Hello guys,
I have a problem:
I want to run this command “upsc ups@IP-NutServer” and split the Output to different Items.
This is for example the Output:
Init SSL without certificate database
battery.charge: 100
battery.charge.low: 10
battery.charge.warning: 50
battery.date: not set
battery.mfr.date: 2019/04/25
battery.runtime: 2302
battery.runtime.low: 120
battery.type: PbAc
battery.voltage: 13.6
battery.voltage.nominal: 12.0
device.mfr: APC
device.model: Back-UPS ES 700G
device.serial: XXXXXXXXXX
device.type: ups
driver.name: usbhid-ups
driver.parameter.pollfreq: 30
driver.parameter.pollinterval: 5
driver.parameter.port: auto
driver.version: XXXXXXXXX
driver.version.data: APC HID 0.95
driver.version.internal: 0.38
input.sensitivity: medium
input.transfer.high: 266
input.transfer.low: 180
input.voltage: 238.0
input.voltage.nominal: 230
ups.beeper.status: enabled
ups.delay.shutdown: 20
ups.firmware: 871.O4 .I
ups.firmware.aux: O4
ups.load: 0
ups.mfr: APC
ups.mfr.date: 2019/04/25
ups.model: Back-UPS ES 700G
ups.productid: 0000
ups.serial: XXXXXXX
ups.status: OL
ups.timer.reboot: 0
ups.timer.shutdown: -1
ups.vendorid: 00XX0
Now i want to transfer every single value like “Back-UPS ES 700G” or “medium” to different OpenHab Items
This is my Items-File:
Number USV_APC_BattProz "Akku: [%.1f %%]" <battery> (influx)
Number USV_APC_BattLowProz "Akku Low bei: [%.1f %%]" <battery>
Number USV_APC_BattWarnProz "Akku Warn bei: [%.1f %%]" <battery>
String USV_APC_BattManFacDate "Akku Herstellungsdat: [%s]" <calendar>
Number USV_APC_BattRuntime "Akku Laufzeit: [%.1f s]" <clock> (influx)
Number USV_APC_BattRuntimeLow "Akku Runt Low: [%.1f s]" <clock>
String USV_APC_BattType "Akkutyp: [%s]" <battery>
Number USV_APC_BattVolt "Akkuspng: [%.1f V]" <battery> (influx)
Number USV_APC_BattVoltNorm "Akkuspng Normal: [%.1f V]" <battery>
String USV_APC_DevMfr "Hersteller: [%s]" <battery>
String USV_APC_DevModel "Model: [%s]" <battery>
String USV_APC_DevSerNr "Seriennummer: [%s]" <battery>
String USV_APC_DevTyp "Typ: [%s]" <battery>
String USV_APC_DriverName "Treibername: [%s]" <battery>
Number USV_APC_DriverPollFr "Pollfreq: [%s]" <clock>
Number USV_APC_DriverPollInt "Pollinter: [%s]" <clock>
String USV_APC_DriverPort "Port: [%s]" <battery>
String USV_APC_DriverVers "Treibervers: [%s]" <battery>
String USV_APC_DriverData "Treiberdata: [%s]" <battery>
String USV_APC_DriverVersInt "Treibervers intern: [%s]" <battery>
String USV_APC_InpSens "Eingangssensib: [%s]" <battery>
Number USV_APC_InpTransH "Eingangsspng High: [%.1f V]" <battery>
Number USV_APC_InpTransL "Eingangsspng Low: [%.1f V]" <battery>
Number USV_APC_InpVolt "Eingangsspng: [%.1f V]" <battery>
Number USV_APC_InpVoltNorm "Eingangsspng Normal: [%.1f V]" <battery>
String USV_APC_UpsBeep "Piepser: [%s" <battery>
Number USV_APC_UpsShutdDelay "Herunterfahrverzö: [%.1f s]" <battery>
String USV_APC_UpsFirmware "Firmware: [%s]" <battery>
String USV_APC_UpsFirmwareAux "Firmware Aux: [%s]" <battery>
Number USV_APC_UpsLoad "Last: [%.1f W]" <light>
String USV_APC_UpsMfr "Ups Hersteller: [%s]" <battery>
String USV_APC_UpsManFacDate "Ups Herstellungsdat: [%s]" <battery>
String USV_APC_UpsModel "Ups Model: [%s]" <battery>
String USV_APC_UpsProductId "Ups Product Id: [%s]" <battery>
String USV_APC_UpsSerNr "Ups Seriennummer: [%s]" <battery>
String USV_APC_UpsStatus "Ups Status: [%s]" <battery>
Number USV_APC_UpsTimerReboot "Ups Timer Reboot: [%.1f s]" <battery>
Number USV_APC_UpsTimerShutdown "Ups Timer Shutdown: [%.1f s]" <battery>
String USV_APC_UpsVendorId "Ups Vendor Id: [%s]" <battery>
And my Rules -File:
