Just to re-re-revisit this, I’m still getting the Cannot cast org.openhab.core.types.UnDefType to org.openhab.core.library.types.DateTimeType
error.
This occurs frequently and is NOT just at startup. It seems to be when it’s trying to recalc time related ‘things’. Designer shows no conflicts…
My rules are below;
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.joda.time.*
import org.java.math.*
var Timer tDownstairsLights
var Timer tUpstairsLights
var Timer tLivingRoomLight
var Timer tOnkyoPower
var Timer tSamsungPower
rule "Get time period for right now"
System started
val morning = now.withTimeAtStartOfDay.plusHours(5).millis // 5 AM
val sunrise = new DateTime((Sunrise_Time.state as DateTimeType).calendar.timeInMillis)
val twilight = new DateTime((Twilight_Event.state as DateTimeType).calendar.timeInMillis)
val night = now.withTimeAtStartOfDay.plusHours(23).millis // 11 PM
if(now.isAfter(morning) && now.isBefore(sunrise)) {
Morning.sendCommand(ON)
Day.sendCommand(OFF)
Twilight.sendCommand(OFF)
Night.sendCommand(OFF)
else if(now.isAfter(sunrise) && now.isBefore(twilight)) {
Morning.sendCommand(OFF)
Day.sendCommand(ON)
else if(now.isAfter(twilight) && now.isBefore(night)) {
Twilight.sendCommand(ON)
else if(now.isAfter(night) && now.isBefore(morning)) {
Night.sendCommand(ON)
rule "Morning Started"
Time cron "0 0 5 * * ? *"
rule "Day"
Item Sunrise_Event received update
Day.sendCommand(ON)
rule "Twilight"
Item Twilight_Event received update
rule "Night Started"
Time cron "0 0 23 * * ? *"
rule "Enable Downstairs Hallway Light on Motion"
Item Z_Motion_GF_Hallway changed
if(Morning.state == ON)
sendCommand(Hue_Hallway_Downstairs, ON)
sendCommand(Hue_Hallway_DownstairsDim, 5)
else if(Twilight.state == ON)
sendCommand(Hue_Hallway_DownstairsDim, 100)
else if(Night.state == ON)
sendCommand(Hue_Hallway_DownstairsDim, 10)
rule "Enable Upstairs Hallway Light on Motion"
Item Z_PIR_FF_Hallway changed
sendCommand(Hue_Hallway_Upstairs, ON)
sendCommand(Hue_Hallway_UpstairsDim, 5)
sendCommand(Hue_Hallway_UpstairsDim, 100)
sendCommand(Hue_Hallway_UpstairsDim, 10)
rule "Turn Bathroom Speakers on at 6pm"
Time cron "0 0 18 * * ?"
sendCommand(Z_Socket_FF_BathroomSpeakers, ON)
rule "Turn Kitchen Speakers on at 6pm"
Time cron "0 0 13 * * ?"
sendCommand(Z_Socket_GF_KitchenSpeakers, ON)
rule "Turn Bedroom TV Off at Half past Midnight on a School night"
Time cron "0 30 0 ? * MON,TUE,WED,THU,SUN *" // School nights at 00:30 hours
sendCommand(LgTvPower, ON)
rule "Turn Bedroom TV Off at Half past Midnight at the weekend"
Time cron "0 0 1 ? * FRI,SAT" // Weekend 01:30 hours
rule "Turn Bedroom TV down at 11pm"
Time cron "0 0 23 * * ?" // Every day at 23:00, turn volume down further
sendCommand(LgTvVolume, DECREASE)
rule "Turn Bedroom TV down at Midnight"
Time is midnight // Every day Midnight, turn volume down even further
rule "Update max and min temperatures"
Item Weather_Temperature changed or
Time cron "0 0 0 * * ?" or
System started
postUpdate(Weather_Temp_Max, Weather_Temperature.maximumSince(now.toDateMidnight).state)
postUpdate(Weather_Temp_Min, Weather_Temperature.minimumSince(now.toDateMidnight).state)
logInfo("Weather", "Temperature evolved of " + Weather_Temperature.deltaSince(now.minusMinutes(2)) + " degrees.")
