[SOLVED] Null Exception when starting Google Text-to-Speech Service
I’ve pretty much exhausted all of the threads I could find on setting up google text to speech. I am running OH2 2.5.0-M1 stable on a linux server, I’ve got JRE 11 (x64), and have an otherwise very reliable and stable OH2 setup.
I followed all of the instructions regarding setting up Google Cloud platform, have verified that the google TTS service has billing enabled, properly copied and pasted the contents of the .json key file into the Google TTS configuration page on Paper UI. When I do that, and I look at the log, I see a lot of red going by, and can’t make heads or tails of it. I enabled TRACE logging and have copied what appears to be the related logs here:
2019-04-30 17:45:59.178 [ERROR] [org.openhab.voice.googletts         ] - bundle org.openhab.voice.googletts:2.5.0.M1 (230)[org.openhab.voice.googletts.internal.GoogleTTSService(255)] : The activate method has thrown an exception
	at org.openhab.voice.googletts.internal.GoogleCloudAPI.listVoices(GoogleCloudAPI.java:250) ~[?:?]
	at org.openhab.voice.googletts.internal.GoogleCloudAPI.initVoices(GoogleCloudAPI.java:222) ~[?:?]
	at org.openhab.voice.googletts.internal.GoogleCloudAPI.setConfig(GoogleCloudAPI.java:146) ~[?:?]
	at org.openhab.voice.googletts.internal.GoogleTTSService.updateConfig(GoogleTTSService.java:215) ~[?:?]
	at org.openhab.voice.googletts.internal.GoogleTTSService.activate(GoogleTTSService.java:122) ~[?:?]
	at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:341) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:983) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:956) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:901) [39:org.apache.felix.scr:2.1.14]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
	at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
	at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry$1.run(ServiceRegistry.java:805) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry$1.run(ServiceRegistry.java:1) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:803) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.AbstractExtender.addingBundle(AbstractExtender.java:139) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.AbstractExtender.addingBundle(AbstractExtender.java:49) [39:org.apache.felix.scr:2.1.14]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469) [?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415) [?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:124) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:1) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:122) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
	at org.eclipse.osgi.container.Module.doStart(Module.java:578) [?:?]
	at org.eclipse.osgi.container.Module.start(Module.java:449) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) [?:?]
	at org.apache.karaf.bundle.command.Restart.doExecute(Restart.java:51) [42:org.apache.karaf.bundle.core:4.2.2]
	at org.apache.karaf.bundle.command.BundlesCommand.execute(BundlesCommand.java:55) [42:org.apache.karaf.bundle.core:4.2.2]
	at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84) [14:org.apache.karaf.shell.core:4.2.2]
	at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68) [14:org.apache.karaf.shell.core:4.2.2]
	at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86) [14:org.apache.karaf.shell.core:4.2.2]
	at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599) [14:org.apache.karaf.shell.core:4.2.2]
	at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526) [14:org.apache.karaf.shell.core:4.2.2]
	at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415) [14:org.apache.karaf.shell.core:4.2.2]
	at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416) [14:org.apache.karaf.shell.core:4.2.2]
	at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229) [14:org.apache.karaf.shell.core:4.2.2]
	at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59) [14:org.apache.karaf.shell.core:4.2.2]
2019-04-30 17:45:59.263 [INFO ] [.googletts.internal.GoogleTTSService] - Using cache folder /var/lib/openhab2/cache/org.openhab.voice.googletts
2019-04-30 17:45:59.256 [WARN ] [org.openhab.voice.googletts         ] - FrameworkEvent WARNING - org.openhab.voice.googletts
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
	at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry$1.run(ServiceRegistry.java:805) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry$1.run(ServiceRegistry.java:1) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:803) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) ~[?:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) ~[?:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) ~[?:?]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) ~[?:?]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.addingBundle(AbstractExtender.java:139) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.addingBundle(AbstractExtender.java:49) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:124) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:1) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:122) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
	at org.eclipse.osgi.container.Module.doStart(Module.java:578) ~[?:?]
	at org.eclipse.osgi.container.Module.start(Module.java:449) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
	at org.apache.karaf.bundle.command.Restart.doExecute(Restart.java:51) ~[?:?]
	at org.apache.karaf.bundle.command.BundlesCommand.execute(BundlesCommand.java:55) ~[?:?]
	at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84) ~[?:?]
	at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68) ~[?:?]
	at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86) ~[?:?]
	at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599) ~[?:?]
	at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526) ~[?:?]
	at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415) ~[?:?]
	at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416) ~[?:?]
	at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229) ~[?:?]
	at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
	at java.lang.Thread.run(Thread.java:834) ~[?:?]
2019-04-30 17:46:00.009 [INFO ] [g.eclipse.smarthome.model.script.APC] - RULE FIRED: Update APC Parameters (Every min)
2019-04-30 17:46:00.037 [INFO ] [.eclipse.smarthome.model.script.TIME] - RULE FIRED: Update System DateTimes (Every min)
2019-04-30 17:46:00.050 [ERROR] [org.openhab.voice.googletts         ] - bundle org.openhab.voice.googletts:2.5.0.M1 (230)[org.openhab.voice.googletts.internal.GoogleTTSService(255)] : The activate method has thrown an exception
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:73) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1805) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:436) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:302) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [39:org.apache.felix.scr:2.1.14]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [39:org.apache.felix.scr:2.1.14]
2019-04-30 17:46:00.354 [INFO ] [clipse.smarthome.model.script.SYSTEM] - RULE FIRED: Check Internet Connection (Every 30 sec) [UP, 70 ms, www.google.com]
2019-04-30 17:46:00.199 [WARN ] [org.openhab.voice.googletts         ] - FrameworkEvent WARNING - org.openhab.voice.googletts
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:73) ~[?:?]
	at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1805) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:436) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:302) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) ~[?:?]
After accomplishing all of this, when I go to Paper UI>Configuration>System>Voice, I do have a dropdown for default Text to Speech service, but it simply says “Google Cloud” (other examples I’ve seen are more specific/different, and there are no selections availble in the voice droppdown.
I’m putting my TTS work on hold until I hear back, I’m spending way too much time in front of the computer!
Thanks…
I solved it… I thought I had enabled the Google Text to Speech API in the Google Cloud Platform, but I hadn’t quite done it.
The “Before you begin” section of this link is very helpful.
Cheers!
YOU ARE A LIFESAVER!
The Openhab documentation says to paste a JSON file, however, if you paste the Json config file that you create when you setup an OAUTH ID, it doesn’t work. You have to create a Service Key and use that JSON file to get it working.
Here is the link to create the JSON file that you need to plug into PaperUI.
Go to the Create Service Account Key page
