My OH restarted, and comes up with the following log.
Can someone cast an eye over it and comment on what they see needs addressing, please?
I left the full start-up log intact, to provide context. The questions are, does this look like a reasonable sequence? Are things ‘responding’ as expected? Does something stick out?
I have further questions at the end. But have an unbiased look first. (It is best read when copied to notepad with full length lines.)
2019-07-11 20:00:00.041 [INFO ] [xtr064.internal.FritzboxTr064Binding] - Fritzbox Reconnect Job executed
2019-07-11 20:00:00.046 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Lost connection to Fritzbox because of interrupt
2019-07-11 20:00:05.050 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Connected to FritzBox on 192.168.1.1:1012
2019-07-11 20:17:28.780 [WARN ] [g.dispatch.internal.ConfigDispatcher] - The file /etc/openhab2/services/mqtt.cfg subsequently defines the exclusive PID 'org.openhab.mqtt'. Overriding existing configuration now.
2019-07-11 22:08:28.475 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sysinfo.items'
2019-07-11 22:08:28.783 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'openings.items'
2019-07-11 22:08:29.012 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'weather.items'
2019-07-11 22:08:29.225 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sppro_bms.items'
2019-07-11 22:08:29.390 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'irrigation1.items'
2019-07-11 22:08:29.545 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'geoLocation.items'
2019-07-11 22:08:29.628 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'fritzbox.items'
2019-07-11 22:08:29.746 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'house_sensors.items'
2019-07-11 22:08:29.823 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'shed.items'
2019-07-11 22:08:29.920 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'maingate.items'
2019-07-11 22:08:29.986 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'groups.items'
2019-07-11 22:08:30.166 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'watersystem.items'
2019-07-11 22:08:30.224 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.items'
2019-07-11 22:08:30.271 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lights.items'
2019-07-11 22:08:30.371 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'powerpoints.items'
2019-07-11 22:08:30.409 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'main.items'
2019-07-11 22:08:31.209 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2019-07-11 22:08:31.277 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2019-07-11 22:08:40.162 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'max01.rules'
2019-07-11 22:08:41.737 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'other.rules'
2019-07-11 22:08:42.681 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'maingate.rules'
2019-07-11 22:08:45.235 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'weather.rules'
2019-07-11 22:08:48.952 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'watersystem.rules'
2019-07-11 22:08:50.222 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'shed.rules'
2019-07-11 22:08:50.909 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'init.rules'
2019-07-11 22:08:54.957 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'geoLocation.rules'
2019-07-11 22:09:05.751 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sppro_bms.rules'
2019-07-11 22:09:14.906 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'irrigation1.rules'
2019-07-11 22:09:15.896 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'fritzbox.rules'
2019-07-11 22:09:16.814 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-07-11 22:09:17.566 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'demo.sitemap'
2019-07-11 22:09:17.815 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'max01.sitemap'
2019-07-11 22:09:17.963 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'irrigation.sitemap'
2019-07-11 22:09:18.449 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'main.things'
2019-07-11 22:09:20.810 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2019-07-11 22:09:20.864 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:home every 60 seconds
2019-07-11 22:09:20.952 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:minus90
2019-07-11 22:09:21.375 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:home
2019-07-11 22:09:22.292 [WARN ] [e.jetty.util.thread.ThreadPoolBudget] - Low configured threads: (max=8 - required=1)=7 < warnAt=8 for QueuedThreadPool[ServletModel-12]@b0aac5{STARTING,8<=0<=8,i=0,q=0}[ReservedThreadExecutor@12fc6bb{s=0/1,p=0}]
2019-07-11 22:09:22.900 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.5:8080
2019-07-11 22:09:22.904 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.5:8443
2019-07-11 22:09:24.205 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'ntp:ntp:local' to inbox.
2019-07-11 22:09:31.087 [INFO ] [smarthome.model.script.watersystem.0] - loading rule and initialise state(s)
2019-07-11 22:09:43.520 [INFO ] [smarthome.model.script.Irrigation1.0] - System Start: Irrigation 1 rules
2019-07-11 22:09:43.725 [INFO ] [.eclipse.smarthome.model.script.init] - initialise states...
2019-07-11 22:09:43.739 [INFO ] [.eclipse.smarthome.model.script.init] - initialise states...
