[SOLVED] Nikobus rules not triggered
I have a rules file to sync nikobus items with mios items (switches).
The bindings are ok.
Sync rules (example below) do not run, for none of the defined switches. The log gives nothing indicating that the rule is not triggered?
Any help for this would be welcome. All was working on OH1
Below the state of the items in smarthome:
LP_garage (Type=SwitchItem, State=ON, Label=Licht Garage, Category=null, Groups=[gDashboard, GR_Lichten_Alles, Schakelmodule, PresenceSimulationGroup, R_Lichten_Beneden])
LPgarageStatus (Type=SwitchItem, State=OFF, Label=LP_garage Status, Category=null, Groups=[gVera, GDevices, GRoom10])
Rules file (only 2 switches shown):
    rule "Link LPgarageStatus to LP_garage"
       Item LPgarageStatus changed
          if(LP_garage.state != LPgarageStatus.state && SystemStarting.state == OFF) {
             sendCommand(LP_garage,LPgarageStatus.state.toString())
             logDebug("vera", "Vera switch LPgarageStatus has been synced to state " + LPgarageStatus.state.toString() + " with Nikobus switch LP_garage")
rule "Link LP_garage to LPgarageStatus"
   Item LP_garage changed
then   if(LP_garage.state != LPgarageStatus.state && SystemStarting.state == OFF) {
         sendCommand(LPgarageStatus,LP_garage.state.toString())
         logDebug("vera", "Nikobus switch LP_garage has been synced to state " + LP_garage.state.toString() + " with Vera switch LPgarageStatus")
I’m in the same situation: Nikobus Rule not working
Mine was working too in OH1.
Tonight I will test the feedback with 0H2b5
The rules problem has been fixed. more changes are needed to migrate from OH1 to OH2 than indicated in the documentation.
Changes that were needed:
  1. variable defintion changes from
var java.util.concurrent.locks.ReentrantLock lock = new java.util.concurrent.locks.ReentrantLock()
to
var ReentrantLock lock = new ReentrantLock()
  1. Defining the variables globally does not work. All variables need to be in the “then”-block
Rule working in 1.8.3
import org.openhab.core.types.*
import org.openhab.core.library.types.*
import org.openhab.core.library.items.*
import java.util.concurrent.locks.Lock
import java.util.concurrent.locks.ReentrantLock
import org.openhab.model.script.actions.*
import org.openhab.action.squeezebox.*
import org.openhab.model.script.actions.Timer
import org.joda.time.*
import java.lang.Math
import java.util.Calendar
import java.util.Date
import java.util.TimeZone
import java.text.SimpleDateFormat
import org.openhab.core.persistence.*
import org.openhab.core.library.types.PercentType
import org.openhab.core.library.items.SwitchItem
import java.util.HashMap
import java.util.LinkedHashMap
import java.util.ArrayList
import java.util.Map
import org.eclipse.xtext.xbase.lib.*
   lock.lock()
   try {
         LP_garage.sendCommand(LPgarageStatus.state.toString())
} finally{
   lock.unlock()
Rule adapted and working in OH2B5
rule "Link LPgarageStatus to LPgarage"
   lock.lock()
   try {
      if(LPgarage.state != LPgarageStatus.state && SystemStarting.state == OFF) {
         LPgarage.sendCommand(LPgarageStatus.state.toString())
         logDebug("vera", "Vera switch LPgarageStatus has been synced to state " + LPgarageStatus.state.toString() + " with Nikobus switch LPgarage")
} finally{
   lock.unlock()
