Heya
Currently I am on 1.8.3 with the 1.9 action and binding for MQTT (tried 1.8.3 previously with the same issue)
I have mosquitto runnning and I get the sensor data just fine. When I try it with mosquitto_sub I get:
test/temperature/28-0000086a746c 21.187
I have configured openahb.conf
mqtt:mosquitto.url=tcp://:1883
And an item:
Number mqttTest “Temperatur: [%.1f °C]” {mqtt=“<[mosquitto:test/temperature/28-0000086a746c:state:default]”}
Now here is the issue: when I use the above item configuration I get most of the times nothing. Sometimes I get the Error:
2017-01-19 23:29:00.697 [WARN ] [.c.i.events.EventPublisherImpl] - given new state is NULL, couldn’t post update for ‘mqttTest’
If I change the item configuration:
Number mqttTest “Temperatur: [%.1f °C]” {mqtt=“<[mosquitto:test/temperature/28-0000086a746c:state:default:.]”}
2017-01-19 23:47:49.974 [DEBUG] [.o.b.m.i.MqttMessageSubscriber] - Skipped message ‘21.187’ because Message Filter ‘.’ does not apply.
So I do get the values, Openhab just somehow is not able to parse them.
I write the values via the python mqtt client and I have tried both: sending a float and a string. Same behavior.
