Hey folks,
I am trying to set up a connection from an openhabian Pi4 to a Nibe Heatpump using an RS485 USB adapter and the nibwgw program as supplied by the binding. However, I am getting errors when I try to compile the C-program.
This is a fresh install of OpenHABian 1.6.3 (32-bit) on Raspberry Pi4 Model B.
I did:
gcc -std=gnu99 -o nibegw nibegw.c
And got the warnings/errors:
nibegw.c: In function ‘getTimeStamp’:
nibegw.c:195:7: warning: implicit declaration of function ‘localtime’; did you mean ‘st_atime’? [-Wimplicit-function-declaration]
tm = localtime(&tv.tv_sec);
st_atime
nibegw.c:195:5: warning: assignment to ‘struct tm *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
nibegw.c:198:8: error: dereferencing pointer to incomplete type ‘struct tm’
tm->tm_year + 1900,
I’m afraid, I’m not a C buff, so I’m lost already. Any helpful hints?
Thanks!
