Hi all,
Openhab Version
Version: 2.5.0 (Build)
Zwave binding version: 2.5.0
Problem
I’m having issue with the Neo Coolcam Motion detector.
The discovery is succesful. However, I don’t get any motion alarms at all.
I only see the temperature being reported in the logs:
2019-12-30 16:52:23.248 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@7f528085.
2019-12-30 16:53:33.041 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:VERSION)
2019-12-30 16:53:33.041 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 24: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2019-12-30 16:53:33.041 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2019-12-30 16:53:33.041 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 24: Received COMMAND_CLASS_SENSOR_MULTILEVEL V0 SENSOR_MULTILEVEL_REPORT
2019-12-30 16:53:33.042 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 24: Sensor Type = Temperature(1), Scale = 0
2019-12-30 16:53:33.042 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 24: Sensor Value = 24.9
2019-12-30 16:53:33.042 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2019-12-30 16:53:33.042 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_MULTILEVEL, value=24.9
2019-12-30 16:53:33.042 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating channel state zwave:device:3d4427ff:node24:sensor_temperature to 24.9 °C [QuantityType]
2019-12-30 16:53:33.043 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2019-12-30 16:53:33.043 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@29a5df56.
2019-12-30 16:54:40.800 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update received
2019-12-30 16:54:40.802 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update set binding_cmdrepollperiod to 1500 (BigDecimal)
2019-12-30 16:54:40.803 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_11_1 to 1 (BigDecimal)
2019-12-30 16:54:40.803 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_10_1 to 5 (BigDecimal)
2019-12-30 16:54:40.803 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored group_4 to null (null)
2019-12-30 16:54:40.803 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update set group_1 to controller (String)
2019-12-30 16:54:40.803 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Association 1 consolidated to [controller]
2019-12-30 16:54:40.803 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Unknown association group 1
2019-12-30 16:54:40.804 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored group_3 to null (null)
2019-12-30 16:54:40.804 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored group_2 to null (null)
2019-12-30 16:54:40.804 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update set wakeup_node to null (null)
2019-12-30 16:54:40.804 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Error converting wakeup value null
2019-12-30 16:54:40.804 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_12_1 to 1 (BigDecimal)
2019-12-30 16:54:40.804 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_99_2 to 1000 (BigDecimal)
2019-12-30 16:54:40.805 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update set action_failed to false (Boolean)
2019-12-30 16:54:40.805 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored wakeup_interval to 0 (BigDecimal)
2019-12-30 16:54:40.805 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update set action_remove to false (Boolean)
2019-12-30 16:54:40.805 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update set binding_pollperiod to 86400 (BigDecimal)
2019-12-30 16:54:40.805 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Polling initialised at 86400 seconds - start in 76118400 milliseconds.
2019-12-30 16:54:40.805 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update set action_heal to false (Boolean)
2019-12-30 16:54:40.806 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_1_1 to 12 (BigDecimal)
2019-12-30 16:54:40.806 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_7_2 to 180 (BigDecimal)
2019-12-30 16:54:40.806 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_8_1 to 0 (BigDecimal)
2019-12-30 16:54:40.806 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_9_2 to 100 (BigDecimal)
2019-12-30 16:54:40.806 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_2_2 to 30 (BigDecimal)
2019-12-30 16:54:40.806 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_3_1 to 255 (BigDecimal)
2019-12-30 16:54:40.807 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_4_1 to 255 (BigDecimal)
Also, when I want to set association group 1 to controller, it’s not accepted…also in the logs above.
The “thing” looks as follow in habmin:
bit stuck here now…
@chris Maybe I’m doing something wrong?
/Jasper
