Continuing the discussion from [OH2] Control ESP8266 Relay using MQTT Eventbus:
post your onoff.map plz
Switch item=Robo500 mappings=[ON="ON", OFF="OFF"]
this is for the sitemap and it should be ok. This will work also: Switch item=Robo500
you shouldn’t need a map.
note: there was a mistake in the Item definition
try this: (with Switch added in front and no transformation at the end)
Switch Robo500 "Robo 500" switch <siren> { mqtt=">[mosquitto:openhab/out/Robo500/command:command:*:default], <[mosquitto:openhab/in/Robo500/state:state:default]" }
now it seems to work, I continue with the development of the project trying to understand the error.
thank you very much
cool! good luck!
punch that solution check mark plz on the previous post to close this thread
