I currently have OH2.0 running on an Ubuntu 14.4 VM. I’ve been a user since OH1.8, and have been using 2.0 for a couple years so this isn’t my first rodeo. However, I still consider myself a beginner, especially on the Linux end of things (it and I seem to have a hate-hate relationship). I have a few quirky issues and was looking to finally upgrade to 2.3 and upgrade Ubuntu at the same time.
Instead of upgrading my existing system, I’ve created a new VM and have 18.4 installed and running. Have Oracle Java 1.8.0_181-b13 installed and successfully registered (shows using java -version). I want to get this new VM up and running well and then I’ll make the switch from the old to new for daily use.
Installed OH2.3 and copied over all the configurations from my other system to this one as per:
Backing/Restoring up openHAB2.x
I’m sure I got my cart ahead of the horse partly there, but I don’t think it’s my current issue. I may be wrong… If I need to, I can blow this out and revert to default if need be (going to be my next step unless someone has any other bright ideas).
When I start the OH2 service and then run ‘systemctl status openhab2.service’, I get:
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Sat 2018-09-22 23:34:56 CDT; 1s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 2725 ExecStart=/usr/share/openhab2/runtime/bin/karaf $OPENHAB_STARTMODE (code=exited, status=255)
Main PID: 2725 (code=exited, status=255)
Sep 22 23:34:56 Server-Linux18 systemd[1]: openhab2.service: Main process exited, code=exited, status=255/n/a
Sep 22 23:34:56 Server-Linux18 systemd[1]: openhab2.service: Failed with result 'exit-code'.
Went to /usr/share/openhab2 and ran ‘bash start_debug.sh’ and I got:
Launching the openHAB runtime...
Listening for transport dt_socket at address: 5005
Unable to update instance pid: /var/lib/openhab2/tmp/instances/instance.properties (Permission denied)
java.lang.RuntimeException: /var/log/openhab2/openhab.log (Permission denied)
at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlerInternal(BootstrapLogManager.java:102)
at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlersInternal(BootstrapLogManager.java:137)
at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlers(BootstrapLogManager.java:70)
at org.apache.karaf.main.util.BootstrapLogManager.configureLogger(BootstrapLogManager.java:75)
at org.apache.karaf.main.Main.launch(Main.java:244)
at org.apache.karaf.main.Main.main(Main.java:179)
Caused by: java.io.FileNotFoundException: /var/log/openhab2/openhab.log (Permission denied)
at java.io.FileOutputStream.open0(Native Method)
at java.io.FileOutputStream.open(FileOutputStream.java:270)
at java.io.FileOutputStream.<init>(FileOutputStream.java:213)
at org.apache.karaf.main.util.BootstrapLogManager$SimpleFileHandler.open(BootstrapLogManager.java:193)
at org.apache.karaf.main.util.BootstrapLogManager$SimpleFileHandler.<init>(BootstrapLogManager.java:182)
at org.apache.karaf.main.util.BootstrapLogManager.getDefaultHandlerInternal(BootstrapLogManager.java:100)
... 5 more
!SESSION 2018-09-22 23:35:22.990 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_181
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
!ENTRY org.eclipse.osgi 4 0 2018-09-22 23:35:22.990
!MESSAGE Error reading configuration: /var/lib/openhab2/cache/org.eclipse.osgi/.manager/.fileTableLock (Permission denied)
!STACK 0
java.io.FileNotFoundException: /var/lib/openhab2/cache/org.eclipse.osgi/.manager/.fileTableLock (Permission denied)
at java.io.RandomAccessFile.open0(Native Method)
at java.io.RandomAccessFile.open(RandomAccessFile.java:316)
at java.io.RandomAccessFile.<init>(RandomAccessFile.java:243)
at org.eclipse.osgi.internal.location.Locker_JavaNio.lock(Locker_JavaNio.java:36)
at org.eclipse.osgi.storagemanager.StorageManager.lock(StorageManager.java:388)
at org.eclipse.osgi.storagemanager.StorageManager.open(StorageManager.java:701)
at org.eclipse.osgi.storage.Storage.getChildStorageManager(Storage.java:1776)
at org.eclipse.osgi.storage.Storage.getInfoInputStream(Storage.java:1793)
at org.eclipse.osgi.storage.Storage.<init>(Storage.java:132)
at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:85)
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:68)
at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:31)
at org.eclipse.osgi.launch.EquinoxFactory.newFramework(EquinoxFactory.java:24)
at org.apache.karaf.main.Main.launch(Main.java:256)
Looked in the openhab.log file and see this:
2018-09-22 22:34:09.852 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
java.lang.RuntimeException: Error initializing storage.
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:70)
Caused by: java.io.FileNotFoundException: /var/lib/openhab2/cache/org.eclipse.osgi/.manager/.fileTableLock (Permission denied)
... 4 more
At this point, I made sure that all the openhab config folders, etc. didn’t have any permission issues (chmod 777) and were owned by the default user (chown).
Then, when I ran ‘bash start_debug.sh’, I got:
mkdir: cannot create directory ‘/usr/share/openhab2/userdata/tmp’: No such file or directory
KARAF_BASE is not valid: /usr/share/openhab2/userdata
Error changed and got smaller, so I’ll take that as progress…
There is no userdata folder. Looking at my OH2.0 system, it doesn’t have one either. As something to try, I create the userdata folder and make sure it has write access, etc. like I did everywhere else.
Still essentially the same thing from the service status:
Active: activating (auto-restart) (Result: exit-code) since Sat 2018-09-22 23:51:05 CDT; 3s ago
Process: 3754 ExecStart=/usr/share/openhab2/runtime/bin/karaf $OPENHAB_STARTMODE (code=exited, status=255)
Main PID: 3754 (code=exited, status=255)
Sep 22 23:51:05 Server-Linux18 systemd[1]: openhab2.service: Main process exited, code=exited, status=255/n/a
Sep 22 23:51:05 Server-Linux18 systemd[1]: openhab2.service: Failed with result 'exit-code'.
But my messag when running ‘bash start_debug.sh’, changed:
KARAF_ETC is not valid: /usr/share/openhab2/userdata/etc
There is no etc file or directory within userdata. I verified the permissions on userdata to 777 and chowned it again to the default user with no change. Googling this, I haven’t found anyone that has had a KARAF_ETC issue. I guess I’m special… What mistifies me is that I don’t have this folder on my other system and it runs fine. Guessing it’s a change that’s been made between 2.0 and 2.3?
Here’s what I see in my openhab.log:
2018-09-22 23:51:11.753 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
... 4 more
This really doesn’t help me at all, but maybe it will mean more to someone else…
I’ve searched and tried everything I can think of with no effect. Ideas?
Thanks,
Danny
