Hello, i am having big problems using openhabian on my raspi2.
Everything worked fine the last 50 days (or more … i dont know), roller shutters worked, rr4d sitemap was fine, till today. Now everything is going crazy and it gets crazier more and more.
Now looking in syslog, i am expecting till syslog.7 this message, every minute:
Mar 7 06:22:29 openHABianPi karaf[829]: Exception in thread “pool-7885-thread-1” java.lang.NoClassDefFoundError: Could not initialize class org.apache.karaf.features.internal.model.JaxbUtil
Mar 7 06:22:29 openHABianPi rsyslogd-2007: action ‘action 17’ suspended, next retry is Wed Mar 7 06:23:59 2018 [try http://www.rsyslog.com/e/2007 ]
Mar 7 06:22:29 openHABianPi karaf[829]: at org.apache.karaf.features.internal.service.RepositoryImpl.load(RepositoryImpl.java:88)
Mar 7 06:22:29 openHABianPi karaf[829]: at org.apache.karaf.features.internal.service.RepositoryImpl.load(RepositoryImpl.java:80)
Mar 7 06:22:29 openHABianPi karaf[829]: at org.apache.karaf.features.internal.service.FeaturesServiceImpl.getFeatures(FeaturesServiceImpl.java:780)
Mar 7 06:22:29 openHABianPi karaf[829]: at org.apache.karaf.features.internal.service.FeaturesServiceImpl.getRepository(FeaturesServiceImpl.java:649)
Mar 7 06:22:29 openHABianPi karaf[829]: at org.apache.karaf.features.internal.service.FeaturesServiceImpl.removeRepository(FeaturesServiceImpl.java:525)
Mar 7 06:22:29 openHABianPi karaf[829]: at org.apache.karaf.features.internal.service.FeaturesServiceImpl.removeRepository(FeaturesServiceImpl.java:520)
Mar 7 06:22:29 openHABianPi karaf[829]: at org.openhab.core.karaf.internal.FeatureInstaller.setLegacyExtensions(FeatureInstaller.java:282)
Mar 7 06:22:29 openHABianPi karaf[829]: at org.openhab.core.karaf.internal.FeatureInstaller.lambda$1(FeatureInstaller.java:162)
Mar 7 06:22:29 openHABianPi karaf[829]: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
Mar 7 06:22:29 openHABianPi karaf[829]: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
Mar 7 06:22:29 openHABianPi karaf[829]: at java.lang.Thread.run(Thread.java:748)
now, today at 1PM my openahb app could not connect, so i restarted my raspi.
After that i got following messages in syslog:
Mar 13 13:17:03 openHABianPi raspi-config[243]: Checking if shift key is held down:Error opening ‘/dev/input/event*’: No such file or directory
Mar 13 13:17:03 openHABianPi kernel: [ 0.884380] vc_vchi_sm_init: failed to open VCHI service (-1)
Mar 13 13:17:03 openHABianPi kernel: [ 0.884501] [vc_sm_connected_init]: failed to initialize shared memory service
Mar 13 13:17:04 openHABianPi triggerhappy[420]: Error opening ‘/dev/input/event*’: No such file or directory
Mar 13 13:17:28 openHABianPi karaf[782]: /usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/rt.jar: invalid LOC header (bad signature)
Mar 13 13:17:28 openHABianPi /etc/mysql/debian-start[1591]: /usr/bin/mysql_upgrade: the ‘–basedir’ option is always ignored
Mar 13 13:17:28 openHABianPi /etc/mysql/debian-start[1591]: Looking for ‘mysql’ as: /usr/bin/mysql
Mar 13 13:17:28 openHABianPi /etc/mysql/debian-start[1591]: Looking for ‘mysqlcheck’ as: /usr/bin/mysqlcheck
Mar 13 13:17:28 openHABianPi /etc/mysql/debian-start[1591]: This installation of MySQL is already upgraded to 5.5.57, use --force if you still need to run mysql_upgrade
Mar 13 13:17:28 openHABianPi karaf[782]: Error: Could not find or load main class org.apache.karaf.main.Main
Mar 13 13:17:28 openHABianPi /etc/mysql/debian-start[1615]: Checking for insecure root accounts.
