I have problems using the MQTT Mosquette add on.
I’m Always getting this error:
2019-12-30 23:43:03.508 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to ‘192.168.178.100’ with clientid 5f6d589f-8fd6-488f-b8d6-7ad56d18e833
2019-12-30 23:43:06.140 [ERROR] [.moquette.broker.NewNettyMQTTHandler] - Unexpected exception while processing MQTT message. Closing Netty channel. CId=null
java.io.IOException: invalid massage
at io.moquette.broker.NettyUtils.validateMessage(NettyUtils.java:86) ~[?:?]
at io.moquette.broker.metrics.MQTTMessageLogger.logMQTTMessage(MQTTMessageLogger.java:61) ~[?:?]
at io.moquette.broker.metrics.MQTTMessageLogger.logMQTTMessageRead(MQTTMessageLogger.java:50) ~[?:?]
at io.moquette.broker.metrics.MQTTMessageLogger.channelRead(MQTTMessageLogger.java:45) ~[?:?]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:374) [bundleFile:4.1.42.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:360) [bundleFile:4.1.42.Final]
at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:352) [bundleFile:4.1.42.Final]
at io.moquette.broker.metrics.MessageMetricsHandler.channelRead(MessageMetricsHandler.java:50) [bundleFile:?]
at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:328) [bundleFile:4.1.42.Final]
at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:315) [bundleFile:4.1.42.Final]
at io.netty.handler.codec.ReplayingDecoder.callDecode(ReplayingDecoder.java:349) [bundleFile:4.1.42.Final]
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:283) [bundleFile:4.1.42.Final]
at io.netty.handler.timeout.IdleStateHandler.channelRead(IdleStateHandler.java:287) [bundleFile:4.1.42.Final]
at io.moquette.broker.metrics.BytesMetricsHandler.channelRead(BytesMetricsHandler.java:51) [bundleFile:?]
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1422) [bundleFile:4.1.42.Final]
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:931) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:163) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:700) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:635) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:552) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:514) [bundleFile:4.1.42.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor$6.run(SingleThreadEventExecutor.java:1044) [bundleFile:4.1.42.Final]
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.42.Final]
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.42.Final]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
Caused by: java.lang.IllegalArgumentException: invalid QoS: 3
at io.netty.handler.codec.mqtt.MqttQoS.valueOf(MqttQoS.java:40) ~[?:?]
at io.netty.handler.codec.mqtt.MqttDecoder.decodeFixedHeader(MqttDecoder.java:169) ~[?:?]
at io.netty.handler.codec.mqtt.MqttDecoder.decode(MqttDecoder.java:75) ~[?:?]
at io.netty.handler.codec.ByteToMessageDecoder.decodeRemovalReentryProtection(ByteToMessageDecoder.java:505) ~[?:?]
at io.netty.handler.codec.ReplayingDecoder.callDecode(ReplayingDecoder.java:366) ~[?:?]
… 25 more
Platform information:
- Hardware: QNAP TS-453B+/4GB
- OS: 4.4.1.1146
- openHAB version: 2.5.0 (Docker)
