If they really are identical, we can add the ZEN26/ZEN27 deviceType:deviceId to the existing database entries. Otherwise, we’ll need to create new database entries for the ZEN26/ZEN27.
I am honestly not sure what the important parts of the manual for determining this are. They have the same commands for customization (which aren’t in the manuals for the ZEN21 and ZEN22), but do seem to have a difference in the list of “This device requires the following command classes to be supported and
recognized by your Z-Wave controller:”
There are newer manuals here.
What are the parts of these manuals I need to be concerned about for adding to the DB?
Ok, so then there should be new database entries created for these.
The easiest way to get started is to take the relevant node.xml files from the userdata/zwave directory and upload them to the new database entries that you can create following these directions.
Also, it seems like this listing in github is more complete and has the configuration parameters in it, but the database for the ZEN21 does not. I thought I understood that the database was used to update the repository on github, so I am curious why the difference?
As a new user I don’t have permissions to edit the DB. Looks like I can now upload to this community and so I have uploaded the .xml file. node9.xml (7.1 KB)
To use the database you must first register on the site, then email, or open a ticket to have your access updated to allow you to edit the information. Please avoid adding comments to this page to request access.
i got the ZEN27 added to the DB. I was not entirely sure on the Association Groups. I will add the Z26 after I get one installed so that I have the xml file to start with.
Any feedback on what I did wrong when adding that would be appreciated.
It also looks like it will make it into the next version of the binding, which is underway now. I expect the ZEN27 will be in build 1434, so you should be able to test it out by installing the build when it completes.
