[SOLVED] No access to Karaf Console remotely using putty
I have upgraded OH to version 2.2.
Since upgrading I don’t seem to be able to ssh into the karafe console using localhost:8081 using putty.
Network error: Connection refused
I can, however, log in to karafe console from a terminal window from within raspbian using:
ssh -p 8101 openhab@localhost
Any ideas how I can diagnose what is happening?
have a look at the docs https://docs.openhab.org/administration/console.html#bind-console-to-all-interfaces
also if you accessing karaf from another machine you need to use the ip or hostname of your OH machine not localhost
edit: 2023-02-03: the link changed. this is the new one: The Console | openHAB
Excellent, thankyou!!
Problem solved :slight_smile:
