- Platform information:
- Hardware: Intel NUC 8GB /128GB SSD
- OS: Ubuntu Server 16.04
- Java Runtime Environment:OpenJDK Zulu
- openHAB version:2.20 with Openhabian 1.4
This items file was working fine until recently:
Number OilDepth "Depth [%d cm]" (g1) { mqtt="<[broker:RTL_433/JSON:state:JSONPATH($.depth):.*\"id\" \\: 137574874,.*]"}
Number OilTemp "Oil Temperature [%.2f °C]" (g1) { mqtt="<[broker:RTL_433/JSON:state:JSONPATH($.temperature_C):.*\"id\" \\: 137574874,.*]"}
Number PowerMeter "Power [%d W]" (g1) { mqtt="<[broker:RTL_433/JSON:state:JSONPATH($.power0):.*\"dev_id\" \\: 77,.*]"}
It capures the topics generated by a power consumption meter and an Oil depth gauge. The MQTT topic looks like this:
{"time" : "2018-01-23 18:48:16", "model" : "CurrentCost TX", "dev_id" : 77, "power0" : 1490, "power1" : 0, "power2" : 0}
{"time" : "2018-01-23 18:48:18", "model" : "Oil Watchman", "id" : 137574874, "flags" : 128, "maybetemp" : 25, "temperature_C" : 6.667, "binding_countdown" : 0, "depth" : 31}
{"time" : "2018-01-23 18:48:22", "model" : "CurrentCost TX", "dev_id" : 77, "power0" : 1502, "power1" : 0, "power2" : 0}
mqtt.cfg:
broker.url=tcp://127.0.0.1:1883
broker.clientId=openHAB2
It was working and I could see values being recorded in the logs, but I can’t figure out why it stopped.
If I save the items file, I can see it reloading but still no values recorded:
2018-01-23 17:01:13.254 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'mqtt.items'
2018-01-23 17:01:13.265 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message consumers for item OilDepth
2018-01-23 17:01:13.275 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message publishers for item OilDepth
2018-01-23 17:01:13.286 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message consumers for item OilTemp
2018-01-23 17:01:13.297 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message publishers for item OilTemp
2018-01-23 17:01:13.308 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message consumers for item PowerMeter
2018-01-23 17:01:13.319 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message publishers for item PowerMeter
2018-01-23 17:01:13.331 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'OilDepth' : 1 subscribers, 0 publishers
2018-01-23 17:01:13.344 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'OilTemp' : 1 subscribers, 0 publishers
2018-01-23 17:01:13.357 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'PowerMeter' : 1 subscribers, 0 publishers
I have stopped OpenHAB and cleared the cache, as well as uninstalling and re-installing the MQTT binding, I enabled DEBUG logging on the binding but it also showed nothing.
Any ideas would be most welcome!
