I could’t figure out how to map mqtt inbound values to Sitemap Item states.
For example:
My MQTT vaules are:
7, 14, 18, 22, and 24
that are fix Values from another mqtt device.
When one of these values comes in via mqtt I would like to map these to sitemap items.
Here my mqtt item
String Gaestezimmer_Solltemp "Gästezimmer Solltemperatur" {mqtt=">[mosquitto:edomi/in/set/Gaestezimmer/Temp/Soll-Temp:command:*:default], <[mosquitto:edomi/out/status/Gaestezimmer/Temp/Soll-Temp:state:MAP(heiz.map)]", autoupdate="false" }
Here my heiz.map
7=Frost
14=Nacht
18=Standby
22=Komfort
24=Warm
here my sitemap
Switch item=Gaestezimmer_Solltemp mappings=[7=Frost,14=Nacht,18=Standby,22=Komfort,24=Warm]
I could send the Values via mqtt but when I receive these Values my states in the ui dosent’t change.
So the outbound works as aspected.
Any idear about the inbound?
