I’ve installed the newest openhab version and also mosquitto on my Raspberry.
A NodeMcu is recieving commands and turns on/off a LED.
When i send a command on the subscribed channel (with the chrome extension), the arduino is receiving the “message”, when i press the button in openhab, nothing happens.
For example, I named the channel: /garage/light
The mqtt.cfg file:
# Define your MQTT broker connections here for use in the MQTT Binding or MQTT
# Persistence bundles. Replace <broker> with an ID you choose.
# URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
#<broker>.url=tcp://<host>:1883
# Optional. Client id (max 23 chars) to use when connecting to the broker.
# If not provided a random default is generated.
#<broker>.clientId=<clientId>
# Optional. True or false. If set to true, allows the use of clientId values
# up to 65535 characters long. Defaults to false.
# NOTE: clientId values longer than 23 characters may not be supported by all
# MQTT servers. Check the server documentation.
#<broker>.allowLongerClientIds=false
# Optional. User id to authenticate with the broker.
#<broker>.user=<user>
# Optional. Password to authenticate with the broker.
#<broker>.pwd=<password>
# Optional. Set the quality of service level for sending messages to this broker.
# Possible values are 0 (Deliver at most once),1 (Deliver at least once) or 2
# (Deliver exactly once). Defaults to 0.
#<broker>.qos=<qos>
# Optional. True or false. Defines if the broker should retain the messages sent to
# it. Defaults to false.
#<broker>.retain=<retain>
# Optional. True or false. Defines if messages are published asynchronously or
# synchronously. Defaults to true.
#<broker>.async=<async>
# Optional. Defines the last will and testament that is sent when this client goes offline
# Format: topic:message:qos:retained <br/>
#<broker>.lwt=<last will definition>
broker.url=tcp://IP:1883
The test.items file:
Switch mySwitch {mqtt=">[mybroker:/garage/light:command:ON:1],>[mybroker:/garage/light:command:OFF:0]"}
the log says:
2018-05-15 19:09:33.713 [vent.ItemStateChangedEvent] - mySwitch changed from NULL to ON
2018-05-15 19:09:34.969 [ome.event.ItemCommandEvent] - Item ‘mySwitch’ received command OFF
2018-05-15 19:09:35.049 [vent.ItemStateChangedEvent] - mySwitch changed from ON to OFF
But it doesn’t happen anything, either on this channel with the chrome extension or the arduino.
So the fault must be the openhab…
What do you think?