rule "Alle 20 Sekunden UPS Status abfragen und auswerten"
Time cron "0/20 * * ? * * *"
var String CommandOutput = executeCommandLine("upsc ups@IP-NutServer", 120*1000)
if (CommandOutput.startsWith("Init SSL")) {
var String[] results = CommandOutput.split("\\r?\\n")
var Arg0 = results.get(0).split(" ").get(1)
var Arg1 = results.get(1).split(" ").get(2)
var Arg2 = results.get(2).split(" ").get(1)
var Arg3 = results.get(3).split(" ").get(1)
var Arg4 = results.get(4).split(" ").get(1)
var Arg5 = results.get(5).split(" ").get(1)
var Arg6 = results.get(6).split(" ").get(1)
var Arg7 = results.get(7).split(" ").get(1)
var Arg8 = results.get(8).split(" ").get(1)
var Arg9 = results.get(9).split(" ").get(1)
var Arg10 = results.get(10).split(" ").get(1)
var Arg11 = results.get(11).split(" ").get(1)
var Arg12 = results.get(12).split(" ").get(1)
var Arg13 = results.get(13).split(" ").get(1)
var Arg14 = results.get(14).split(" ").get(1)
var Arg15 = results.get(15).split(" ").get(1)
var Arg16 = results.get(16).split(" ").get(1)
var Arg17 = results.get(17).split(" ").get(1)
var Arg18 = results.get(18).split(" ").get(1)
var Arg19 = results.get(19).split(" ").get(1)
var Arg20 = results.get(20).split(" ").get(1)
var Arg21 = results.get(21).split(" ").get(1)
var Arg22 = results.get(22).split(" ").get(1)
var Arg23 = results.get(23).split(" ").get(1)
var Arg24 = results.get(24).split(" ").get(1)
var Arg25 = results.get(25).split(" ").get(1)
var Arg26 = results.get(26).split(" ").get(1)
var Arg27 = results.get(27).split(" ").get(1)
var Arg28 = results.get(28).split(" ").get(1)
var Arg29 = results.get(29).split(" ").get(1)
var Arg30 = results.get(30).split(" ").get(1)
var Arg31 = results.get(31).split(" ").get(1)
var Arg32 = results.get(32).split(" ").get(1)
var Arg33 = results.get(33).split(" ").get(1)
var Arg34 = results.get(34).split(" ").get(1)
var Arg35 = results.get(35).split(" ").get(1)
var Arg36 = results.get(36).split(" ").get(1)
var Arg37 = results.get(37).split(" ").get(1)
var Arg38 = results.get(38).split(" ").get(1)
var Arg39 = results.get(39).split(" ").get(1)
USV_APC_BattProz.sendCommand(Arg1)
USV_APC_BattLowProz.sendCommand(Arg2)
USV_APC_BattWarnProz.sendCommand(Arg3)
USV_APC_BattManFacDate.sendCommand(Arg4)
USV_APC_BattRuntime.sendCommand(Arg5)
USV_APC_BattRuntimeLow.sendCommand(Arg6)
USV_APC_BattType.sendCommand(Arg7)
USV_APC_BattVolt.sendCommand(Arg8)
USV_APC_BattVoltNorm.sendCommand(Arg9)
USV_APC_DevMfr.sendCommand(Arg10)
USV_APC_DevModel.sendCommand(Arg11)
USV_APC_DevSerNr.sendCommand(Arg12)
USV_APC_DevTyp.sendCommand(Arg13)
USV_APC_DriverName.sendCommand(Arg14)
USV_APC_DriverPollFr.sendCommand(Arg15)
USV_APC_DriverPollInt.sendCommand(Arg16)
USV_APC_DriverPort.sendCommand(Arg17)
USV_APC_DriverVers.sendCommand(Arg18)
USV_APC_DriverData.sendCommand(Arg19)
USV_APC_DriverVersInt.sendCommand(Arg20)
USV_APC_InpSens.sendCommand(Arg21)
USV_APC_InpTransH.sendCommand(Arg22)
USV_APC_InpTransL.sendCommand(Arg23)
USV_APC_InpVolt.sendCommand(Arg24)
USV_APC_InpVoltNorm.sendCommand(Arg25)
USV_APC_UpsBeep.sendCommand(Arg26)
USV_APC_UpsShutdDelay.sendCommand(Arg27)
USV_APC_UpsFirmware.sendCommand(Arg28)
USV_APC_UpsFirmwareAux.sendCommand(Arg29)
USV_APC_UpsLoad.sendCommand(Arg30)
USV_APC_UpsMfr.sendCommand(Arg31)
USV_APC_UpsManFacDate.sendCommand(Arg32)
USV_APC_UpsModel.sendCommand(Arg33)
USV_APC_UpsProductId.sendCommand(Arg34)
USV_APC_UpsSerNr.sendCommand(Arg35)
USV_APC_UpsStatus.sendCommand(Arg36)
USV_APC_UpsTimerReboot.sendCommand(Arg37)
USV_APC_UpsTimerShutdown.sendCommand(Arg38)
USV_APC_UpsVendorId.sendCommand(Arg39)
But it’s not working.
Can someone help me with this Problem? Thanks!
