I’m running OH 2.4 (openhabian) on an RPi3 and since the upgrade, I keep getting these errors in the log every minute or so:
2018-12-26 18:07:13.081 [INFO ] [internal.service.FeaturesServiceImpl] - No deployment change.
2018-12-26 18:07:13.086 [INFO ] [internal.service.FeaturesServiceImpl] - Stopping bundles:
2018-12-26 18:07:13.092 [INFO ] [internal.service.FeaturesServiceImpl] - swagger-jersey2-jaxrs/1.5.8.v20160511-1038
2018-12-26 18:07:13.111 [INFO ] [internal.service.FeaturesServiceImpl] - reflections/0.9.10.v20160429-1435
2018-12-26 18:07:13.140 [INFO ] [internal.service.FeaturesServiceImpl] - io.swagger.jaxrs/1.5.8
2018-12-26 18:07:13.157 [INFO ] [internal.service.FeaturesServiceImpl] - com.eclipsesource.jaxrs.provider.swagger/1.1.1.201605111122
2018-12-26 18:07:13.319 [INFO ] [internal.service.FeaturesServiceImpl] - Refreshing bundles:
2018-12-26 18:07:13.322 [INFO ] [internal.service.FeaturesServiceImpl] - com.eclipsesource.jaxrs.provider.swagger/1.1.1.201605111122 (Wired to io.swagger.jaxrs/1.5.8 which is being refreshed)
2018-12-26 18:07:13.324 [INFO ] [internal.service.FeaturesServiceImpl] - io.swagger.jaxrs/1.5.8 (Wired to reflections/0.9.10.v20160429-1435 which is being refreshed)
2018-12-26 18:07:13.326 [INFO ] [internal.service.FeaturesServiceImpl] - reflections/0.9.10.v20160429-1435 (Should be wired to: com.google.guava/18.0.0 (through [reflections/0.9.10.v20160429-1435] osgi.wiring.package; resolution:=optional; filter:="(osgi.wiring.package=com.google.common.base)"))
2018-12-26 18:07:13.328 [INFO ] [internal.service.FeaturesServiceImpl] - swagger-jersey2-jaxrs/1.5.8.v20160511-1038 (Wired to io.swagger.jaxrs/1.5.8 which is being refreshed)
2018-12-26 18:07:13.836 [INFO ] [internal.service.FeaturesServiceImpl] - Done.
2018-12-26 18:07:15.365 [INFO ] [javassist ] - FrameworkEvent INFO - javassist
When this occurs, devices do not respond to command for a minute or so. Also, when devices do work, there is a very large latency before a device will respond to a command, up to 10 seconds. Devices that are directly associated with another behave well, but anything controlled via rules is very slow. I added a log state to a couple of rules and when the rule is triggered, it is logged almost immediately, but the device will not respond for quite some time.
I’ve stopped OH and cleared the cache and restarted, but the behavior is the same.
Any ideas?