Mar 13 13:17:28 openHABianPi systemd[1]: openhab2.service: main process exited, code=exited, status=1/FAILURE
Mar 13 13:17:28 openHABianPi /etc/mysql/debian-start[1632]: Triggering myisam-recover for all MyISAM tables
Mar 13 13:17:30 openHABianPi smbd[1596]: Starting SMB/CIFS daemon: smbd.
Mar 13 13:17:30 openHABianPi systemd[1]: Started LSB: start Samba SMB/CIFS daemon (smbd).
Mar 13 13:17:30 openHABianPi systemd[1]: Starting Multi-User System.
Mar 13 13:17:30 openHABianPi systemd[1]: Reached target Multi-User System.
Mar 13 13:17:30 openHABianPi systemd[1]: Starting Graphical Interface.
Mar 13 13:17:30 openHABianPi systemd[1]: Reached target Graphical Interface.
Mar 13 13:17:30 openHABianPi systemd[1]: Starting Update UTMP about System Runlevel Changes…
Mar 13 13:17:30 openHABianPi systemd[1]: Started Update UTMP about System Runlevel Changes.
Mar 13 13:17:30 openHABianPi systemd[1]: Startup finished in 13.666s (kernel) + 30.200s (userspace) = 43.866s.
Mar 13 13:17:33 openHABianPi karaf[1619]: /usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/rt.jar: invalid LOC header (bad signature)
Mar 13 13:17:33 openHABianPi karaf[1619]: Error: Could not find or load main class org.apache.karaf.main.Stop
Mar 13 13:17:33 openHABianPi systemd[1]: openhab2.service: control process exited, code=exited status=1
Mar 13 13:17:33 openHABianPi systemd[1]: Unit openhab2.service entered failed state.
Mar 13 13:17:38 openHABianPi systemd[1]: openhab2.service holdoff time over, scheduling restart.
Mar 13 13:17:38 openHABianPi systemd[1]: Stopping openHAB 2 - empowering the smart home…
Mar 13 13:17:38 openHABianPi systemd[1]: Starting openHAB 2 - empowering the smart home…
Mar 13 13:17:38 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
Mar 13 13:17:42 openHABianPi karaf[1886]: /usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/rt.jar: invalid LOC header (bad signature)
Mar 13 13:17:42 openHABianPi karaf[1886]: Error: Could not find or load main class org.apache.karaf.main.Main
Mar 13 13:17:42 openHABianPi systemd[1]: openhab2.service: main process exited, code=exited, status=1/FAILURE
Mar 13 13:17:45 openHABianPi karaf[2032]: /usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/rt.jar: invalid LOC header (bad signature)
Mar 13 13:17:45 openHABianPi karaf[2032]: Error: Could not find or load main class org.apache.karaf.main.Stop
Mar 13 13:17:45 openHABianPi systemd[1]: openhab2.service: control process exited, code=exited status=1
Mar 13 13:17:45 openHABianPi systemd[1]: Unit openhab2.service entered failed state.
Mar 13 13:17:50 openHABianPi systemd[1]: openhab2.service holdoff time over, scheduling restart.
Mar 13 13:17:50 openHABianPi systemd[1]: Stopping openHAB 2 - empowering the smart home…
Mar 13 13:17:50 openHABianPi systemd[1]: Starting openHAB 2 - empowering the smart home…
Mar 13 13:17:50 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
Mar 13 13:17:53 openHABianPi karaf[2210]: /usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/rt.jar: invalid LOC header (bad signature)
Mar 13 13:17:53 openHABianPi karaf[2210]: Error: Could not find or load main class org.apache.karaf.main.Main
Mar 13 13:17:53 openHABianPi systemd[1]: openhab2.service: main process exited, code=exited, status=1/FAILURE
Now watch this, a journey through time ?:
Mar 13 13:29:03 openHABianPi systemd[1]: openhab2.service: main process exited, code=exited, status=1/FAILURE
Mar 13 13:29:06 openHABianPi karaf[17097]: /usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/rt.jar: invalid LOC header (bad signature)
Mar 13 13:29:06 openHABianPi karaf[17097]: Error: Could not find or load main class org.apache.karaf.main.Stop
Mar 13 13:29:06 openHABianPi systemd[1]: openhab2.service: control process exited, code=exited status=1
Mar 13 13:29:06 openHABianPi systemd[1]: Unit openhab2.service entered failed state.
