I have a physical light switch and a virtual switch for a light bulb. They are connected to the output using XOR argument (Logo soft comfort configuration for LOGO 8 plc) - so the light bulb only works when there are one signal present, if both are present light bulb is in OFF state.
.sitemap
Switch item=VirtualSwitch
Switch item=LightBulb
The problem is that my switch in sitemap shows the state of the virtual switch and sometimes if I have signal from physical and virtual switches together light bulb is off but the switch in the sitemap shows that it is on.
I want the virtual switch toggle icon to be dependant from lightbulb state, but the value of the virtual switch independent of it.
So if I have physical light bulb in ON state I would have virtual switch icon in ON state independent of virtual switch value. And if I toggle it, I want it to change virtual switch value.
I did one tricky solution using rules and visibility tags:
.sitemap
Switch item=VirtualSwitch icon="switch-on" mappings=[OFF="TURN ON"] visibility=[DATAITEM==ON]
Switch item=VirtualSwitch icon="switch-off" mappings=[ON="TURN ON"] visibility=[DATAITEM1==ON]
Switch item=VirtualSwitch icon="switch-on" mappings=[ON="TURN OFF"] visibility=[DATAITEM2==ON]
Switch item=VirtualSwitch icon="switch-off" mappings=[OFF="TURN OFF"] visibility=[DATAITEM3==ON]
.rules
rule "light change"
Item LightBulb received update
DATAITEM.sendCommand(OFF)
DATAITEM1.sendCommand(OFF)
DATAITEM2.sendCommand(OFF)
DATAITEM3.sendCommand(OFF)
if (LightBulb.state==OFF && VirtualSwitch.state==ON){
DATAITEM.sendCommand(ON)
else if (LightBulb.state==OFF && VirtualSwitch.state==OFF){
DATAITEM1.sendCommand(ON)
else if (LightBulb.state==ON && VirtualSwitch.state==OFF){
DATAITEM2.sendCommand(ON)
else if (LightBulb.state==ON && VirtualSwitch.state==ON){
DATAITEM3.sendCommand(ON)
Which does the trick, but I thought it is not the best solution. And my icon tag did not work as expected, the icon did not changed accordingly. I tried another approach bu using postUpdate:
.sitemap
.rules
rule "Postupdate TEST"
if (LightBulb.state==OFF){
VirtualSwitch.postUpdate(OFF)
else{
VirtualSwitch.postUpdate(ON)
BUT the problem is that when using the switch I have to press it twice to change the real state, although the switch shows correct position.
Is there any workaround to make it lightweight and working? Thank you!
