Hello Community,
I have an issue with openhab2 / KNX that I have been puzzling for several days now. I hope someone can point me in the right direction.
I use openHAB already for 3 or 4 years. For me it is a very good solution that is becoming better with every new version. I especially use it for controlling my KNX installation. OpenHAB, actually OpenHABian runs an a Raspberry (version 3 now). Everything works fine, but since the last upgrade I have a problem.
I have an alarm unit. When I activate the alarm the unit sends a telegram on the KNX-bus (0/1/0 with value [0]). The KNX installation response to this telegram by switching off all the lights.
When there is an actual alarm (burglary or fire) the alarm unit sends a telegram (0/1/0 with value [1]) and all the lights go on.
In openHAB I wish to know the state and control the lights. In openHAB 2.2 I had an item defined:
Switch Groep_Licht_Woning (Groepen) {knx = "0/1/0"}
This switch is visible in the sitemap. This also gives me the possibility to switch off all the lights in case of a false alarm that did all the lights go on. In openHAB 2.2 this worked fine.
In openHAB 2.4 I need to have a thing and an item:
Thing : Type switch : Groep_Licht_Woning … [ ga="0/1/0" ]
Item : Switch Groep_Licht_Woning (Groepen) channel="knx:device:bridge:generic:Groep_Licht_Woning"}
And again there is the switch in the sitemap. Again I can switch all the lights on/off with this switch. But when I use the alarm unit now the action it is unnoticed by openHAB. I have looked in the KNX logging (tracing) and the KNX messages are the same using the switch or the alarm unit. Also ETS shows the same telegrams for both situations.
The event logging however is different. When I use the switch in the sitemap, I see a message like “Groep_Licht_Woning changed from ON to OFF” or “Item ‘Groep_Licht_Woning’ received command ON”; and the switch does response well to this incident. But when I used the panel of the alarm unit to activate there is no message about Groep_Licht_Woning.
What am I missing?
Thanks in advance for any response.
