Hi
My account on myopenhab shows I’m offline all the time.
On the log file I see this failure every 5 seconds:
2018-10-25 21:09:13.820 [DEBUG] [io.socket.client.Manager ] - attempting reconnect
2018-10-25 21:09:13.821 [DEBUG] [io.socket.client.Manager ] - readyState CLOSED
2018-10-25 21:09:13.821 [DEBUG] [io.socket.client.Manager ] - opening https://www.myopenhab.org:443/
2018-10-25 21:09:13.822 [DEBUG] [io.socket.client.Manager ] - connection attempt will timeout after 20000
2018-10-25 21:09:13.822 [DEBUG] [io.socket.engineio.client.Socket ] - creating transport 'polling'
2018-10-25 21:09:13.823 [DEBUG] [io.socket.engineio.client.Socket ] - setting transport polling
2018-10-25 21:09:13.823 [DEBUG] [t.engineio.client.transports.Polling] - polling
2018-10-25 21:09:13.823 [DEBUG] [ngineio.client.transports.PollingXHR] - xhr poll
2018-10-25 21:09:13.824 [DEBUG] [ngineio.client.transports.PollingXHR] - xhr open GET: https://www.myopenhab.org/socket.io/?EIO=3&transport=polling
2018-10-25 21:09:13.824 [DEBUG] [ngineio.client.transports.PollingXHR] - sending xhr with url https://www.myopenhab.org/socket.io/?EIO=3&transport=polling | data null
2018-10-25 21:09:13.981 [DEBUG] [.www.protocol.http.HttpURLConnection] - sun.net.www.MessageHeader@3fa9752d10 pairs: {GET /socket.io/?EIO=3&transport=polling HTTP/1.1: null}{clientversion: 2.3.0}{openhabversion: 2.3.0}{remoteaccess: true}{secret: ***********}{uuid: ***********}{User-Agent: Java/1.8.0_181}{Host: www.myopenhab.org}{Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2}{Connection: keep-alive}
2018-10-25 21:09:14.059 [DEBUG] [.www.protocol.http.HttpURLConnection] - sun.net.www.MessageHeader@3b96f60018 pairs: {null: HTTP/1.1 404 Not Found}{Server: GitHub.com}{Content-Type: text/html; charset=utf-8}{ETag: "5b9391e2-6e0"}{Access-Control-Allow-Origin: *}{X-GitHub-Request-Id: 6C6A:248E:13C23CE:1AC9ED8:5BD1FB5F}{Content-Length: 1760}{Accept-Ranges: bytes}{Date: Thu, 25 Oct 2018 18:09:10 GMT}{Via: 1.1 varnish}{Age: 2915}{Connection: keep-alive}{X-Served-By: cache-hhn1547-HHN}{X-Cache: HIT}{X-Cache-Hits: 40}{X-Timer: S1540490950.470202,VS0,VE0}{Vary: Accept-Encoding}{X-Fastly-Request-ID: c9ecb7af79253acce6a8b6fba2b80d8d05ef4414}
2018-10-25 21:09:14.060 [DEBUG] [io.socket.engineio.client.Socket ] - socket error io.socket.engineio.client.EngineIOException: xhr poll error
2018-10-25 21:09:14.061 [DEBUG] [io.socket.client.Manager ] - connect_error
2018-10-25 21:09:14.061 [DEBUG] [io.socket.client.Manager ] - cleanup
2018-10-25 21:09:14.062 [DEBUG] [io.socket.client.Manager ] - reconnect attempt error
2018-10-25 21:09:14.063 [DEBUG] [io.socket.client.Manager ] - will wait 5000ms before reconnect attempt
2018-10-25 21:09:14.063 [DEBUG] [io.socket.engineio.client.Socket ] - socket close with reason: transport error
2018-10-25 21:09:14.064 [DEBUG] [t.engineio.client.transports.Polling] - transport not open - deferring close
2018-10-25 21:09:16.233 [DEBUG] [org.eclipse.jetty.io.ManagedSelector] - Channel java.nio.channels.SocketChannel[connection-pending remote=/10.0.0.1:9090] timed out while connecting, closing it
2018-10-25 21:09:16.233 [DEBUG] [nt.io.WebSocketClientSelectorManager] - Connection Failed
java.net.SocketTimeoutException: Connect Timeout
at org.eclipse.jetty.io.ManagedSelector$ConnectTimeout.run(ManagedSelector.java:683) [76:org.eclipse.jetty.io:9.3.21.v20170918]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) [?:?]
at java.util.concurrent.FutureTask.run(Unknown Source) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
at java.lang.Thread.run(Unknown Source) [?:?]
2018-10-25 21:09:19.065 [DEBUG] [io.socket.client.Manager ] - attempting reconnect
My Java version is:
java version “1.8.0_181”
Java™ SE Runtime Environment (build 1.8.0_181-b13)
Java HotSpot™ 64-Bit Server VM (build 25.181-b13, mixed mode)
Running on Windows 8.1
I’ve trying changing my UUID and secret, tried updating Java to the latest, tried rebooting.
Nothing seems to help.
Anyone has an idea what am I missing?
