Hi Nathan,
thank you for all your answers.
I am still getting switch ON and still doing update.
So if I want to switch it OFF its again switched ON
Do I need some Rules or Scripts ?
my settings are:
Switch Garage_Door_A_Relay “Garage Door A” (gWater) {modbus=“slave1:45”, autoupdate=“FALSE”}
It looks like this:
2015-12-13 16:50:21.926 [INFO ] [runtime.busevents ] - Garage_Door_A_Relay state updated to ON
2015-12-13 16:50:22.930 [INFO ] [runtime.busevents ] - Garage_Door_A_Relay state updated to ON
2015-12-13 16:50:23.934 [INFO ] [runtime.busevents ] - Garage_Door_A_Relay state updated to ON
2015-12-13 16:50:24.947 [INFO ] [runtime.busevents ] - Garage_Door_A_Relay state updated to ON
2015-12-13 16:50:25.586 [INFO ] [runtime.busevents ] - Garage_Door_A_Relay received command OFF
2015-12-13 16:50:25.949 [INFO ] [runtime.busevents ] - Garage_Door_A_Relay state updated to ON
2015-12-13 16:50:26.958 [INFO ] [runtime.busevents ] - Garage_Door_A_Relay state updated to ON
2015-12-13 16:50:27.973 [INFO ] [runtime.busevents ] - Garage_Door_A_Relay state updated to ON
2015-12-13 16:50:29.291 [INFO ] [runtime.busevents ] - Garage_Door_A_Relay state updated to ON
2015-12-13 16:50:30.305 [INFO ] [runtime.busevents ] - Garage_Door_A_Relay state updated to ON
does the item actually switch the relay or is it just OpenHab reporting the events.
In the past I have had the situation where it toggles back to default because it didn’t actually work due to the modbus link not actually working. Usually due to some comm problem or config on your devices etc.
Andy