Mar 13 13:29:11 openHABianPi systemd[1]: openhab2.service holdoff time over, scheduling restart.
Mar 13 13:29:11 openHABianPi systemd[1]: Stopping openHAB 2 - empowering the smart home…
Mar 13 13:29:11 openHABianPi systemd[1]: Starting openHAB 2 - empowering the smart home…
Mar 13 13:29:11 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
Mar 13 13:29:16 openHABianPi karaf[17227]: /usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/rt.jar: invalid LOC header (bad signature)
Mar 13 13:29:16 openHABianPi karaf[17227]: Error: Could not find or load main class org.apache.karaf.main.Main
Mar 13 13:29:16 openHABianPi systemd[1]: openhab2.service: main process exited, code=exited, status=1/FAILURE
Mar 13 13:29:19 openHABianPi karaf[17356]: /usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/rt.jar: invalid LOC header (bad signature)
Mar 13 13:29:19 openHABianPi karaf[17356]: Error: Could not find or load main class org.apache.karaf.main.Stop
Mar 13 13:29:19 openHABianPi systemd[1]: openhab2.service: control process exited, code=exited status=1
Mar 13 13:29:19 openHABianPi systemd[1]: Unit openhab2.service entered failed state.
Mar 13 13:29:24 openHABianPi systemd[1]: openhab2.service holdoff time over, scheduling restart.
Mar 13 13:29:24 openHABianPi systemd[1]: Stopping openHAB 2 - empowering the smart home…
Mar 13 13:29:24 openHABianPi systemd[1]: Starting openHAB 2 - empowering the smart home…
Mar 13 13:29:24 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
Mar 13 13:29:27 openHABianPi karaf[17492]: /usr/lib/jvm/zulu-embedded-8-armhf/jre/lib/rt.jar: invalid LOC header (bad signature)
Mar 13 13:29:27 openHABianPi karaf[17492]: Error: Could not find or load main class org.apache.karaf.main.Main
Mar 13 13:29:27 openHABianPi systemd[1]: openhab2.service: main process exited, code=exited, status=1/FAILURE
Mar 13 13:17:03 openHABianPi rsyslogd: [origin software=“rsyslogd” swVersion=“8.4.2” x-pid=“385” x-info=“http://www.rsyslog.com”] start
Mar 13 13:17:03 openHABianPi systemd[1]: Starting Create Static Device Nodes in /dev…
Mar 13 13:17:03 openHABianPi systemd[1]: Mounted Configuration File System.
Mar 13 13:17:03 openHABianPi systemd[1]: Started Apply Kernel Variables.
Mar 13 13:17:03 openHABianPi systemd[1]: Started Create Static Device Nodes in /dev.
Mar 13 13:17:03 openHABianPi systemd[1]: Starting udev Kernel Device Manager…
Mar 13 13:17:03 openHABianPi systemd[1]: Started udev Kernel Device Manager.
Mar 13 13:17:03 openHABianPi systemd[1]: Starting Copy rules generated while the root was ro…
Mar 13 13:17:03 openHABianPi systemd[1]: Starting LSB: Set preliminary keymap…
Now we have a time jump, ok lets see whats coming now:
Mar 13 13:17:20 openHABianPi systemd[1]: Started LSB: start Samba NetBIOS nameserver (nmbd).
Mar 13 13:17:20 openHABianPi systemd[1]: Starting LSB: start Samba SMB/CIFS daemon (smbd)…
Mar 13 13:17:20 openHABianPi /etc/mysql/debian-start[1484]: /usr/bin/mysql_upgrade: the ‘–basedir’ option is always ignored
Mar 13 13:17:20 openHABianPi /etc/mysql/debian-start[1484]: Looking for ‘mysql’ as: /usr/bin/mysql
Mar 13 13:17:20 openHABianPi /etc/mysql/debian-start[1484]: Looking for ‘mysqlcheck’ as: /usr/bin/mysqlcheck
Mar 13 13:17:20 openHABianPi /etc/mysql/debian-start[1484]: This installation of MySQL is already upgraded to 5.5.57, use --force if you still need to run mysql_upgrade
Mar 13 13:17:20 openHABianPi /etc/mysql/debian-start[1515]: Checking for insecure root accounts.
