Hello!
I’m trying to connect 2 different users to the same openhab controller.
I’ve registered 2 emails in the portal and set id and secret in the control panel of each user.
The first user registered is working fine but the second show the controller offline.
Is it possible to connect multiple users to the same controller? I would like to do that because I would like to have different push notification depending to each user.
[quote=“alberto.vincenzi, post:1, topic:6124, full:true”]
… and set id and secret in the control panel of each user.[/quote]
How did you do that?
UUID and SECRET are created just once in your openhab installation and need to be set up under “Account”
Then create as many users as you like and set up the notifications.
Or did you forget to put that second user into the settings of habdroid on your second smartphone (assuming you are using Android)?
I registered a second user in my.openhab in the same way I created the first, then I’ve put UUID and SECRET in the control panel (in my.openhab) of each user.
When I log into my.openhab there is only ONE place (under “Account”) where you can store the UUID and SECRET. This is common for both (or even more) users.
But anyway, to make that work (I have also two users for different notifications) I did the following:
add a user, give him/her a password and provide an email adress
add the next user, give him/her a password and provide a different email address
add the first user to the first smartphone, set his/her username and password
add the next user to the second smartphone, set his/her username and password
check in my.openhab under “Devices” if both smartphones are present
edit one of the rules: sendNotification("firstuser@domain.de", "Testmessage first user")
edit another rule: sendNotification("nextuser@domain.de", "Testmessage next user")
I didi this and I am able to get notifications on the first user that happen to be the same of the account. I created a new user under the account but his device is not added, therefore is not able to receive notifications. What i am missing?
I can not check it because I don’t use it anymore. The service was unreliable and I changed to a paid service.
I assume there is something wrong with the second device, it looks like it cannot connect to my.openhab. Double check the correct remote url and username and password.
From my experience, all information provided are correct; but i have to completely remove the app (on android) to make notification work “per-user”. Even if i reconfigure the credentials in the app for openhab cloud, they keep on working like nothing changed.
I don’t know about iphone behaviour - i decided simply to remove the app, reinstall and set up properly, and it worked.
Almost 10 years old thread so maybe things are changed . @sihui do you still think it’s unreliable? If yes, which kind of notification service are you currently using?