2019-07-11 22:09:43.790 [INFO ] [smarthome.model.script.Irrigation1.0] - System Start: Irrigation 1 rules
2019-07-11 22:09:43.933 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id 'rrd4j'
2019-07-11 22:09:43.938 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule 'Update Tank Irrigation Level max / min values': cannot invoke method public abstract org.eclipse.smarthome.core.types.State org.eclipse.smarthome.core.persistence.HistoricItem.getState() on null
2019-07-11 22:09:45.932 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-07-11 22:09:48.374 [INFO ] [b.core.service.AbstractActiveService] - FritzboxTr064 Refresh Service has been started
2019-07-11 22:09:48.386 [INFO ] [tzboxtr064.internal.PhonebookManager] - Downloading phonebook ID 0
2019-07-11 22:09:48.403 [INFO ] [b.core.service.AbstractActiveService] - Expire Refresh Service has been started
2019-07-11 22:09:48.482 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2019-07-11 22:09:48.491 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mymosquitto'
2019-07-11 22:10:00.697 [INFO ] [smarthome.model.script.watersystem.0] - loading rule and initialise state(s)
2019-07-11 22:10:00.881 [INFO ] [.eclipse.smarthome.model.script.init] - initialise states...
2019-07-11 22:10:00.886 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id 'rrd4j'
2019-07-11 22:10:15.143 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule 'Update Tank Irrigation Level max / min values': cannot invoke method public abstract org.eclipse.smarthome.core.types.State org.eclipse.smarthome.core.persistence.HistoricItem.getState() on null
2019-07-11 22:10:15.142 [INFO ] [smarthome.model.script.Irrigation1.0] - System Start: Irrigation 1 rules
2019-07-11 22:10:22.032 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Connected to FritzBox on 192.168.1.1:1012
2019-07-11 22:10:37.177 [INFO ] [smarthome.model.script.Irrigation1.0] - System Start: Irrigation 1 rules
2019-07-11 22:10:42.307 [INFO ] [smarthome.model.script.watersystem.0] - loading rule and initialise state(s)
2019-07-11 22:10:42.454 [INFO ] [.eclipse.smarthome.model.script.init] - initialise states...
2019-07-11 22:10:42.459 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id 'rrd4j'
2019-07-11 22:10:42.464 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule 'Update Tank Irrigation Level max / min values': cannot invoke method public abstract org.eclipse.smarthome.core.types.State org.eclipse.smarthome.core.persistence.HistoricItem.getState() on null
2019-07-11 22:10:43.335 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Monitor traffic': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.lib.NumberExtensions.operator_minus(java.lang.Number,java.lang.Number) on instance: null
2019-07-11 22:11:09.522 [INFO ] [.eclipse.smarthome.model.script.init] - initialise states...
2019-07-11 22:11:09.523 [INFO ] [smarthome.model.script.watersystem.0] - loading rule and initialise state(s)
2019-07-11 22:11:09.527 [INFO ] [smarthome.model.script.Irrigation1.0] - System Start: Irrigation 1 rules
2019-07-11 22:11:09.529 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id 'rrd4j'
2019-07-11 22:11:09.532 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule 'Update Tank Irrigation Level max / min values': cannot invoke method public abstract org.eclipse.smarthome.core.types.State org.eclipse.smarthome.core.persistence.HistoricItem.getState() on null
2019-07-11 22:11:09.563 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Notify of log reader messages': The name 'emailToMax' cannot be resolved to an item or type; line 69, column 11, length 10
2019-07-11 22:11:23.209 [INFO ] [smarthome.model.script.watersystem.0] - loading rule and initialise state(s)
2019-07-11 22:11:36.705 [INFO ] [smarthome.model.script.Irrigation1.0] - System Start: Irrigation 1 rules
2019-07-11 22:11:36.705 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id 'rrd4j'
2019-07-11 22:11:36.708 [INFO ] [.eclipse.smarthome.model.script.init] - initialise states...
