Platform Pi
- Linux 14.71-v7+ #1145 SMP armv7l GNU/Linux
- Java: openjdk version “1.8.0_152”
- OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76)
- OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 25.152-b76, mixed mode, Evaluation)
- Openhab v 2.4.0-1
Issue
I am attempting to integrate a lutron pico into OH2 via the lutron bridge. The bridge is otherwise working fine (I have controlled various devices from OH2 to the bridge). This is the first time I am going the other way, having a switch inside the lutron bridge attempt to communicate with OH2
I have the pico switch configured according to the docs here (note the last line defines the pico switch in question “nook”.
Thing lutron:ipbridge:radiora2 [ ipAddress="X.X.X.X", user="X", password="X" ]
Thing lutron:switch:lobby "Lobby" (lutron:ipbridge:radiora2) @ "Lobby" [ integrationId=7 ]
Thing lutron:switch:kitchen "Kitchen" (lutron:ipbridge:radiora2) @ "Kitchen" [ integrationId=6 ]
Thing lutron:pico:nook (lutron:ipbridge:radiora2) [ integrationId=11, model="4B",autorelease="true" ]
The OH2 instance does sort of acknowledge the pico switch, but with some caveats / errors within PaperUI. It is uninitialized and there is a java cast error which is not super instructive, string that should be a bool.. hmm.
The log event entries tell a similar story of failed initialization
2019-03-10 15:33:31.474 [hingStatusInfoChangedEvent] - 'lutron:pico:nook' changed from UNINITIALIZED (HANDLER_INITIALIZING_ERROR): java.lang.String cannot be cast to java.lang.Boolean to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-03-10 15:33:31.482 [hingStatusInfoChangedEvent] - 'lutron:pico:nook' changed from UNINITIALIZED (HANDLER_INITIALIZING_ERROR): java.lang.String cannot be cast to java.lang.Boolean to INITIALIZING
2019-03-10 15:33:31.497 [hingStatusInfoChangedEvent] - 'lutron:pico:nook' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): java.lang.String cannot be cast to java.lang.Boolean
Status: UNINITIALIZED - HANDLER_INITIALIZING_ERROR java.lang.String cannot be cast to java.lang.Boolean
The only other odd thing is that in the properties in the paper UI, the pico model field is empty (even though I specified it in the thing file) and you can’t edit it (409 ERROR conflict) if you try to manually edit it. I am pretty sure 4B is a valid config value in the docs.
When I press a button on the pico, it does send an event to OH2, but the log entry suggests that OH2 can’t handle it. This is from the openhab logs as I press the button. It refers to component 2. Not sure where the 2 is coming from, the pico is integrationId 11 according to my dump of the system.
2019-03-10 16:06:59.946 [WARN ] [n.internal.handler.BaseKeypadHandler] - Unable to determine channel for component 2 in keypad update event message
Any thoughts appreciated. I will continue to randomly mutate things in the interim to see if I can get success. I will say the lutron docs are good as far as they go, but plenty of guessing involved. It took me a lot of trial and error for example to work out how to include location in the Thing configuration and it didn’t match any of the examples ( you have to split the “name” @ “location” string with the bridge name in the middle
Addendum
I decided to tidy up the pico entry and add a location to the thing definition, specifically
Thing lutron:pico:nook (lutron:ipbridge:radiora2) @ "Nook" [ integrationId=11, model="4B",autorelease="true" ]
and this delivered this beautiful traceback in the openhab logs which might be helpful in pinpointing where the type cast error is happening. Going to peek at the source myself now.
2019-03-10 16:13:10.932 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.lutron.internal.handler.PicoKeypadHandler@5297ee': java.lang.String cannot be cast to java.lang.Boolean
java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Boolean
at org.openhab.binding.lutron.internal.handler.BaseKeypadHandler.initialize(BaseKeypadHandler.java:173) ~[?:?]
at sun.reflect.GeneratedMethodAccessor121.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
2019-03-10 16:13:10.945 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'lutron:pico:nook': java.lang.String cannot be cast to java.lang.Boolean
