[SOLVED] Mysql.cfg not able to edit after persistance installation
I can edit all other cfg files, but not mysql.cfg.
I’ve just installed MYSQL Persistance on my RPI.
What are the permissions on the file? ls -al /etc/openhab2/services
Should be -rw-rw-r-- openhab openhabian
If not use the openhabian tool to fix. sudo openhabian-config select Apply Improvements then Fix Permissions.
-rw-r--r--   1 openhab openhab   450 Feb  3 14:20 mysql.cfg
As mentioned above use sudo openhabian-config select Apply Improvements then Fix Permissions. That should take care of the issue.:crossed_fingers:
Thanks, H102, it works well now.
Good deal.:+1: and thanks for clicking the solution. I edited the title to start with [Solved] as well.:wink:
