[SOLVED] Mapdb not reinstating item properly
I am currently using openhab2 on RPi3.
I have installed mapdb persistence and looking to restore my last value form DB. I have succesfully restored values for relay, dc motor etc that means my MapDB setup is working fine.
I am trying to control a Stepper motor now. And below i have given my configuration files for the same.
Here goes my demo.items file:
String EPBM4 "EPBM4 [%s]" { serial="/dev/ttyUSB0" }
Switch st_start "Start/Stop" <garagedoor>
Switch st_clk "Clockwise/Anti-Clockwise"
Number st_steps "Steps in Degree [%d deg]"
Here goes my Demo.rules file:
var String st_clkFlag
var Number st_stepsFlag
rule "ST_Step"
  Item st_steps received command
  var Number st_percent = st_steps.state as DecimalType
 st_stepsFlag = st_percent
   postUpdate(st_steps, st_stepsFlag)
rule "ST_Clk"
 Item st_clk changed
  var state = st_clk.state as OnOffType
  if(state == ON){
  	st_clkFlag = 'C';
  if(state == OFF){
  	st_clkFlag = 'A';
rule "ST_Start"
 Item st_start changed
 var state = st_start.state as OnOffType
 if(state == ON){
 	sendCommand (EPBM4 , "S" + "ON" + st_clkFlag + st_stepsFlag + "\r")
 if(state == OFF){
 	sendCommand (EPBM4 , "SOFF" + "\r")
Here is my sitemap:
sitemap demo label="Main Menu"
Frame label="EPBM4 Serial" icon="socket" {
				Text item=EPBM4
				Switch item=st_start
				Switch item=st_clk
				Setpoint item=st_steps minValue=0 maxValue=100 step=5
My mapDB config file are given below for reference:
mapdb.persist
Strategies {
default = everyUpdate
Items {
*: strategy = everyChange, restoreOnStartup
mapdb.cfg (haavent made any change)
     # the commit interval in seconds (optional, default to '5')
    #commitinterval=5
# issue a commit even if the state did not change (optional, defaults to 'false')
#commitsamestate=false
Error:
*My item “EPBM4” is stored correctly in Database,
   {"name":"EPBM4","datapoints":"1","data":[{"time":1543564644523,"state":"SONC100\r"}]}
But when i restart openhab, the item values get updated succesfully but Motor dont rotates as the EPBM4 is getting Null value in string.
Here is event.log file for better understanding:
13:29:33.662 [DEBUG] [org.openhab.persistence.mapdb ] - ServiceEvent REGISTERED - {org.openhab.core.persistence.PersistenceService}={service.id=379, service.bundleid=242, service.scope=bundle, component.name=org.openhab.persistence.mapdb, component.id=248} - org.openhab.persistence.mapdb
13:29:33.696 [INFO ] [smarthome.event.ItemStateChangedEvent] - EPBM4 changed from NULL to SONC100
13:29:33.701 [INFO ] [smarthome.event.ItemStateChangedEvent] - st_start changed from NULL to ON
13:29:33.706 [INFO ] [smarthome.event.ItemStateChangedEvent] - st_clk changed from NULL to ON
13:29:33.711 [INFO ] [smarthome.event.ItemStateChangedEvent] - st_steps changed from NULL to 100
13:29:33.730 [DEBUG] [org.openhab.persistence.mapdb ] - BundleEvent STARTED - org.openhab.persistence.mapdb
13:29:35.908 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘EPBM4’ received command SONCnull
13:29:35.926 [DEBUG] [apdb.internal.MapDBPersistenceService] - store called for EPBM4
13:29:35.942 [INFO ] [smarthome.event.ItemStateChangedEvent] - EPBM4 changed f to SONCnull
Can anyone help me, why this null value is arising as last value stored in DB was correct.
it’s not null … it’s SONCnull
since you are composing this from:
check why the value of your var Number st_stepsFlag is null
It may be due to the following situation:
  1. Map restores the state of EPBM4 to SONC100\r but then the rule fires and updates it with SONCnull
    or
  2. Map has stored SONCnull as the last value
Map stores the values correctly. Might be problem with rule.
Okay my issue was with the above rule.
Here is the code thats working,
 rule "ST_Step"
    Item st_steps changed
Thankyou :slight_smile:
