I’m struggling on the last step to get the actual data to the sitemap of openhab, after everything else is working…went through the configs and tutorial several times, cannot find the mistake..
I have 3 xiaomi aqara sensors (square)
what is done:
-mosquitto installed and running
-zigbee2mqtt installed and running
-mqtt binding installed in OH 2.5
-devices paired with zigbee2mqtt and showing data in the logs (temperature,humidity,battery..)
-mqtt.things and mqtt.items created following the “new way” no transformations
-mosquitto_sub -d -t zigbee2mqtt/# shows reading from sensors
my things:
Bridge mqtt:broker:mosquitto [host="localhost", secure=false]
Thing topic SensorLiving "SensorLiving" @ "Muneera Doma" {
Channels:
Type number: LivingTemperature "Living Temperature [%d mV]" [stateTopic="zigbee2mqtt/SensorLiving/temperature"]
Type number: LivingHumidity "Living Humidity [%d mV]" [stateTopic="zigbee2mqtt/SensorLiving/humidity"]
Type number: LivingPressure "Living Pressure [%d mV]" [stateTopic="zigbee2mqtt/SensorLiving/pressure"]
Type number: LivingBattery "Living Battery [%d mV]" [stateTopic="zigbee2mqtt/SensorLiving/battery"]
Type number: LivingLink "Living Link Quality [%d mV]" [stateTopic="zigbee2mqtt/SensorLiving/linkquality"]
Thing topic SensorKids "SensorKids" @ "Muneera Doma" {
Channels:
Type number: KidsTemperature "Kids Temperature [%d mV]" [stateTopic="zigbee2mqtt/SensorKids/temperature"]
Type number: KidsHumidity "Kids Humidity [%d mV]" [stateTopic="zigbee2mqtt/SensorKids/humidity"]
Type number: KidsPressure "Kids Pressure [%d mV]" [stateTopic="zigbee2mqtt/SensorKids/pressure"]
Type number: KidsBattery "Kids Battery [%d mV]" [stateTopic="zigbee2mqtt/SensorKids/battery"]
Type number: KidsLink "Kids Link Quality [%d mV]" [stateTopic="zigbee2mqtt/SensorKids/linkquality"]
Thing topic SensorBalcony "SensorBalcony" @ "Muneera Doma" {
Channels:
Type number: BalconyTemperature "Balcony Temperature [%d mV]" [stateTopic="zigbee2mqtt/SensorBalcony/temperature"]
Type number: BalconyHumidity "Balcony Humidity [%d mV]" [stateTopic="zigbee2mqtt/SensorBalcony/humidity"]
Type number: BalconyPressure "Balcony Pressure [%d mV]" [stateTopic="zigbee2mqtt/SensorBalcony/pressure"]
Type number: BalconyBattery "Balcony Battery [%d mV]" [stateTopic="zigbee2mqtt/SensorBalcony/battery"]
Type number: BalconyLink "Balcony Link Quality [%d mV]" [stateTopic="zigbee2mqtt/SensorBalcony/linkquality"]
my items:
Number LivingTemperature "Living Temperature [%.1f °C]" <temperature> {channel="mqtt:topic:mosquitto:SensorLiving:temperature"}
Number LivingHumidity "Living Humidity [%.1f °C]" <humidity> {channel="mqtt:topic:mosquitto:SensorLiving:humidity"}
Number KidsTemperature "Kids Temperature [%.1f °C]" <temperature> {channel="mqtt:topic:mosquitto:SensorKids:temperature"}
Number KidsHumidity "Kids Humidity [%.1f °C]" <humidity> {channel="mqtt:topic:mosquitto:SensorKids:humidity"}
Number BalconyTemperature "Balcony Temperature [%.1f °C]" <temperature> {channel="mqtt:topic:mosquitto:SensorBalcony:temperature"}
Number BalconyHumidity "Balcony Humidity [%.1f °C]" <humidity> {channel="mqtt:topic:mosquitto:SensorBalcony:humidity"}
zigbee2mqtt log
zigbee2mqtt.service - zigbee2mqtt
Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2020-08-15 16:29:01 +04; 2min 52s ago
Main PID: 482 (node)
Tasks: 23 (limit: 2068)
CGroup: /system.slice/zigbee2mqtt.service
├─482 npm
├─625 sh -c node index.js
└─626 node index.js
Aug 15 16:29:17 knx npm[482]: Zigbee2MQTT:info 2020-08-15 16:29:17: MQTT publish: topic 'zigbee2mqtt/SensorKids/humidity', payload '62.7
Aug 15 16:29:17 knx npm[482]: Zigbee2MQTT:info 2020-08-15 16:29:17: MQTT publish: topic 'zigbee2mqtt/SensorLiving/humidity', payload '68
Aug 15 16:29:17 knx npm[482]: Zigbee2MQTT:info 2020-08-15 16:29:17: MQTT publish: topic 'zigbee2mqtt/SensorBalcony/humidity', payload '6
Aug 15 16:29:17 knx npm[482]: Zigbee2MQTT:info 2020-08-15 16:29:17: MQTT publish: topic 'zigbee2mqtt/SensorKids/pressure', payload '984.
Aug 15 16:29:17 knx npm[482]: Zigbee2MQTT:info 2020-08-15 16:29:17: MQTT publish: topic 'zigbee2mqtt/SensorLiving/pressure', payload '98
Aug 15 16:29:17 knx npm[482]: Zigbee2MQTT:info 2020-08-15 16:29:17: MQTT publish: topic 'zigbee2mqtt/SensorBalcony/pressure', payload '9
Aug 15 16:29:17 knx npm[482]: Zigbee2MQTT:info 2020-08-15 16:29:17: MQTT publish: topic 'zigbee2mqtt/SensorKids/linkquality', payload '4
Aug 15 16:29:17 knx npm[482]: Zigbee2MQTT:info 2020-08-15 16:29:17: MQTT publish: topic 'zigbee2mqtt/SensorLiving/linkquality', payload
Aug 15 16:29:17 knx npm[482]: Zigbee2MQTT:info 2020-08-15 16:29:17: MQTT publish: topic 'zigbee2mqtt/SensorBalcony/linkquality', payload
Aug 15 16:29:17 knx npm[482]: Zigbee2MQTT:info 2020-08-15 16:29:17: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"version"
SensorLiving,SensorKids,SensorBalcony are the friendly names of devices defined in
/opt/zigbee2mqtt/data/configuration.yaml
All defined items have status NULL and do not get updated
If you see the mistake, for the love of God let me know ![]()
thanks