rule "Turn living room lights on when it gets dark"
Item Twilight_Event received update ON
sendCommand(Hue_LivingRoom_TallLamp, ON)
sendCommand(Hue_LivingRoom_TallLampDim, 50)
sendCommand(Hue_LivingRoom_Lamp, ON)
sendCommand(Hue_LivingRoom_LampDim, 50)
sendCommand(Hue_LivingRoom_MainLight, ON)
sendCommand(Hue_LivingRoom_MainLightDim, 50)
rule "Turn living room lights up when it gets darker"
Item Sunset_Event received update ON
sendCommand(Hue_LivingRoom_TallLampDim, 100)
sendCommand(Hue_LivingRoom_LampDim, 100)
sendCommand(Hue_LivingRoom_MainLightDim, 100)
rule "Enable Living Room Main Light on Motion (cat feed)"
sendCommand(Hue_LivingRoom_MainLightMorning, ON)
sendCommand(Hue_LivingRoom_MainLightMorningDim, 30)
rule "Turn Living Room Main Light off after time in morning"
Item Hue_LivingRoom_MainLightMorning received command
if(receivedCommand==ON) {
if(tLivingRoomLight==null) {
// first ON command, so create a timer to turn the light off again
tLivingRoomLight = createTimer(now.plusSeconds(300)) [|
sendCommand(Hue_LivingRoom_MainLightMorning, OFF)
sendMail("email@address.com", "Living Room Light is off (Morning)", "Cat feed light")
} else {
// subsequent ON command, so reschedule the existing timer
tLivingRoomLight.reschedule(now.plusSeconds(300))
} else if(receivedCommand==OFF) {
// remove any previously scheduled timer
if(tLivingRoomLight!=null) {
tLivingRoomLight.cancel
tLivingRoomLight = null
rule "Turn Downstairs Hallway Light off after 5 minutes"
Item Hue_Hallway_Downstairs received command
if(tDownstairsLights==null) {
tDownstairsLights = createTimer(now.plusSeconds(300)) [|
sendCommand(Hue_Hallway_Downstairs, OFF)
} else {
tDownstairsLights.reschedule(now.plusSeconds(300))
if(tDownstairsLights!=null) {
tDownstairsLights.cancel
tDownstairsLights = null
rule "Turn Upstairs Hallway Light off after 5 minutes"
Item Hue_Hallway_Upstairs received command
if(tUpstairsLights==null) {
tUpstairsLights = createTimer(now.plusSeconds(300)) [|
sendCommand(Hue_Hallway_Upstairs, OFF)
} else {
tUpstairsLights.reschedule(now.plusSeconds(300))
if(tUpstairsLights!=null) {
tUpstairsLights.cancel
tUpstairsLights = null
rule "Turn things off at 10:30pm daily"
Time cron "0 30 22 * * ?"
sendCommand(Z_Socket_GF_KitchenSpeakers, OFF)
sendCommand(Z_Socket_FF_BathroomSpeakers, OFF)
rule "Turn everything off at Midnight"
Time is midnight
sendCommand(Hue_LivingRoom_Lamp, OFF)
sendCommand(Hue_LivingRoom_TallLamp, OFF)
sendCommand(Hue_LivingRoom_MainLight, OFF)
sendCommand(Z_Socket_FrontBedroom_DAB, OFF)
sendMail("email@address.com", "It's midnight!", "Everything is now off.")
rule "Turn Downstairs Lights off 5 minutes after TV goes off"
Item SamsungTV received command
if(tSamsungPower==null) {
tSamsungPower = createTimer(now.plusSeconds(300)) [|
sendMail("email@address.com", "TV off, Lights off! (1)", "TV off, Lights off! (1)")
} else {
tSamsungPower.reschedule(now.plusSeconds(300))
sendMail("email@address.com", "TV off, Lights off! (2)", "TV off, Lights off! (2)")
} else {
rule "Turn Front Bedroom Toys on"
Item Z_Light_FF_FrontBedroomSwitch received command ON
sendCommand(Z_Socket_FrontBedroom_DAB, ON)
sendCommand(Z_Socket_FrontBedroom_Morning, ON)
rule "Turn Front Bedroom Toys off"
Item Z_Light_FF_FrontBedroomSwitch received command OFF
sendCommand(Z_Socket_FrontBedroom_Morning, OFF)
sendMail("email@address.com", "Front Bedroom is OFF!", "Radio is off.")
