Java Runtime Environment: java version “1.8.0_171”
Java™ SE Runtime Environment (build 1.8.0_171-b11)
Java HotSpot™ Client VM (build 25.171-b11, mixed mode)
openHAB version: 2.2
Issue of the topic: I can’t get my openhab to get information from my mutt I have tested it with mqtt-spy. even node red can read information from the server.
Please post configurations (if applicable):
Items configuration related to the issue :
Number Bathroom_Temperature “Temperature” (Bathroom) {mqtt=“<[flatcntr:/TempCNTR/test/Temperature:string:default]”}
Number Bathroom_Humidity “Humidity [%.1F %%]” (Bathroom) {mqtt=“<[flatcntr:/TempCNTR/test/Humidity:state:default]”}
Sitemap configuration related to the issue
sitemap flat label=“FLAT” {
Frame {
Group item=Bathroom
Frame {
Text label=“Light” icon=“light” {
Default item=Bathroom_Light label=“Bathroom”
Text label="Fan" icon="fan_ceiling" {
Default item=Bathroom_Fan label="Bathroom"
Text label="Temperature" icon="temperature" {
Default item=Bathroom_Temperature label="Bathroom"
Text label="Humidity" icon="humidity" {
Default item=Bathroom_Humidity label="Bathroom"
Services configuration related to the issue
Define your MQTT broker connections here for use in the MQTT Binding or MQTT
Persistence bundles. Replace with an ID you choose.
URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
.url=ssl://localhost:1883
Optional. Client id (max 23 chars) to use when connecting to the broker.
If not provided a random default is generated.
flatcntr=
Optional. True or false. If set to true, allows the use of clientId values
up to 65535 characters long. Defaults to false.
NOTE: clientId values longer than 23 characters may not be supported by all
MQTT servers. Check the server documentation.
#.allowLongerClientIds=false
Optional. User id to authenticate with the broker.
#.user=
Optional. Password to authenticate with the broker.
#.pwd=
Optional. Set the quality of service level for sending messages to this broker.
Possible values are 0 (Deliver at most once),1 (Deliver at least once) or 2
(Deliver exactly once). Defaults to 0.
#.qos=
Optional. True or false. Defines if the broker should retain the messages sent to
it. Defaults to false.
#.retain=
Optional. True or false. Defines if messages are published asynchronously or
synchronously. Defaults to true.
#.async=
Optional. Defines the last will and testament that is sent when this client goes offline
Format: topic:message:qos:retained
#.lwt=
I am new to this. I have a esp8266 with a dht sensor. running espeasy
I can see the information is coming to the mqtt broker but I just can’t get the info in to openhab.
this is part of my cnew system for climate monitoring. I am also adding more to it my sonoff touch are getting delivered today.
09:38:06.181 [INFO ] [rt.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ‘’
09:38:06.185 [DEBUG] [rt.mqtt.internal.MqttBrokerConnection] - Creating new client for ‘ssl://localhost:1883’ using id ‘paho58712023007635’ and file store ‘/var/lib/openhab2/tmp/’
09:38:06.415 [ERROR] [openhab.io.transport.mqtt.MqttService] - Error starting broker connection
org.eclipse.paho.client.mqttv3.MqttException: MqttException
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:38) [208:org.openhab.io.transport.mqtt:1.11.0]
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:664) [208:org.openhab.io.transport.mqtt:1.11.0]
Caused by: java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream.java:210) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:?]
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:?]
at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) ~[?:?]
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.SSLNetworkModule.start(SSLNetworkModule.java:93) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:650) ~[?:?]
… 1 more
09:38:05.671 [ERROR] [del.item.internal.GenericItemProvider] - Binding configuration of type ‘mqtt’ of item ‘Bathroom_Temperature’ could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: Configuration ‘flatcntr:/TempCNTR/test/Temperature:string:default’ is not a valid inbound configuration: Invalid type.