Mar 13 13:17:20 openHABianPi /etc/mysql/debian-start[1520]: Triggering myisam-recover for all MyISAM tables
Mar 13 13:17:21 openHABianPi karaf[760]: Error: A JNI error has occurred, please check your installation and try again
Mar 13 13:17:21 openHABianPi karaf[760]: Exception in thread “main” java.lang.ClassFormatError: Unknown constant tag 0 in class file java/util/Properties$LineReader
Mar 13 13:17:21 openHABianPi karaf[760]: at java.util.Properties.load(Properties.java:341)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.security.Security.initialize(Security.java:90)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.security.Security.access$000(Security.java:49)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.security.Security$1.run(Security.java:71)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.security.Security$1.run(Security.java:69)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.security.AccessController.doPrivileged(Native Method)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.security.Security.(Security.java:69)
Mar 13 13:17:21 openHABianPi karaf[760]: at sun.security.util.AbstractAlgorithmConstraints$1.run(AbstractAlgorithmConstraints.java:52)
Mar 13 13:17:21 openHABianPi karaf[760]: at sun.security.util.AbstractAlgorithmConstraints$1.run(AbstractAlgorithmConstraints.java:49)
Mar 13 13:17:21 openHABianPi karaf[760]: at sun.security.util.AbstractAlgorithmConstraints.getAlgorithms(AbstractAlgorithmConstraints.java:48)
Mar 13 13:17:21 openHABianPi karaf[760]: at sun.security.util.DisabledAlgorithmConstraints.(DisabledAlgorithmConstraints.java:98)
Mar 13 13:17:21 openHABianPi karaf[760]: at sun.security.util.DisabledAlgorithmConstraints.(DisabledAlgorithmConstraints.java:84)
Mar 13 13:17:21 openHABianPi karaf[760]: at sun.security.util.SignatureFileVerifier.(SignatureFileVerifier.java:62)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.util.jar.JarFile.initializeVerifier(JarFile.java:370)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.util.jar.JarFile.getInputStream(JarFile.java:450)
Mar 13 13:17:21 openHABianPi karaf[760]: at sun.misc.URLClassPath$JarLoader$2.getInputStream(URLClassPath.java:977)
Mar 13 13:17:21 openHABianPi karaf[760]: at sun.misc.Resource.cachedInputStream(Resource.java:77)
Mar 13 13:17:21 openHABianPi karaf[760]: at sun.misc.Resource.getByteBuffer(Resource.java:160)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.net.URLClassLoader.defineClass(URLClassLoader.java:454)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
Mar 13 13:17:21 openHABianPi karaf[760]: at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:338)
Mar 13 13:17:21 openHABianPi karaf[760]: at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
Mar 13 13:17:21 openHABianPi karaf[760]: at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:495)
Mar 13 13:17:21 openHABianPi systemd[1]: openhab2.service: main process exited, code=exited, status=1/FAILURE
Mar 13 13:17:22 openHABianPi smbd[1497]: Starting SMB/CIFS daemon: smbd.
Mar 13 13:17:22 openHABianPi systemd[1]: Started LSB: start Samba SMB/CIFS daemon (smbd).
Mar 13 13:17:22 openHABianPi systemd[1]: Starting Multi-User System.
Mar 13 13:17:22 openHABianPi systemd[1]: Reached target Multi-User System.
Mar 13 13:17:22 openHABianPi systemd[1]: Starting Graphical Interface.
Mar 13 13:17:22 openHABianPi systemd[1]: Reached target Graphical Interface.
Mar 13 13:17:22 openHABianPi systemd[1]: Starting Update UTMP about System Runlevel Changes…
Mar 13 13:17:22 openHABianPi systemd[1]: Started Update UTMP about System Runlevel Changes.
Mar 13 13:17:22 openHABianPi systemd[1]: Startup finished in 15.008s (kernel) + 22.738s (userspace) = 37.746s.
