setup
is something we devs do but a normal user reads the doc for this specific binding/issue and does not see the connection between his “custom” Synology (which is not really custom) since for a normal user it’s a 1’click install.
I hope @Jim_Verspuij will find the files and share the paths for Synology so I can create a PR for the doc.
I entered the last 2 lines, it loads for like 5 seconds and then nothing happens…
when i enter the first line of code, it tells me there is no such file or directory
