Hi All, during my install of Java I used the latest version, 10.
I assume this is whats causing my issues in starting OH2.3 after the apt-get install method? SHould I roll back to Java 8?
kris@openhab2:~$ java -version
openjdk version "10.0.2" 2018-07-17
OpenJDK Runtime Environment Zulu10.3+5 (build 10.0.2+13)
OpenJDK 64-Bit Server VM Zulu10.3+5 (build 10.0.2+13, mixed mode)
kris@openhab2:~$
2018-08-27 23:19:29.480 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
java.lang.RuntimeException: Error occurred while checking the system module.
at org.eclipse.osgi.storage.Storage.checkSystemBundle(Storage.java:311)
at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:87)
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxCo ntainer.java:68)
at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:31)
at org.eclipse.osgi.launch.EquinoxFactory.newFramework(EquinoxFactory.ja va:24)
at org.apache.karaf.main.Main.launch(Main.java:256)
at org.apache.karaf.main.Main.main(Main.java:179)
Caused by: org.osgi.framework.BundleException: Invalid manifest header Export-Pa ckage: "org.osgi.dto;version="1.0",org.osgi.resource;version="1.0",org.osgi.reso urce.dto;version="1.0";uses:="org.osgi.dto",org.osgi.framework;version="1.8",org .osgi.framework.dto;version="1.8";uses:="org.osgi.dto",org.osgi.framework.hooks. bundle;version="1.1";uses:="org.osgi.framework",org.osgi.framework.hooks.resolve r;version="1.0";uses:="org.osgi.framework.wiring",org.osgi.framework.hooks.servi ce;version="1.1";uses:="org.osgi.framework",org.osgi.framework.hooks.weaving;ver sion="1.1";uses:="org.osgi.framework.wiring",org.osgi.framework.launch;version=" 1.2";uses:="org.osgi.framework",org.osgi.framework.namespace;version="1.1";uses: ="org.osgi.resource",org.osgi.framework.startlevel;version="1.0";uses:="org.osgi .framework",org.osgi.framework.startlevel.dto;version="1.0";uses:="org.osgi.dto" ,org.osgi.framework.wiring;version="1.2";uses:="org.osgi.framework,org.osgi.reso urce",org.osgi.framework.wiring.dto;version="1.2";uses:="org.osgi.dto,org.osgi.r esource.dto",org.osgi.service.condpermadmin;version="1.1.1";uses:="org.osgi.fram ework,org.osgi.service.permissionadmin",org.osgi.service.packageadmin;version="1 .2";uses:="org.osgi.framework",org.osgi.service.permissionadmin;version="1.2",or g.osgi.service.resolver;version="1.0";uses:="org.osgi.resource",org.osgi.service .startlevel;version="1.1";uses:="org.osgi.framework",org.osgi.service.url;versio n="1.0",org.osgi.util.tracker;version="1.5.1";uses:="org.osgi.framework",org.apa che.karaf.version;version="4.1.5",org.apache.karaf.jaas.boot.principal;uses:=jav ax.security.auth;version="4.1.5",org.apache.karaf.jaas.boot;uses:="javax.securit y.auth,javax.security.auth.callback,javax.security.auth.login,javax.security.aut h.spi,org.osgi.framework";version="4.1.5",, org.apache.karaf.branding, sun.misc, org.apache.karaf.jaas.boot.principal;uses:=javax.security.auth;version=4.1.5, o rg.apache.karaf.jaas.boot;uses:="javax.security.auth,javax.security.auth.callbac k,javax.security.auth.login,javax.security.auth.spi,org.osgi.framework";version= 4.1.5, org.apache.karaf.diagnostic.core;uses:=org.osgi.framework;version=4.1.5, org.apache.karaf.diagnostic.core.common;uses:=org.apache.karaf.diagnostic.core;v ersion=4.1.5"
at org.eclipse.osgi.util.ManifestElement.parseHeader(ManifestElement.jav a:353)
at org.eclipse.osgi.container.builders.OSGiManifestBuilderFactory.create Builder(OSGiManifestBuilderFactory.java:85)
at org.eclipse.osgi.storage.Storage.getBuilder(Storage.java:632)
at org.eclipse.osgi.storage.Storage.checkSystemBundle(Storage.java:263)
... 6 more
kris@openhab2:~$