Mar 13 13:17:26 openHABianPi karaf[1540]: Error: A JNI error has occurred, please check your installation and try again
Mar 13 13:17:26 openHABianPi karaf[1540]: Exception in thread “main” java.lang.ClassFormatError: Unknown constant tag 0 in class file java/util/Properties$LineReader
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.util.Properties.load(Properties.java:341)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.security.Security.initialize(Security.java:90)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.security.Security.access$000(Security.java:49)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.security.Security$1.run(Security.java:71)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.security.Security$1.run(Security.java:69)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.security.AccessController.doPrivileged(Native Method)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.security.Security.(Security.java:69)
Mar 13 13:17:26 openHABianPi karaf[1540]: at sun.security.util.AbstractAlgorithmConstraints$1.run(AbstractAlgorithmConstraints.java:52)
Mar 13 13:17:26 openHABianPi karaf[1540]: at sun.security.util.AbstractAlgorithmConstraints$1.run(AbstractAlgorithmConstraints.java:49)
Mar 13 13:17:26 openHABianPi karaf[1540]: at sun.security.util.AbstractAlgorithmConstraints.getAlgorithms(AbstractAlgorithmConstraints.java:48)
Mar 13 13:17:26 openHABianPi karaf[1540]: at sun.security.util.DisabledAlgorithmConstraints.(DisabledAlgorithmConstraints.java:98)
Mar 13 13:17:26 openHABianPi karaf[1540]: at sun.security.util.DisabledAlgorithmConstraints.(DisabledAlgorithmConstraints.java:84)
Mar 13 13:17:26 openHABianPi karaf[1540]: at sun.security.util.SignatureFileVerifier.(SignatureFileVerifier.java:62)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.util.jar.JarFile.initializeVerifier(JarFile.java:370)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.util.jar.JarFile.getInputStream(JarFile.java:450)
Mar 13 13:17:26 openHABianPi karaf[1540]: at sun.misc.URLClassPath$JarLoader$2.getInputStream(URLClassPath.java:977)
Mar 13 13:17:26 openHABianPi karaf[1540]: at sun.misc.Resource.cachedInputStream(Resource.java:77)
Mar 13 13:17:26 openHABianPi karaf[1540]: at sun.misc.Resource.getByteBuffer(Resource.java:160)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.net.URLClassLoader.defineClass(URLClassLoader.java:454)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
Mar 13 13:17:26 openHABianPi karaf[1540]: at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:338)
Mar 13 13:17:26 openHABianPi karaf[1540]: at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
Mar 13 13:17:26 openHABianPi karaf[1540]: at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:495)
Mar 13 13:17:26 openHABianPi systemd[1]: openhab2.service: control process exited, code=exited status=1
Mar 13 13:17:26 openHABianPi systemd[1]: Unit openhab2.service entered failed state.
Mar 13 13:17:31 openHABianPi systemd[1]: openhab2.service holdoff time over, scheduling restart.
Mar 13 13:17:31 openHABianPi systemd[1]: Stopping openHAB 2 - empowering the smart home…
Mar 13 13:17:31 openHABianPi systemd[1]: Starting openHAB 2 - empowering the smart home…
Mar 13 13:17:31 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
Mar 13 13:17:36 openHABianPi karaf[1798]: Error: A JNI error has occurred, please check your installation and try again
Next timejump:
Mar 13 13:20:05 openHABianPi karaf[4819]: at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
Mar 13 13:20:05 openHABianPi karaf[4819]: at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:495)
Mar 13 13:20:05 openHABianPi systemd[1]: openhab2.service: main process exited, code=exited, status=1/FAILURE
@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@Mar 13 13:17:03 openHABianPi rsyslogd: [origin software=“rsyslogd” swVersion=“8.4.2” x-pid=“382” x-info=“http://www.rsyslog.com”] start
Mar 13 13:17:25 openHABianPi karaf[740]: Error: A JNI error has occurred, please check your installation and try again
Mar 13 13:17:25 openHABianPi karaf[740]: Exception in thread “main” java.lang.ClassFormatError: Unknown constant tag 108 in class file java/util/Properties$LineReader
