Since a couple of years i use a Nest thermorstat in my house. Unfortunately it doens’t work properly in openhab. Mainly due to my ignorance. At this moment i would like to get better with rules, But now no idea where to start
My problem with the nest:
When I use setpoint for changing the temperature i send for every 0.5 degrees a request to the server. Because of that the server gets to much requests and blocks my requests for a while.
My solustion:
Now, I have the idea to make an extra item and a rule that only sends the last input to the nest server,
I haven’t done this before, but it would be simple with an Expire item I think.
You make a proxy item which you will use to control the thermostat from sitemap.
When this item changes, the rule fires and turns on the expiring Item.
When the item expires you send the state of the item to the real nest item.
Example (not tested):
Items:
Number Woonkamer_NEST_Thermostat_SP_Proxy
Switch Thermostat_Timer { expire="10s, command=OFF" }
rules:
rule "Start countdown"
Item Woonkamer_NEST_Thermostat_SP_Proxy changed
Thermostat_Timer.sendCommand(ON)
rule "Send Thermostat data"
Item Thermostat_Timer received command OFF
Woonkamer_NEST_Thermostat_SP.sendCommand(Woonkamer_NEST_Thermostat_SP_Proxy.state)
2019-01-22 09:40:16.259 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Send Thermostat data': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(org.eclipse.smarthome.core.items.Item,java.lang.String) on instance: null
but the idea is great! and simpel
EDIT
Change state.toString solve the error
Thermostat_SP.sendCommand(Woonkamer_NEST_Thermostat_SP_Proxy.state.toString)
