Get one and use one. They are the best tools for debugging mqtt
How they would help me debug? It seems that openhab just donât publish MQTT messageâŠ
Btw, DE1State item from my .items work - when I do mosquitto_pub -h 192.168.1.170 -t de1/state_update -m "test"
I see state gets updated in habmin
Also if I do âmosquitto_pub -h 192.168.1.170 -t de1/command -m âtestââ I can also see my mosquitto_sub window showing âtestâ - so broker is working
Fine if you donât want my adviceâŠ
I am sorry, I didnât mean that I donât want your advice, I am trying to understand how subscribing to the topic can help debugging problem when it seems that openhab doesnât publish anythingâŠ
Launched MQTT.fx, subscribed to de1/command topic - nothingâŠ
Broker Status in MQTT.fx shows that number of Messages Publish Sent doesnât change
Is there a way to turn on logs in openhab to see if it even try to publish anything?
Yes your log
There is nothing new in openhab.log when I change state of the switch
Can I see the log?
Subscribing to the topic will turn âseemsâ into certainty
As I mentioned in several of my previous posts - I donât get message when I subscribe
Itâs literally the same as I posted earlier - there is no new lines in openhab.log when I toggle switch. I will post it again when I get home
Try changing the topic.
Changed to âde1/triggerâ - same result
showlogs:
2018-06-13 05:16:00.001 [vent.ChannelTriggeredEvent] - astro:sun:local:daylight#event triggered START
2018-06-13 05:16:00.002 [vent.ChannelTriggeredEvent] - astro:sun:local:rise#event triggered END
2018-06-13 05:16:00.003 [.event.RuleStatusInfoEvent] - eafb1fc3-79a9-466a-b599-721e29ffd762 updated: RUNNING
2018-06-13 05:16:00.004 [ome.event.ItemCommandEvent] - Item 'exterior_light_switch' received command OFF
2018-06-13 05:16:00.004 [ome.event.ItemCommandEvent] - Item 'zwave_device_contoller_node12_switch_binary' received command OFF
2018-06-13 05:16:00.004 [.event.RuleStatusInfoEvent] - eafb1fc3-79a9-466a-b599-721e29ffd762 updated: IDLE
2018-06-13 05:24:00.001 [vent.ChannelTriggeredEvent] - astro:moon:local:rise#event triggered START
2018-06-13 12:44:00.002 [vent.ChannelTriggeredEvent] - astro:moon:local:phase#event triggered NEW
2018-06-13 13:10:00.002 [vent.ChannelTriggeredEvent] - astro:sun:local:noon#event triggered START
2018-06-13 13:11:00.001 [vent.ChannelTriggeredEvent] - astro:sun:local:noon#event triggered END
2018-06-13 18:23:01.961 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'DE1Plus.items'
2018-06-13 18:23:01.963 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message consumers for item DE1
2018-06-13 18:23:01.963 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message publishers for item DE1
2018-06-13 18:23:01.963 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Removing message producer for broker 'mosquitto'
2018-06-13 18:23:01.964 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message consumers for item DE1State
2018-06-13 18:23:01.964 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Unsubscribing message consumer for topic 'de1/state_update' from broker 'mosquitto'
2018-06-13 18:23:01.964 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message publishers for item DE1State
2018-06-13 18:23:01.965 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'DE1State' : 1 subscribers, 0 publishers
2018-06-13 18:23:01.965 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Starting message consumer for broker 'mosquitto' on topic 'de1/state_update'
2018-06-13 18:23:01.965 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item 'DE1' : 0 subscribers, 1 publishers
.items:
String DE1State { mqtt="<[mosquitto:de1/state_update:state:default]" }
//Switch DE1 "DE1" ["Switchable"] {mqtt="<[mosquitto:de1/state_update:state:default],>[mosquitto:de1/turn_on:command:ON:1],>[mosquitto:de1/turn_off:command:OFF:0]"}
//Switch DE1 "DE1" ["Switchable"] { mqtt=">[mosquitto:de1/command:command:*:default],<[mosquitto:de1/command:command:*:default]" }
//Switch DE1 "DE1" ["Switchable"] {mqtt=">[mosquitto:de1/command:*:Switch ${itemName} was turned ${command}]"}
//Switch DE1 "DE1" ["Switchable"] { mqtt=">[mosquitto:de1/command:command:*:default" }
Switch DE1 "DE1" ["Switchable"] { mqtt=">[mosquitto:de1/trigger:command:*:default]" }
Not sure if that relevant, but when I subscribe to â#â topic I see retained message to âmyhome/bedroom/switch2â in MQTT.fx showing up⊠I do have it defined in another .items file - but it also doesnât work when I trigger switch - no mqtt messages
switch.items:
//Switch Switch1 {mqtt=">[mosquitto:myhome/bedroom/switch1:command:ON:1],>[mosquitto:myhome/bedroom/switch1:command:OFF:0],<[mosquitto:myhome/bedroom/switch1:state:ON:1],<[mosquitto:myhome/bedroom/switch1:state:OFF:0"}
Switch SwitchMQTT { mqtt=">[mosquitto:myhome/bedroom/switch2:command:ON:1],>[mosquitto:myhome/bedroom/switch2:command:OFF:0],<[mosquitto:myhome/bedroom/switch2:state:ON:1],<[mosquitto:myhome/bedroom/switch2:state:OFF:0]" }
How do you trigger your switches?
In classicui?
Can I see your sitemap, please?
After reading some source code (https://github.com/openhab/openhab1-addons/blob/db62be70e9cd9561036d8925a177a2e37aaa4bd4/bundles/binding/org.openhab.binding.mqtt/src/main/java/org/openhab/binding/mqtt/internal/MqttItemBinding.java) I kinda starting to thinking that it might be
my item doesnât receive any commands when I trigger them from Habmin Sitemaps
I feel like an idiot now, when I trigger switch from Habmin - nothing happens, when I trigger form Basic UI - everything works
Thanks a lot for dealing with me, I feel bad for wasting so much your time
Use habmin for Zwave configuration. Use the rest of openhab for other things.
Can you mark the solution, please?
Thank you
Good luck
