What does the event log say? On a new installation you should see lines like this:
2019-12-20 15:09:39.966 [thome.event.ExtensionEvent] - Extension 'package-standard' has been installed.
2019-12-20 15:09:53.844 [thome.event.ExtensionEvent] - Extension 'ui-homebuilder' has been installed.
2019-12-20 15:09:53.846 [thome.event.ExtensionEvent] - Extension 'ui-basic' has been installed.
2019-12-20 15:09:53.848 [thome.event.ExtensionEvent] - Extension 'ui-habpanel' has been installed.
2019-12-20 15:09:53.849 [thome.event.ExtensionEvent] - Extension 'ui-paper' has been installed.
2019-12-20 15:09:58.300 [thome.event.ExtensionEvent] - Extension 'ui-dashboard' has been uninstalled.
This is the only *.log in my SD.
I can not open anythings else.
2019-07-10_01:21:56_BST [openHABian] Starting the openHABian initial setup.
2019-07-10_01:21:57_BST [openHABian] Storing configuration… OK
2019-07-10_01:21:59_BST [openHABian] Starting webserver with installation log… OK
2019-07-10_01:22:07_BST [openHABian] Changing default username and password… OK
2019-07-10_01:22:50_BST [openHABian] Setting up Wi-Fi connection… OK, rebooting…
2019-07-10_01:23:09_BST [openHABian] Starting the openHABian initial setup.
2019-07-10_01:23:09_BST [openHABian] Storing configuration… OK
2019-07-10_01:23:09_BST [openHABian] Starting webserver with installation log… OK
2019-07-10_01:23:14_BST [openHABian] Changing default username and password… SKIPPED
2019-07-10_01:23:14_BST [openHABian] Setting up Wi-Fi connection… OK
2019-07-10_01:23:18_BST [openHABian] Ensuring network connectivity… OK
2019-07-10_01:23:18_BST [openHABian] Waiting for dpkg/apt to get ready… OK
2019-12-22_11:27:17_GMT [openHABian] Updating repositories and upgrading installed packages… OK
2019-12-22_11:36:06_GMT [openHABian] Installing git package… OK
2019-12-22_11:37:05_GMT [openHABian] Cloning myself… OK
2019-12-22_11:37:12_GMT [openHABian] Executing ‘openhabian-setup.sh unattended’…
2019-12-22_11:37:12_GMT [openHABian] Checking for root privileges… OK
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Reading package lists…
2019-12-22_11:37:28_GMT [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2019-12-22_11:37:28_GMT [openHABian] Setting timezone based on IP geolocation… OK (Europe/Amsterdam)
2019-12-22_12:39:20_CET [openHABian] Setting locale based on openhabian.conf… OK
2019-12-22_12:41:22_CET [openHABian] Setting hostname of the base system… OK
2019-12-22_12:41:22_CET [openHABian] Setting the GPU memory split down to 16MB for headless system… OK
2019-12-22_12:41:22_CET [openHABian] Enabling Audio output… OK
2019-12-22_12:41:23_CET [openHABian] Installing basic can’t-be-wrong packages (screen, vim, …)… OK
2019-12-22_12:42:55_CET [openHABian] Installing additional needed packages… OK
2019-12-22_12:43:45_CET [openHABian] Installing additional bluetooth packages… OK
2019-12-22_12:44:46_CET [openHABian] Adding slightly tuned bash config files to system… OK
2019-12-22_12:44:46_CET [openHABian] Adding slightly tuned vim config file to system… OK
2019-12-22_12:44:46_CET [openHABian] Downloading and setting up FireMotD… OK
2019-12-22_12:47:29_CET [openHABian] Installing Java Zulu 32-Bit OpenJDK… OK
2019-12-22_12:49:28_CET [openHABian] Installing or upgrading to latest openHAB release (stable)… OK
2019-12-22_12:51:03_CET [openHABian] Adding an openHAB dashboard tile for ‘openhabiandocs’… OK
2019-12-22_12:51:04_CET [openHABian] Adding openHAB syntax to vim editor… OK
2019-12-22_12:51:04_CET [openHABian] Adding openHAB syntax to nano editor… OK
2019-12-22_12:51:05_CET [openHABian] Adding openHAB scheme to multitail… OK
2019-12-22_12:51:05_CET [openHABian] Preparing openHAB folder mounts under /srv/… OK
2019-12-22_12:51:05_CET [openHABian] Applying file permissions recommendations… OK
2019-12-22_12:51:10_CET [openHABian] Applying miscellaneous system settings… Creating persistent systemd journal folder location: /var/log/journal
Keeping at most 30 days of systemd journal entries
Deleted archived journal /run/log/journal/29ed9ca737794908b11ff5a5c001beaa/system@0ef8772c8ba443e59eb081ebcee3188d-0000000000000001-00058d48ad96fc5f.journal (5.7M).
Vacuuming done, freed 5.7M of archived journals from /run/log/journal/29ed9ca737794908b11ff5a5c001beaa.
OK
2019-12-22_12:51:10_CET [openHABian] Setting up Samba network shares… OK
2019-12-22_12:53:09_CET [openHABian] Installing Node.js for arm (prerequisite for other packages)… OK
2019-12-22_12:53:41_CET [openHABian] Installing the openHAB Log Viewer (frontail) relative to nodejs base /usr/lib… OK
2019-12-22_12:54:37_CET [openHABian] Adding an openHAB dashboard tile for ‘frontail’… OK
2019-12-22_12:54:38_CET [openHABian] Execution of ‘openhabian-setup.sh unattended’ completed.
2019-12-22_12:54:38_CET [openHABian] Waiting for openHAB to become ready…1…2…3…4…5…6…7…8…OK
2019-12-22_12:55:59_CET [openHABian] Visit the openHAB dashboard now: http://openhab:8080
2019-12-22_12:55:59_CET [openHABian] To gain access to a console, simply reconnect.
2019-12-22_12:55:59_CET [openHABian] First time setup successfully finished.
There should be log files in /var/log/openhab2/ Here is the listing from my recent openHABian image installation. events.log and openhab.log are the main files of interest.
openhabian@openhab:~$ cd /var/log/openhab2/
openhabian@openhab:/var/log/openhab2$ ls -l
total 12
-rw-rw-r-- 1 openhab openhab 0 Dec 20 15:08 audit.log
-rw-rw-r-- 1 openhab openhab 3702 Dec 21 14:44 events.log
-rw-rw-r-- 1 openhab openhab 7941 Dec 21 14:44 openhab.log
-rwxrwxr-x 1 openhab openhab 0 Dec 15 17:56 Readme.txt
Likely, you did not wait long enough. The log you posted was just for initially installing and starting OpenHAB. It then needs to download and install addons such as Basic UI and Paper UI.