Mar 13 13:17:25 openHABianPi karaf[740]: at java.util.Properties.load(Properties.java:341)
Mar 13 13:17:25 openHABianPi karaf[740]: at java.security.Security.initialize(Security.java:90)
Mar 13 13:17:25 openHABianPi karaf[740]: at java.security.Security.access$000(Security.java:49)
Mar 13 13:17:26 openHABianPi karaf[740]: at java.security.Security$1.run(Security.java:71)
Mar 13 13:17:26 openHABianPi karaf[740]: at java.security.Security$1.run(Security.java:69)
Mar 13 13:17:26 openHABianPi karaf[740]: at java.security.AccessController.doPrivileged(Native Method)
Mar 13 13:17:26 openHABianPi karaf[740]: at java.security.Security.(Security.java:69)
Mar 13 13:17:26 openHABianPi karaf[740]: at sun.security.util.AbstractAlgorithmConstraints$1.run(AbstractAlgorithmConstraints.java:52)
Mar 13 13:17:26 openHABianPi karaf[740]: at sun.security.util.AbstractAlgorithmConstraints$1.run(AbstractAlgorithmConstraints.java:49)
Mar 13 13:17:26 openHABianPi karaf[740]: at sun.security.util.AbstractAlgorithmConstraints.getAlgorithms(AbstractAlgorithmConstraints.java:48)
Mar 13 13:17:26 openHABianPi karaf[740]: at sun.security.util.DisabledAlgorithmConstraints.(DisabledAlgorithmConstraints.java:98)
Mar 13 13:17:26 openHABianPi karaf[740]: at sun.security.util.DisabledAlgorithmConstraints.(DisabledAlgorithmConstraints.java:84)
Mar 13 13:17:26 openHABianPi karaf[740]: at sun.security.util.SignatureFileVerifier.(SignatureFileVerifier.java:62)
Mar 13 13:17:26 openHABianPi karaf[740]: at java.util.jar.JarFile.initializeVerifier(JarFile.java:370)
Mar 13 13:17:26 openHABianPi karaf[740]: at java.util.jar.JarFile.getInputStream(JarFile.java:450)
Mar 13 13:17:26 openHABianPi karaf[740]: at sun.misc.URLClassPath$JarLoader$2.getInputStream(URLClassPath.java:977)
Mar 13 13:17:26 openHABianPi karaf[740]: at sun.misc.Resource.cachedInputStream(Resource.java:77)
Mar 13 13:17:26 openHABianPi karaf[740]: at sun.misc.Resource.getByteBuffer(Resource.java:160)
Mar 13 13:17:26 openHABianPi karaf[740]: at java.net.URLClassLoader.defineClass(URLClassLoader.java:454)
Mar 13 13:17:26 openHABianPi karaf[740]: at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
Mar 13 13:17:26 openHABianPi karaf[740]: at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
Mar 13 13:17:26 openHABianPi karaf[740]: at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
Mar 13 13:17:26 openHABianPi karaf[740]: at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
Mar 13 13:17:26 openHABianPi karaf[740]: at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
Mar 13 13:17:26 openHABianPi karaf[740]: at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:338)
Mar 13 13:17:26 openHABianPi karaf[740]: at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
Mar 13 13:17:26 openHABianPi karaf[740]: at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:495)
Mar 13 13:17:26 openHABianPi systemd[1]: openhab2.service: main process exited, code=exited, status=1/FAILURE
Mar 13 13:17:26 openHABianPi smbd[1474]: Starting SMB/CIFS daemon: smbd.
Mar 13 13:17:26 openHABianPi systemd[1]: Started LSB: start Samba SMB/CIFS daemon (smbd).
Mar 13 13:17:26 openHABianPi systemd[1]: Starting Multi-User System.
Mar 13 13:17:26 openHABianPi systemd[1]: Reached target Multi-User System.
Mar 13 13:17:26 openHABianPi systemd[1]: Starting Graphical Interface.
Mar 13 13:17:26 openHABianPi systemd[1]: Reached target Graphical Interface.
Mar 13 13:17:26 openHABianPi systemd[1]: Starting Update UTMP about System Runlevel Changes…
Mar 13 13:17:26 openHABianPi systemd[1]: Started Update UTMP about System Runlevel Changes.
Mar 13 13:17:26 openHABianPi systemd[1]: Startup finished in 15.755s (kernel) + 26.786s (userspace) = 42.542s.
Mar 13 13:17:29 openHABianPi karaf[1529]: Error: A JNI error has occurred, please check your installation and try again
So the same error again:
Next timejump … this time with a new error:
Mar 13 13:36:30 openHABianPi systemd[1]: Unit openhab2.service entered failed state.
Mar 13 13:36:35 openHABianPi systemd[1]: openhab2.service holdoff time over, scheduling restart.
