I migrated from v5.1.0.M2 to 5.1.1 - Release Build. I am running OH as docker on my NAS with x86_64 CPUs and I lost the connection to an MQTT Device that Ihave added in 5.1.0.M2 via the MQTT Binding => “Home Assistant Discovery” feature. I found that the Home Assistant Discovery has been moved from the MQTT binding to a separate binding. I installed this binding but all three things that were prviously connected via the MQTT binding are now in the state “error:handler”. After the did not revive with installing the new Home Assistant Binding I disabled and tried to remove them but they are staying in the things list as orphans (I have additionally other orphan thing entries from my old gas heating where I deleted the things and items files months ago but they are still hanging around in the things view.)
But coming back to my problem to recover the three MQTT devices that have been working before the upgrade.
I would kindly appreciate any hint how to clean up and rediscover the things. I tried to rediscover by clicking (+) in the Inbox and chossing the Home Assistant Bindings selecting my MQTT broker. It does not discover anything I could only “add manually” which I refuse for 266 channels across three things …
EDIT:
I found in the karaf.log that the discovery in the Home Assistant binding does not seem to work correctly:
19:32:27.361 [ERROR] [nt.internal.HomeAssistantPythonBridge] - bundle org.openhab.binding.homeassistant:5.1.1 (350)[org.openhab.binding.homeassistant.internal.HomeAssistantPythonBridge(452)] : Error during instantiation of the implementation object
java.lang.reflect.InvocationTargetException: null
at jdk.internal.reflect.DirectConstructorHandleAccessor.newInstance(DirectConstructorHandleAccessor.java:74) ~[?:?]
at java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:502) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:486) ~[?:?]
at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:326) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:286) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1002) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:975) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:920) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:220) ~[org.eclipse.osgi-3.18.0.jar:?]
at java.security.AccessController.doPrivileged(AccessController.java:319) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:217) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:118) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:48) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:547) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:534) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:660) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:88) ~[?:?]
at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:287) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:675) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2612) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:2078) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:2061) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:443) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:336) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:304) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1232) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1152) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:959) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:895) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1184) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:116) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:123) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:961) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:937) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:874) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:262) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:500) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:671) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:310) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:593) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:74) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:460) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) ~[osgi.core-8.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:949) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:486) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:464) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.startBundle(BundleInstallSupportImpl.java:165) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1160) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:1041) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:317) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642) ~[?:?]
at java.lang.Thread.run(Thread.java:1583) [?:?]
Caused by: java.lang.IllegalArgumentException: Could not find option with name python.Executable.
at com.oracle.truffle.polyglot.PolyglotEngineException.illegalArgument(PolyglotEngineException.java:129) ~[?:?]
at com.oracle.truffle.polyglot.OptionValuesImpl.failNotFound(OptionValuesImpl.java:331) ~[?:?]
at com.oracle.truffle.polyglot.PolyglotEngineImpl.parseOptions(PolyglotEngineImpl.java:873) ~[?:?]
at com.oracle.truffle.polyglot.PolyglotEngineImpl.<init>(PolyglotEngineImpl.java:356) ~[?:?]
at com.oracle.truffle.polyglot.PolyglotImpl.buildEngine(PolyglotImpl.java:357) ~[?:?]
at org.graalvm.polyglot.Engine$Builder.build(Engine.java:843) ~[?:?]
at org.graalvm.polyglot.Context$Builder.build(Context.java:2136) ~[?:?]
at org.openhab.binding.homeassistant.internal.HomeAssistantPythonBridge.<init>(HomeAssistantPythonBridge.java:62) ~[?:?]
at jdk.internal.reflect.DirectConstructorHandleAccessor.newInstance(DirectConstructorHandleAccessor.java:62) ~[?:?]
