Hi all
I’m not getting any MQTT messages
It seems all ok from log:
reading config
finished setting log
INFO:root:logging complete
INFO:root:Rolling old log over
INFO:root:config.ini file read successfully: 0
INFO:root:State01:Attempting connection to MQTT Broker: 192.168.1.39:1883
INFO:root:State01:MQTT client subscribed to control messages on topic: Paradox/C/#
INFO:root:State02:Connecting to IP Module
INFO:root:Connecting to 192.168.1.48
INFO:root:Logging into alarm system...
INFO:root:Login to alarm panel successful
INFO:root:Connected to MQTT broker with result code 0
INFO:root:Command 0x5F : Start communication
INFO:root:Command 0x00 : Initialize communication
INFO:root:State02: Logged into IP modeule successfully
INFO:root:State03: Preading labels
INFO:root:State03:Updating all labels from alarm
INFO:root:updateAllLabels: Topic being published Paradox/Labels/WirelessKeypads1:;2:;3:;4:;5:;6:;7:;8:
INFO:root:updateAllLabels: Topic being published Paradox/Labels/WirelessSirens1:;2:;3:;4:
INFO:root:updateAllLabels: Topic being published Paradox/Labels/SiteNames1:
INFO:root:updateAllLabels: Topic being published Paradox/Labels/Partitions1:;2:
INFO:root:updateAllLabels: Topic being published Paradox/Labels/WirelessRepeaters1:;2:
INFO:root:updateAllLabels: Topic being published Paradox/Labels/Outputs1:;2:;3:;4:;5:;6:;7:;8:;9:;10:;11:;12:;13:;14:;15:;16:
And this is my config
[IP150]
Pincode: pin ;PC Password (from Winload/Babyware)
Password: password
IP: 192.168.1.48
IP_Software_Port: 10000
[MQTT Broker]
IP: 192.168.1.39
Port: 1883
Mqtt_Username = user ;MQTT username, without qoutes
Mqtt_Password = password ;MQTT password, without qoutes
[Alarm]
Alarm_Model = ParadoxMG5050 ;Currently not used
Alarm_Registry_Map = ParadoxMG5050 ;This is used to map to the correct dictionary class within the ParadoxMap.py package. The word$
Alarm_Event_Map = ParadoxMG5050 ;This is used to map to the correct dictionary class within the ParadoxMap.py package. The word$
Zone_Amount = 32
[MQTT Topics]
Topic_Publish_Events = Paradox/Events ;The main topic used to publish all events
Events_Payload_Numeric = 0 ;1=Events are reported using numeric value [not replaced by the dictionary]. 0=Events are trans$
Topic_Subscribe_Control=Paradox/C/ ;All controls are given through this high-level topic
Startup_Publish_All_Info = True ;Upon startup publish all labels from the alarm (configured names of things), only application $
Topic_Publish_Labels = Paradox/Labels ;The topic used to publish labels
Topic_Publish_AppState = Paradox/State ;Publishes the scripts internal states, useful to check if connection is alive
Topic_Publish_ZoneState = Paradox/Zone ;Publishes the zone status' with the zone name as the next topic group (1 for open, 0 for close$
Topic_Publish_ArmState = Paradox/Partition ; Publishes the partition status 1 for armed, 0 for disarmed.
Topic_Publish_Heartbeat = Paradox/Heartbeat ; Publishes a periodic message, and it a last will and teastament of the mqtt connection
Topic_Publish_Status = Paradox/Status ; publishes specific parts of the 6 zone status messages (0 - 5)
Publish_Status_Factor = 10 ; A keepalive sequence is 6 seconds, this factory will publish the Status/0 message every fact$
Publish_Static_Topic = 1 ;Publish events emulated as topics, E.g. Paradox/Events/0/20
Publish_Zones_OpenClosed = 1 ; Publish OPEN and CLOSED for zones if 1, or ON and OFF is 0 (openhab contact items)
[Application]
Debug_Mode = 0 ;0=Minimal, 1=Basic, 2=Verbose
Startup_Update_All_Labels = True ;Upon startup collect all labels from the alarm (configured names of things). Required for conf$
Log_File = /opt/paradoxip/paradoxip.log ; can also use Log_File = stream://sys.stderr for stderr stream (for docker)
Auto_Logoff = True ;When detecting another 3rd party connection to the IP module, logoff for the Logoff_De$
Logoff_Delay = 120 ;Delay before reconnection after a 3rd party connection attempt
What else can I check?
I use the broker also for other stuff, and I get the messages.
I’ve read this thread but haven’t found a solution.
