Java Runtime Environment: openjdk version “1.8.0_152”
openHAB version: [master]v1.4.1-433(ee99445)
Issue of the topic: Good morning and sorry for my poor english. Ive looked for an answer without luck. Here is my problem…ive a web relay and i can query it with url http://192.168.1.6/status.xml i can see this:
When i activate a light, the btnX go to “dn” state…
Now, for example, i’ve a light called “Luce dell’ingresso” that is activate via manual button also…how can i update the status (icon and state) of this light (btn6) in OH and BasicUI when it change from a normal fisical button?
This is my .sitemap
rule "PT Luce Ingresso transform"
Item PT_Luce_Ingresso_String changed
if ( PT_Luce_Ingresso_String.state == UNDEF !! PT_Luce_Ingresso_String.state == NULL) return;
PT_Luce_Ingresso.postUpdate(transform("MAP", "onoff.map", PT_Luce_Ingresso_String.state.toString)
Many thanks for the reply…ive write your code in my OH and return this error
2018-12-26 22:02:24.353 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'default.rules' has errors, therefore ignoring it: [3,5]: no viable alternative at input 'PT_Luce_Ingresso_String'[5,49]: missing ')' at '!'[5,90]: mismatched input ')' expecting 'end'
In the onoff.map ive wrote
ON=dn
OFF=up
dn=ON
up=OFF
And in http.cfg
# configuration of the first cache item
Domo2.url=http://192.168.1.6/status.xml
Domo2.updateInterval=3000
if (PT_Luce_Ingresso_String.state == UNDEF || PT_Luce_Ingresso_String.state == NULL) return;
PT_Luce_Ingresso.postUpdate(transform("MAP", "onoff.map", PT_Luce_Ingresso_String.state.toString))
Ok ive typed all…there is a missing ) before the end statement…
but, ive this WARN…so is only a warn but i wanto to understand…THANK YOU VERY MUCH!
2018-12-26 22:17:44.004 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'default.rules' has errors, therefore ignoring it: [3,2]: no viable alternative at input 'PT_Luce_Ingresso_String'
Yes…after mod the light dont activate anymore.
I use “Google home” too…the “Switchable” must be in String?
Now my rules is
PT_Luce_Ingresso.postUpdate(transform("MAP","onoff.map",PT_Luce_Ingresso_String.state.toString))
rule "LUCE INGRESSO ON"
Item PT_Luce_Ingresso received command ON
sendHttpGetRequest("http://192.168.1.2:8083/command=set_active?605")
rule "LUCE INGRESSO OFF"
Item PT_Luce_Ingresso received command OFF
sendHttpGetRequest("http://192.168.1.2:8083/command=set_deactive?605")
The LOG is (truncated) [why the sistem doesnt recognize change of state? the String change only this time]
2018-12-26 22:33:22.436 [vent.ItemStateChangedEvent] - PT_Luce_Ingresso_String changed from NULL to up
2018-12-26 22:33:25.660 [ome.event.ItemCommandEvent] - Item 'PT_Luce_Ingresso' received command ON
2018-12-26 22:33:25.682 [vent.ItemStateChangedEvent] - PT_Luce_Ingresso changed from NULL to ON
2018-12-26 22:33:28.441 [ome.event.ItemCommandEvent] - Item 'PT_Luce_Ingresso' received command OFF
2018-12-26 22:33:28.457 [vent.ItemStateChangedEvent] - PT_Luce_Ingresso changed from ON to OFF
Nothing to do…ive tried some change but nothing…cant understand
Ty a lot for your patience
UPDATE…NOW if i activate and deactivate the light from button the LOG write
2018-12-26 22:59:11.204 [vent.ItemStateChangedEvent] - PT_Luce_Ingresso_String changed from up to dn
2018-12-26 22:59:20.405 [vent.ItemStateChangedEvent] - PT_Luce_Ingresso_String changed from dn to up
BEATIFUL…but now why the button on sitemap doesnt activate?
Seems that the rule “LUCE INGRESSO ON” received command but dont execute the “then”
PT_Luce_Ingresso.sendCommand(transform("MAP","onoff.map",PT_Luce_Ingresso_String.state.toString))
The LOG
2018-12-26 23:09:19.443 [ome.event.ItemCommandEvent] - Item 'PT_Luce_Ingresso' received command ON
2018-12-26 23:09:19.459 [vent.ItemStateChangedEvent] - PT_Luce_Ingresso changed from OFF to ON
