openHAB version: 2
I know this is not really a openhab problem, but on the tasmota forum this issue was not accepted and they advised to ask it here.
I have 2 T1 sonoff devices with tasmota.
One of my T1 with tasmota is connecting to the MQtt server, the other one first give the error:
MQT: Connect failed to 192.168.1.14:1883, rc 5. Retry in 10 sec
By the way all esp and arduino devices are working good with mqtt and openhab
settings of the device: device1:
MQTT Host 192.168.1.14
MQTT Port 1883
MQTT User openhab
MQTT Client rolluikebbadkamer
MQTT Topic bathR/window/shutter
MQTT Group Topic sonoffs
MQTT Full Topic cmnd/bathR/window/shutter/
MQTT Fallback Topic cmnd/rolluikenouderkamer_fb/
device2:
MQTT Port 1883
MQTT User openhab
MQTT Client rolluikenouderkamer
MQTT Topic parentsR/window/shutter
MQTT Full Topic cmnd/parentsR/window/shutter/
Each Client connecting to the Server has a unique ClientId
MQTT Client rolluikebbadkamer_1
MQTT Client rolluikebbadkamer_2
or in tasmota DVES_%06X (6 last digit of mac)
Hi Mpampinos,
thanks for the fast answer, but i do not quit understand your answer.
I also tried it with these settings but still get the same errror
device1:
This is what the _changelog files says:
6.4.1.1 20181224
I compiled the code my self, because I changed something in the interlocking code so that I can use it for roller shutters. (directly flipping between up and down).
Another strange thing is happening:
when I do “sudo systemctl restart mosquitto” I get the error:
MQT: Connect failed to 192.168.1.14:1883, rc -2. Retry in 10 sec
So rc=-2 instead of rc=5.
This error then occurs for both devices .
When I then run “sudo mosquitto”.
Both devices are getting a connection to the mosquitto broker.
There problem here is that error is getting back when I restart my ubuntu system.
That sounds a bit like the connection problems I observed with version 6.4.
Reverted back to 6.3.0 (build 2018.10.30 17:39:28 / Core-/SDK-Version 2_3_0/1.5.3(aec24ac9))
Although I had those problems on all my sonoff devices!
I also used core 2.5.0 I am now trying to get it back to 2.4.2.
For the shutters I know, I changed it so that if the up switch is active and I then I press the down switch it will not only stop, but it will do down too.
I now remember vaguely that with the first switch it did not work in core version 2.5.0, so I changed to 2.4.3. My computer crashed in the meanwhile, so I had to reinstall everything. I will let you know if that will solve the problem
Found the problem: I always logged in without a user name on my mqtt broker, but I had configure a user name with password. I also had the option allow_anonymous to true. So it is possible to login without a user name. But since it is not possible to NOT use a user name in tasmota ( it is always has a default name), it was asking for a password, which I did not fill.
When I filled in the correct username and password everything worked fine.!
