Yes things were added.
I did a thing search but no result.
I added the things manually, here is my conf file:
Bridge mysensors:bridge-ser:gateway [ serialPort=“/dev/ttyAMA0”, sendDelay=50, startupCheckEnabled=false, baudRate=115200] {
door door02 [ nodeId=20, childId=3 ]
log results when added the node:
[hingStatusInfoChangedEvent] - ‘mysensors:door:gateway:door02’ changed from UNINITIALIZED to INITIALIZING
[DEBUG] [ensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=20, childId=3, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
[DEBUG] [rs.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=20, childNumber=1, chidldList={3=MySensorsChild [childId=3, nodeValue={V_VAR4=MySensorsVariableVVar4 [value=null], V_TRIPPED=MySensorsVariableVTripped [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_ARMED=MySensorsVariableVArmed [value=null], V_VAR5=MySensorsVariableVVar5 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null]}]}]
[DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 20-3 not registered yet, registering…
2019-09-09 19:56:56.797 [hingStatusInfoChangedEvent] - ‘mysensors:door:gateway:door02’ changed from INITIALIZING to ONLINE
The door switch also carries nodeID 20 and childID 3.
no message coming in…
