ikir
(Kirill)
June 10, 2018, 7:46pm
1
I am trying to make a simple switch that would send message to the MQTT topic
here is my .items:
String DE1State {mqtt="<[mosquitto:de1/state_update:state:default]"}
Switch DE1 "DE1" ["Switchable"] {mqtt=">[mosquitto:de1/command:command:*:Switch ${itemName} was turned ${command}]"}
My .sitemap:
sitemap demo label="My MQTT Demo Switches" {
Frame label="Demo" {
Text item=DE1State
Switch item=DE1
I see that my string idem gets updated when I publish something to de1/state_update topic, but nothing happened when I toggle switch in Habmin - I donât see any topic gets publishedâŠ
I tried
Switch DE1 "DE1" ["Switchable"] {mqtt=">[mosquitto:de1/command:command:*:default"}
it didnât work eitherâŠ
Any ideas what I am doing wrong?
vzorglub
(Vincent Regaud)
June 10, 2018, 7:55pm
2
You need a space after the {
and before the }
Switch DE1 "DE1" ["Switchable"] { mqtt=">[mosquitto:de1/command:command:*:Switch ${itemName} was turned ${command}]" }
ikir
(Kirill)
June 10, 2018, 8:01pm
3
Hm⊠I donât have space in my String my itemâŠ
vzorglub
(Vincent Regaud)
June 10, 2018, 8:02pm
4
Yours:
Mine:
See the difference now?
ikir
(Kirill)
June 10, 2018, 8:03pm
5
Also, looking at openhab.log it didnât fail parsing and actually added subscription on topic de1/command:
2018-06-10 13:02:14.878 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item âDE1â : 1 subscribers, 1 publishers
2018-06-10 13:02:14.878 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Starting message consumer for broker âmosquittoâ on topic âde1/commandâ
ikir
(Kirill)
June 10, 2018, 8:04pm
6
Adding space didnât help
vzorglub
(Vincent Regaud)
June 10, 2018, 8:07pm
7
You should have 1 publisher, 0 subscribers
It that the entire item definition?
vzorglub
(Vincent Regaud)
June 10, 2018, 8:11pm
8
Try this:
Switch DE1 "DE1" ["Switchable"] { mqtt=">[mosquitto:de1/command:command:*:default]" }
ONLY
hmerk
(Hans-Jörg Merk)
June 10, 2018, 8:54pm
10
Square bracket missing at the end.
vzorglub
(Vincent Regaud)
June 10, 2018, 8:56pm
11
@hmerk , Yes I missed that
But the longer definition should work, though. Going back to basics.
ikir
(Kirill)
June 11, 2018, 2:05am
14
mosquitto.url=tcp://localhost:1883
mosquitto.clientId=openhab
mosquitto.retain=true
mosquitto.async=false
Dim
(Angelos)
June 11, 2018, 4:42am
15
ikir:
â] { mqtt="
could be a typo, but try to use the correct quote marks everywhere: ""
instead of ââ
Also, add a spaces in the tag (it should work also without i think)
Switch DE1 "DE1" [ "Switchable" ] { mqtt=">[mosquitto:de1/command:command:*:default]" }
you should have some log entry about errors in your items file.
vzorglub
(Vincent Regaud)
June 11, 2018, 5:40am
16
I didnât see these bloody quotes on my phone screen!
vzorglub
(Vincent Regaud)
June 11, 2018, 5:53am
17
mosquitto.url=tcp://127.0.0.1:1883
Show me the openhab.log when OH starts and when you edit the item file, please
Also can you publish the complete items file, thanks
ikir
(Kirill)
June 11, 2018, 11:35pm
18
Complete .items file:
String DE1State { mqtt="<[mosquitto:de1/state_update:state:default]" }
//Switch DE1 "DE1" ["Switchable"] {mqtt="<[mosquitto:de1/state_update:state:default],>[mosquitto:de1/turn_on:command:ON:1],>[mosquitto:de1/turn_off:command:OFF:0]"}
//Switch DE1 "DE1" ["Switchable"] { mqtt=">[mosquitto:de1/command:command:*:default],<[mosquitto:de1/command:command:*:default]" }
//Switch DE1 "DE1" ["Switchable"] {mqtt=">[mosquitto:de1/command:*:Switch ${itemName} was turned ${command}]"}
//Switch DE1 "DE1" ["Switchable"] { mqtt=">[mosquitto:de1/command:command:*:default" }
openhab.log:
2018-06-11 16:33:22.745 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item âDE1â : 0 subscribers, 1 publishers
2018-06-11 16:33:22.748 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model âDE1Plus.itemsâ
2018-06-11 16:33:22.750 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message consumers for item DE1State
2018-06-11 16:33:22.750 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Unsubscribing message consumer for topic âde1/state_updateâ from broker âmosquittoâ
2018-06-11 16:33:22.750 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message publishers for item DE1State
2018-06-11 16:33:22.751 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message consumers for item DE1
2018-06-11 16:33:22.751 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message publishers for item DE1
2018-06-11 16:33:22.751 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Removing message producer for broker âmosquittoâ
2018-06-11 16:33:22.751 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item âDE1Stateâ : 1 subscribers, 0 publishers
2018-06-11 16:33:22.752 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Starting message consumer for broker âmosquittoâ on topic âde1/state_updateâ
2018-06-11 16:33:22.752 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item âDE1â : 0 subscribers, 1 publishers
2018-06-11 16:33:22.757 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model âDE1Plus.itemsâ
2018-06-11 16:33:22.759 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message consumers for item DE1State
2018-06-11 16:33:22.759 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Unsubscribing message consumer for topic âde1/state_updateâ from broker âmosquittoâ
2018-06-11 16:33:22.760 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message publishers for item DE1State
2018-06-11 16:33:22.760 [DEBUG] [.internal.MqttGenericBindingProvider] - Removing message consumers for item DE1
2018-06-11 16:33:22.761 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Removing message producer for broker âmosquittoâ
2018-06-11 16:33:22.761 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item âDE1Stateâ : 1 subscribers, 0 publishers
2018-06-11 16:33:22.761 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Starting message consumer for broker âmosquittoâ on topic âde1/state_updateâ
2018-06-11 16:33:22.762 [DEBUG] [binding.mqtt.internal.MqttItemConfig] - Loaded MQTT config for item âDE1â : 0 subscribers, 1 publishers
vzorglub
(Vincent Regaud)
June 12, 2018, 6:08am
19
It should work
Do you have an MQTT monitor like mqtt.fx or mqtt-spy?
Get one and subcribe to the topic de1/command
. You should see the payload ON
and OFF
when you action the switch.
ikir
(Kirill)
June 12, 2018, 11:59pm
20
It doesnât work, I use mosquito_sub -t de1/command to listen and when trigger control from habminâs sitemap I donât see anything in terminal where mosquito_sub is runnin