... 93 more
19:32:27.403 [WARN ] [rnal.discovery.HomeAssistantDiscovery] - bundle org.openhab.binding.homeassistant:5.1.1 (350)[org.openhab.binding.homeassistant.internal.discovery.HomeAssistantDiscovery(455)] : Could not get service from ref {org.openhab.binding.homeassistant.internal.HomeAssistantPythonBridge}={service.id=844, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.homeassistant.internal.HomeAssistantPythonBridge, component.id=452}
19:32:27.404 [ERROR] [rnal.discovery.HomeAssistantDiscovery] - bundle org.openhab.binding.homeassistant:5.1.1 (350)[org.openhab.binding.homeassistant.internal.discovery.HomeAssistantDiscovery(455)] : Error during instantiation of the implementation object: Unable to get service for reference $001
19:32:27.406 [WARN ] [internal.DiscoveryServiceRegistryImpl] - bundle org.openhab.core.config.discovery:5.1.1 (170)[org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl(146)] : Could not get service from ref {org.openhab.core.config.discovery.DiscoveryService}={service.id=847, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), service.config.label=Home Assistant Binding, component.name=org.openhab.binding.homeassistant.internal.discovery.HomeAssistantDiscovery, component.id=455, service.config.factory=false, service.config.category=binding, service.pid=org.openhab.binding.homeassistant, service.config.description.uri=binding:homeassistant}
19:32:27.406 [WARN ] [internal.DiscoveryServiceRegistryImpl] - bundle org.openhab.core.config.discovery:5.1.1 (170)[org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl(146)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.config.discovery.DiscoveryService}={service.id=847, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), service.config.label=Home Assistant Binding, component.name=org.openhab.binding.homeassistant.internal.discovery.HomeAssistantDiscovery, component.id=455, service.config.factory=false, service.config.category=binding, service.pid=org.openhab.binding.homeassistant, service.config.description.uri=binding:homeassistant} for reference DiscoveryService
19:32:27.467 [ERROR] [nt.internal.HomeAssistantPythonBridge] - bundle org.openhab.binding.homeassistant:5.1.1 (350)[org.openhab.binding.homeassistant.internal.HomeAssistantPythonBridge(452)] : Error during instantiation of the implementation object
... 93 more
19:32:27.482 [WARN ] [dler.HomeAssistantThingHandlerFactory] - bundle org.openhab.binding.homeassistant:5.1.1 (350)[org.openhab.binding.homeassistant.internal.handler.HomeAssistantThingHandlerFactory(456)] : Could not get service from ref {org.openhab.binding.homeassistant.internal.HomeAssistantPythonBridge}={service.id=844, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.homeassistant.internal.HomeAssistantPythonBridge, component.id=452}
19:32:27.483 [ERROR] [dler.HomeAssistantThingHandlerFactory] - bundle org.openhab.binding.homeassistant:5.1.1 (350)[org.openhab.binding.homeassistant.internal.handler.HomeAssistantThingHandlerFactory(456)] : Error during instantiation of the implementation object: Unable to get service for reference $004
19:32:27.484 [WARN ] [ig.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:5.1.1 (170)[org.openhab.core.config.discovery.internal.PersistentInbox(147)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=848, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.homeassistant.internal.handler.HomeAssistantThingHandlerFactory, component.id=456}
19:32:27.485 [WARN ] [ig.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:5.1.1 (170)[org.openhab.core.config.discovery.internal.PersistentInbox(147)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=848, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.homeassistant.internal.handler.HomeAssistantThingHandlerFactory, component.id=456} for reference ThingHandlerFactory
19:32:27.487 [WARN ] [l.thing.internal.GenericThingProvider] - bundle org.openhab.core.model.thing:5.1.1 (216)[org.openhab.core.model.thing.internal.GenericThingProvider(260)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=848, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.homeassistant.internal.handler.HomeAssistantThingHandlerFactory, component.id=456}
19:32:27.487 [WARN ] [l.thing.internal.GenericThingProvider] - bundle org.openhab.core.model.thing:5.1.1 (216)[org.openhab.core.model.thing.internal.GenericThingProvider(260)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=848, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.homeassistant.internal.handler.HomeAssistantThingHandlerFactory, component.id=456} for reference ThingHandlerFactory
19:32:27.488 [WARN ] [aml.internal.things.YamlThingProvider] - bundle org.openhab.core.model.yaml:5.1.1 (219)[org.openhab.core.model.yaml.internal.things.YamlThingProvider(269)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=848, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.homeassistant.internal.handler.HomeAssistantThingHandlerFactory, component.id=456}
19:32:27.489 [WARN ] [aml.internal.things.YamlThingProvider] - bundle org.openhab.core.model.yaml:5.1.1 (219)[org.openhab.core.model.yaml.internal.things.YamlThingProvider(269)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=848, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.homeassistant.internal.handler.HomeAssistantThingHandlerFactory, component.id=456} for reference ThingHandlerFactory
19:32:27.490 [WARN ] [.core.thing.internal.ThingManagerImpl] - bundle org.openhab.core.thing:5.1.1 (223)[org.openhab.core.thing.internal.ThingManagerImpl(303)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=848, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.homeassistant.internal.handler.HomeAssistantThingHandlerFactory, component.id=456}
19:32:27.490 [WARN ] [.core.thing.internal.ThingManagerImpl] - bundle org.openhab.core.thing:5.1.1 (223)[org.openhab.core.thing.internal.ThingManagerImpl(303)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=848, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.homeassistant.internal.handler.HomeAssistantThingHandlerFactory, component.id=456} for reference ThingHandlerFactory
19:32:27.491 [WARN ] [core.thing.internal.ThingRegistryImpl] - bundle org.openhab.core.thing:5.1.1 (223)[org.openhab.core.thing.internal.ThingRegistryImpl(304)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=848, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.homeassistant.internal.handler.HomeAssistantThingHandlerFactory, component.id=456}
19:32:27.492 [WARN ] [core.thing.internal.ThingRegistryImpl] - bundle org.openhab.core.thing:5.1.1 (223)[org.openhab.core.thing.internal.ThingRegistryImpl(304)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=848, service.bundleid=350, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.homeassistant.internal.handler.HomeAssistantThingHandlerFactory, component.id=456} for reference ThingHandlerFactory
Please help ![]()
