[SOLVED] OH 2.4 S1434 & ZWave Error
just upgraded my OH 2.4 from M6 to S1434 (with 2.4.0.201811202338 org.openhab.binding.zwave) and I am getting the following error in openhab.log:
2018-11-21 15:32:42.582 [ERROR] [ig.xml.osgi.XmlDocumentBundleTracker] - Could not send adding finished event for the module 'org.openhab.binding.zwave'!
java.lang.IllegalArgumentException: The label must neither be null nor empty.
	at org.eclipse.smarthome.core.thing.type.ThingTypeBuilder.build(ThingTypeBuilder.java:120) ~[?:?]
	at org.eclipse.smarthome.core.thing.xml.internal.ThingTypeXmlResult.toThingType(ThingTypeXmlResult.java:153) ~[?:?]
	at org.eclipse.smarthome.core.thing.xml.internal.ThingTypeXmlProvider.addingFinished(ThingTypeXmlProvider.java:148) ~[?:?]
	at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.addingFinished(XmlDocumentBundleTracker.java:217) [100:org.eclipse.smarthome.config.xml:0.10.0.201811171951]
	at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.parseDocuments(XmlDocumentBundleTracker.java:359) [100:org.eclipse.smarthome.config.xml:0.10.0.201811171951]
	at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.processBundle(XmlDocumentBundleTracker.java:337) [100:org.eclipse.smarthome.config.xml:0.10.0.201811171951]
	at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.access$4(XmlDocumentBundleTracker.java:332) [100:org.eclipse.smarthome.config.xml:0.10.0.201811171951]
	at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker$2.run(XmlDocumentBundleTracker.java:307) [100:org.eclipse.smarthome.config.xml:0.10.0.201811171951]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
similar case to OH2.2 S1133 & ZWave Error
@chris
When does this occur? At startup?
yes. only on startup
functionality is not affected
all Z-Wave nodes are operating normally
i think that some info in the xml db are wrong… not a big problem
Maybe there’s been a change to ESH to add more checking and make certain things “illegal” - this happens periodically.
I think if you enable trace, or even debug logging, it should show the list of files being read so we can find out what the device is that has the problem. Once I know this a) I can fix it, and b) I will add a check to the database so that these are listed so people can fix them before they are released :slight_smile:
not much in TRACE log…
2018-11-21 17:22:49.688 [DEBUG] [org.openhab.binding.zwave           ] - BundleEvent [unknown:512] - org.openhab.binding.zwave
2018-11-21 17:22:49.712 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.usbserial.UsbSerialDiscoveryParticipant}={service.id=121, service.bundleid=240, service.scope=bundle, component.name=org.openhab.binding.zwave.discovery.ZWaveUsbSerialDiscoveryParticipant, component.id=21} - org.openhab.binding.zwave
2018-11-21 17:22:49.721 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=122, service.bundleid=240, service.scope=bundle, component.name=org.openhab.binding.zwave.internal.ZWaveHandlerFactory, component.id=25} - org.openhab.binding.zwave
2018-11-21 17:22:49.722 [DEBUG] [org.openhab.binding.zwave           ] - BundleEvent STARTING - org.openhab.binding.zwave
2018-11-21 17:22:49.724 [DEBUG] [inding.zwave.internal.ZWaveActivator] - Z-Wave binding started. Version 2.4.0.201811202338
2018-11-21 17:22:49.725 [DEBUG] [org.openhab.binding.zwave           ] - BundleEvent STARTED - org.openhab.binding.zwave
2018-11-21 17:22:52.528 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.events.EventFactory}={service.id=182, service.bundleid=240, service.scope=bundle, component.name=org.openhab.binding.zwave.event.BindingEventFactory, component.id=22} - org.openhab.binding.zwave
2018-11-21 17:22:53.422 [DEBUG] [org.openhab.binding.zwave           ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.ConfigDescriptionProvider, org.eclipse.smarthome.config.core.ConfigOptionProvider}={service.id=236, service.bundleid=240, service.scope=bundle, component.name=org.openhab.binding.zwave.internal.ZWaveConfigProvider, component.id=23} - org.openhab.binding.zwave
2018-11-21 17:22:55.994 [ERROR] [ig.xml.osgi.XmlDocumentBundleTracker] - Could not send adding finished event for the module 'org.openhab.binding.zwave'!
(from startup to error)
It happens at the very beginning of OH2 (6 secs after startup)
ooops… TRACE on the wrong bundle :slight_smile: org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker is the correct one
restarting now
@chris here is the trace… I can’t identify the offending xml :frowning:
openhab.log (536.1 KB)
I think I’ve found the issue. I’ll do a database update shortly…
confirming issue fix on openHAB 2.4.0 Build #1436
thanx @chris !
Thanks.
