Ian_Mellor
(Ian Mellor)
#1
Hi All, I’m new to OpenHAB and I’m trying to write my first rule:
I have bound Philips HUE and the device have been found, items I have added are:
Switch Top_Landing_Presence “Top_Motion” {channel=“hue:0107:001788499314:2:presence”}
Color Top_bulb “Top” {channel=“hue:0210:001788499314:7:color”}
My rule is:
rule "Turn bulb switch on"
Item Top_Landing_Presence changed from off to on
then.
Top_Bulb.sendCommand(On)
However no matter what I have tried, I can’t et the rules to work, can someone point in the right direction please?
Ian
vzorglub
(Vincent Regaud)
#2
Item Top_Landing_Presence changed from OFF to ON
Top_Bulb.sendCommand(ON)
No .
after then
Use OFF
and ON
not off
, on
, or On
Ian_Mellor
(Ian Mellor)
#3
Thank you, I also discovered looking at the log, I had “Top_Bulb” instead of “Top_bulb” that I had defined
vzorglub
(Vincent Regaud)
#4
If you look at the logs live when you save a rules file, it should give some feedback if you have errors…
Good luck
Welcome to OH