2019-07-11 22:11:36.711 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule 'Update Tank Irrigation Level max / min values': cannot invoke method
2019-07-11 22:11:37.660 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Monitor traffic': An error occurred during the script execution: Could not invoke method: org.eclipse.smart
2019-07-11 22:11:42.924 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Geo Location Max': Could not cast NULL to java.lang.Number; line 99, column 42, length 33
2019-07-11 22:11:44.936 [ERROR] [pse.smarthome.core.items.GenericItem] - Tried to set invalid state null##null (StringType) on item fbox_IncomingCallResolved of type CallItem, ignoring i
2019-07-11 22:11:45.127 [ERROR] [pse.smarthome.core.items.GenericItem] - Tried to set invalid state null##null (StringType) on item fbox_IncomingCall of type CallItem, ignoring it
2019-07-11 22:11:45.361 [ERROR] [pse.smarthome.core.items.GenericItem] - Tried to set invalid state null##null (StringType) on item fboxOutgoingCall of type CallItem, ignoring it
2019-07-11 22:11:45.431 [ERROR] [pse.smarthome.core.items.GenericItem] - Tried to set invalid state null##null (StringType) on item fboxIncomingCallResolved of type CallItem, ignoring it
2019-07-11 22:11:45.678 [ERROR] [pse.smarthome.core.items.GenericItem] - Tried to set invalid state null##null (StringType) on item fbox_OutgoingCall of type CallItem, ignoring it
2019-07-11 22:11:45.711 [ERROR] [pse.smarthome.core.items.GenericItem] - Tried to set invalid state null##null (StringType) on item fboxIncomingCall of type CallItem, ignoring it
2019-07-11 22:12:03.219 [INFO ] [marthome.model.script.Irrigation1.30] - Irrigation1: stopping = cancelling timer(s)
2019-07-11 22:12:03.230 [INFO ] [marthome.model.script.Irrigation1.31] - Irrigation1: turning OFF all valves regardless of state
2019-07-11 22:12:03.290 [INFO ] [.model.script.GridSupportManualOff.1] - GridSupportManual set to OFF
2019-07-11 22:12:03.787 [INFO ] [eather.internal.common.WeatherConfig] - ProviderConfig[providerName=FORECASTIO,apiKey=1c1bbf3b13bac5b092bd7a763fa62ce3]
2019-07-11 22:12:03.805 [INFO ] [eather.internal.common.WeatherConfig] - LocationConfig[providerName=FORECASTIO,language=en,updateInterval=10,latitude=-27.3164855,longitude=152.3701568,w
2019-07-11 22:12:03.807 [INFO ] [eather.internal.common.WeatherConfig] - LocationConfig[providerName=YAHOO,language=en,updateInterval=10,latitude=<null>,longitude=<null>,woeid=1102162,lo
2019-07-11 22:12:05.535 [INFO ] [marthome.model.script.Irrigation1.00] - Irrigation1 -> enabled.
2019-07-11 22:12:05.539 [INFO ] [marthome.model.script.Irrigation1.30] - Irrigation1: stopping = cancelling timer(s)
2019-07-11 22:12:05.543 [INFO ] [marthome.model.script.Irrigation1.31] - Irrigation1: turning OFF all valves regardless of state
2019-07-11 22:12:05.560 [INFO ] [.smarthome.model.script.TankFilledUp] - Tank_Irrigation_Demand............: OFF
2019-07-11 22:12:05.568 [INFO ] [rthome.model.script.HWS_BoostTimer.3] - test Shed_RC41_HotWaterSystem = Early Morning Boost OFF
2019-07-11 22:12:06.725 [INFO ] [se.smarthome.model.script.BorePump.3] - Bore Pump: stopped
2019-07-11 22:12:06.787 [INFO ] [thome.model.script.ProfitLossTotal.1] - ProfitLossTotal yesterday.0.: 52.64
2019-07-11 22:12:06.830 [INFO ] [ternal.scheduler.WeatherJobScheduler] - Starting and scheduling weatherJob-argyle with interval of 10 minutes
2019-07-11 22:12:06.831 [INFO ] [thome.model.script.ProfitLossTotal.1] - ProfitLossTotal yesterday.1.: 52.64
2019-07-11 22:12:06.836 [INFO ] [thome.model.script.ProfitLossTotal.2] - ProfitLoss updated (night)..: 1.39
2019-07-11 22:12:06.839 [INFO ] [thome.model.script.ProfitLossTotal.3] - ProfitLoss corrections......: 0.000
2019-07-11 22:12:06.842 [INFO ] [ternal.scheduler.WeatherJobScheduler] - Disabling weather locationId 'home', no binding available
2019-07-11 22:12:06.847 [INFO ] [thome.model.script.ProfitLossTotal.4] - ProfitLossTotal new today...: 54.030
2019-07-11 22:12:06.912 [INFO ] [thome.model.script.ProfitLossTotal.5] - Import......................: -1.87
2019-07-11 22:12:06.916 [INFO ] [thome.model.script.ProfitLossTotal.6] - ImportTotalYear.1...........: -358.481
2019-07-11 22:12:06.927 [INFO ] [thome.model.script.ProfitLossTotal.7] - ImportTotalYear w Correction: -358.4810
2019-07-11 22:12:06.953 [INFO ] [thome.model.script.ProfitLossTotal.8] - ImportTotalYear.2...........: -360.3510
2019-07-11 22:12:42.836 [INFO ] [e.smarthome.model.script.fBbox.Mon.0] - byteIn................ 1071210116
2019-07-12 00:00:00.008 [INFO ] [xtr064.internal.FritzboxTr064Binding] - Fritzbox Reconnect Job executed
2019-07-12 00:00:00.015 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Lost connection to Fritzbox because of interrupt
What catches my attention is:
What does this mean?