09:56:07.151 [WARN ] [.ui.internal.items.ItemUIRegistryImpl] - Exception while formatting undefined value [sourcePattern=%.1F %ºC, targetPattern=%1$s %ºC, {}]
java.util.UnknownFormatConversionException: Conversion = ‘º’
at java.util.Formatter.checkText(Formatter.java:2579) [?:?]
at java.util.Formatter.parse(Formatter.java:2565) [?:?]
at java.util.Formatter.format(Formatter.java:2501) [?:?]
at java.util.Formatter.format(Formatter.java:2455) [?:?]
at java.lang.String.format(String.java:2940) [?:?]
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.formatUndefined(ItemUIRegistryImpl.java:434) [155:org.eclipse.smarthome.ui:0.10.0.b1]
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.getLabel(ItemUIRegistryImpl.java:345) [155:org.eclipse.smarthome.ui:0.10.0.b1]
at org.eclipse.smarthome.io.rest.sitemap.internal.SitemapResource.createWidgetBean(SitemapResource.java:417) [129:org.eclipse.smarthome.io.rest.sitemap:0.10.0.b1]
at org.eclipse.smarthome.io.rest.sitemap.internal.SitemapResource.createPageBean(SitemapResource.java:383) [129:org.eclipse.smarthome.io.rest.sitemap:0.10.0.b1]
at org.eclipse.smarthome.io.rest.sitemap.internal.SitemapResource.getPageBean(SitemapResource.java:288) [129:org.eclipse.smarthome.io.rest.sitemap:0.10.0.b1]
at org.eclipse.smarthome.io.rest.sitemap.internal.SitemapResource.getPageData(SitemapResource.java:222) [129:org.eclipse.smarthome.io.rest.sitemap:0.10.0.b1]
at sun.reflect.GeneratedMethodAccessor25.invoke(Unknown Source) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
09:56:08.456 [WARN ] [.ui.internal.items.ItemUIRegistryImpl] - Exception while formatting undefined value [sourcePattern=%.1F %ºC, targetPattern=%1$s %ºC, {}]
So for me it seems that the MQTT binding cannot connect to the broker. Please check if all settings are correct
After that you get many parsing errors:
I guess that the STRING here is wrong. From my experience it is always either a state or a command.
You might want to use a lower case “f” here. See also Formatter (Java Platform SE 7 )
OpenHab is using this formatter class and for formatting floats only a lower case f is specified.
You are welcome, but this was easy.
You just needed to read the docs carefully.
When you have a problem, always go back to the docs first. 90% of the time the answer of your problem will be there and you get to learn something by yourself at the same time.
The remaining 9%, someone will probably have tried it before and ask the forum and the answer will be there after a quick search.
The last 1% is when you ask a question in the forum. When you get really stuck.
my pi decided to go all screw you. and I had to load everything. did everything according to how it was working . the mqqt message from the temp sensor dos not display in open tab again.
I had a look at all my mqtt on the items and I think I am over looking something.
Ok, so you reloaded your PI with a fresh openhabian.
Have you got mosquitto running on it too?
Can you show me your mqtt.cfg?
And your openhab start up log, please?
04:51:00.021 [WARN ] [ab.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'FamilyRoom_Light'
04:51:00.022 [INFO ] [smarthome.event.ItemStateChangedEvent] - Bathroom_Humidity changed from 55.0 to 56.0
04:51:00.036 [WARN ] [ab.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'FamilyRoom_Fan'
04:51:00.045 [WARN ] [ab.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'FamilyRoom_Pargola_Light
06:05:32.524 [WARN ] [ab.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'FamilyRoom_Light'
06:05:33.257 [DEBUG] [g.mqtt.internal.MqttMessageSubscriber] - Received message before transformation service '{}' was initialized.
06:05:33.266 [WARN ] [b.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
06:05:33.275 [DEBUG] [tt.internal.AbstractMqttMessagePubSub] - No transformation service found for MAP
06:05:33.283 [WARN ] [ab.core.events.EventPublisherDelegate] - given new state is NULL, couldn't post update for 'FamilyRoom_Light'
