I’m trying to setup a new OpneHAB application, currently running on a Windows 7 box. In the past, when I have a MQTT broker specified in the openhab.cfg file, I’ll see a message when I run the .bat file…something that saids “connection to mqtt broker successful”.
I saw it once with this new installation of OpenHAB. But the IP address was incorrect, so I edited the cfg file and corrected it. Then I restarted the .bat.
I’m not seeing the MQTT broker message in the start-up this time around. It’s not even trying to connect to a broker, it seems. I’ve made sure that:
- MQTT broker is specified in my openhab.cfg file. In this case, it’s name “mymosquitto”
mqtt:mymosquitto.url=tcp://192.168.2.104:1883
- MQTT binding is in the addons folder.
org.openhab.binding.mqtt-1.8.2.jar
I’m not sure what I did to screw it up? I’ve started fresh openhab applications a few times, and I thought these were the only two things I need to do to get it to connect to MQTT broker.