Do I need to worry about this, and what can I do to fix it?
Seems to be related to "Low configured threads" warning
Weird, it is working once the system is up.
… yest this rule file has this at the beginning:
val String emailToMax = "myEmail@gmail.com"
… and the rule looks like htis:
// ----- 190210-1010 Notify of log reader messages
rule "Notify of log reader messages"
Channel "logreader:reader:openhablog:newErrorEvent" triggered
if (blnEmailLock_errMsg == false) {
errMsgCount = errMsgCount + 1
if (errMsgCount < 5) {
sendMail(
emailToMax,
"rPi3OHv2: encountered errors in openHAB.log",
"rPi3OHv2: " + logreaderLastError.state
} else {
sendMail(
emailToMax,
"rPi3OHv2: encountered " + errMsgCount + " errors in openHAB.log",
"rPi3OHv2: " + logreaderLastError.state + ". Further error messages have been suppressed for 6 hours."
blnEmailLock_errMsg = true
… and sending of mail eventually works; meaning I get these messages after start-up; maybe something hasn’t loaded yet.
the related rule is:
// ----- 170306 MaxG: update min max for irrigation tank level -----
rule "Update Tank Irrigation Level max / min values"
Item Tank_Irrigation_Level changed or
Time cron "1 0 0 * * ?" or
System started
val startOfDay = now.withTimeAtStartOfDay // toDateMidnight
if (Tank_Irrigation_Level !== null) {
Tank_Irrigation_Level_Max.postUpdate((Tank_Irrigation_Level.maximumSince(startOfDay).state as DecimalType).intValue)
Tank_Irrigation_Level_Min.postUpdate((Tank_Irrigation_Level.minimumSince(startOfDay).state as DecimalType).intValue)
… and works under normal operation.
realted rule:
// ----- 190126 MaxG: monitor traffic
rule "Monitor traffic"
Item fbox_WanTotalBytesReceived received update
val byteIn = fbox_WanTotalBytesReceived.state as DecimalType
val byteInMB = byteIn / (1024 * 1024)
val byteOutMB = fbox_WanTotalBytesSent.state as DecimalType / (1024 * 1024)
val byteTotMB = byteInMB + byteOutMB
val byteInPrev = fbox_WanTotalBytesReceivedPrev.state
var byteInDelta = (byteIn - byteInPrev) / 1024
if (byteInDelta < 0) {
logInfo("fBbox.Mon.0", "byteIn................ {}", byteIn)
byteInDelta = 0
fbox_WanTotal_MB_Sent.postUpdate(byteOutMB)
fbox_WanTotal_MB_Rec.postUpdate(byteInMB)
fbox_WanTotal_MB_Total.postUpdate(byteTotMB)
fbox_WanTotalBytesReceivedPrev.postUpdate(byteIn)
fbox_WanTotal_RecDelta.postUpdate(byteInDelta)
Works under normal operation.
related rule fragment:
// 181014: see if we reached the gateTriggerRadius for opening the gate
if (MaxG_DistanceFromHome.state <= GateTriggerRadius.state as Number) {
indicating this item: GateTriggerRadius.state
… and following lines; Would I have to initialise these values somehow? I thought it would grab these from the Fritzbox?!
2019-07-11 22:12:03.807 [INFO ] [eather.internal.common.WeatherConfig] - LocationConfig[providerName=YAHOO,language=en,updateInterval=10,latitude=<null>,longitude=<null>,woeid=1102155,lo
Seems a left over somewhere in the config I will fix. Have no Yahoo, ended service earlier this year anyway.
I reckon the ‘rrd4j’ errors show, because persistence hasn’t loaded yet?! IS there a way to fix it.
Any feedback (also on rules shown) including improvements or flaws much appreciated.
In any case, you’re a champ if you made it to the end of this post. Thank you.