Mar 13 13:36:35 openHABianPi systemd[1]: Stopping openHAB 2 - empowering the smart home…
Mar 13 13:36:35 openHABianPi systemd[1]: Starting openHAB 2 - empowering the smart home…
Mar 13 13:36:35 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@Mar 13 13:17:03 openHABianPi rsyslogd: [origin software=“rsyslogd” swVersion=“8.4.2” x-pid=“383” x-info=“http://www.rsyslog.com”] start
Mar 13 15:17:40 openHABianPi smbd[1566]: Starting SMB/CIFS daemon: smbd.
Mar 13 15:17:40 openHABianPi systemd[1]: Started LSB: start Samba SMB/CIFS daemon (smbd).
Mar 13 15:17:40 openHABianPi systemd[1]: Starting Multi-User System.
Mar 13 15:17:40 openHABianPi systemd[1]: Reached target Multi-User System.
Mar 13 15:17:40 openHABianPi systemd[1]: Starting Graphical Interface.
Mar 13 15:17:40 openHABianPi systemd[1]: Reached target Graphical Interface.
Mar 13 15:17:40 openHABianPi systemd[1]: Starting Update UTMP about System Runlevel Changes…
Mar 13 15:17:40 openHABianPi systemd[1]: Started Update UTMP about System Runlevel Changes.
Mar 13 15:17:40 openHABianPi systemd[1]: Startup finished in 13.505s (kernel) + 26.787s (userspace) = 40.292s.
Mar 13 15:17:40 openHABianPi karaf[773]: Invalid pc in LineNumberTable in class file java/io/RandomAccessFile
Mar 13 15:17:40 openHABianPi karaf[773]: Error occurred shutting down framework: java.lang.ClassFormatError: Invalid pc in LineNumberTable in class file java/io/RandomAccessFile
Mar 13 15:17:41 openHABianPi karaf[773]: java.lang.ClassFormatError: Invalid pc in LineNumberTable in class file java/io/RandomAccessFile
Mar 13 15:17:41 openHABianPi karaf[773]: at java.lang.ClassLoader.findBootstrapClass(Native Method)
Mar 13 15:17:41 openHABianPi karaf[773]: at java.lang.ClassLoader.findBootstrapClassOrNull(ClassLoader.java:1015)
Mar 13 15:17:41 openHABianPi karaf[773]: at java.lang.ClassLoader.loadClass(ClassLoader.java:413)
Mar 13 15:17:41 openHABianPi karaf[773]: at java.lang.ClassLoader.loadClass(ClassLoader.java:411)
Mar 13 15:17:41 openHABianPi karaf[773]: at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:338)
Mar 13 15:17:41 openHABianPi karaf[773]: at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
Mar 13 15:17:41 openHABianPi karaf[773]: at org.apache.karaf.main.InstanceHelper.updateInstancePid(InstanceHelper.java:65)
Mar 13 15:17:41 openHABianPi karaf[773]: at org.apache.karaf.main.Main.updateInstancePidAfterShutdown(Main.java:230)
Mar 13 15:17:41 openHABianPi karaf[773]: at org.apache.karaf.main.Main.main(Main.java:193)
Mar 13 15:17:41 openHABianPi systemd[1]: openhab2.service: main process exited, code=exited, status=254/n/a
Mar 13 15:17:44 openHABianPi karaf[1644]: Can’t connect to the container. The container is not running.
Mar 13 15:17:44 openHABianPi systemd[1]: openhab2.service: control process exited, code=exited status=1
Mar 13 15:17:44 openHABianPi systemd[1]: Unit openhab2.service entered failed state.
Mar 13 15:17:49 openHABianPi systemd[1]: openhab2.service holdoff time over, scheduling restart.
Mar 13 15:17:49 openHABianPi systemd[1]: Stopping openHAB 2 - empowering the smart home…
Mar 13 15:17:49 openHABianPi systemd[1]: Starting openHAB 2 - empowering the smart home…
Mar 13 15:17:49 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
Mar 13 15:17:58 openHABianPi karaf[1829]: Invalid pc in LineNumberTable in class file java/io/RandomAccessFile
Mar 13 15:17:58 openHABianPi karaf[1829]: Error occurred shutting down framework: java.lang.ClassFormatError: Invalid pc in LineNumberTable in class file java/io/RandomAccessFile
This error is now written every 10-20 seconds.
I did an apt-get update + upgrade. No change
Did an openhabian upgrade from 2.1 to 2.2. No change
Any help would be really good, because i am really helpless.
Thanks in advance
