I created a group gWeather
have a bunch of items associated to this group.
I added this group gWeather to gPersist_rrd4j in the hope that all weather items are being persisted.
But when I restart OH, these items are NULL, and because I check for them and if NULL set them to 0, I lose my previously persisted setting(s).
I am now wondering, whether the values where persisted in the first place, or whether I reset them, because persistence was not restored before I check and reset them.
I reckon it is the former, which causes endless trouble.
Is there a way to stop rule execution until items are loaded and values are restored?
// ----- 190810 MaxG: created
// ----- AccuRite 5in1 outdoor weather station
Group gAccuRite (gAll, gPersist_rrd4j)
// AccuRite Weather Charts
Group gAccuRiteTemp_Chart
Number gAccuRiteTemp_Chart_Period
Group gAccuRiteHumi_Chart
Number gAccuRiteHumi_Chart_Period
Group gAccuRiteWind_Chart
Number gAccuRiteWind_Chart_Period
Group gAccuRiteRain_Chart
Number gAccuRiteRain_Chart_Period
// data received
String ar_DataReceived "AccuRite data" {mqtt="<[mymosquitto:ArgyleCourt/Property/AcuRite5in1:state:default]"}
DateTime ar_LastUpdated "AccuRite: Last update [%1$td/%1$tm %1$tH:%1$tM]" <calendar> (gAccuRite, gLUP)
// data being extracted
Number ar_Temperature "Outdoor temperature [%.1f °C]" <temperature> (gAccuRite, gAccuRiteTemp_Chart, gSensors_Temperature)
Number ar_Humidity "Outdoor Humidity [%.0f %%]" <temperature> (gAccuRite, gAccuRiteHumi_Chart)
Number ar_WindSpeed "Wind speed at present [%.0f km/h]" <wind> (gAccuRite, gAccuRiteWind_Chart)
Number ar_WindDir "Wind direction [%.0f°]" <wind> (gAccuRite)
String ar_WindDirText "Wind direction [SCALE(wind_direction.scale):%s]" <wind> (gAccuRite)
String ar_Battery "AccuRite Battery [%s]" <battery4> (gAccuRite)
Number ar_RainTotal "Rain Total [%.0f mm]" <clouds_rain> (gAccuRite)
// data being derived / calculated
Number ar_TemperatureMin "Outdoor temperature minimum [%.1f °C]" <temperature> (gAccuRite, gAccuRiteTemp_Chart)
Number ar_TemperatureMax "Outdoor temperature maximum [%.1f °C]" <temperature> (gAccuRite, gAccuRiteTemp_Chart)
Number ar_HumidityMin "Outdoor humidity minimum [%.0f %%]" <temperature> (gAccuRite, gAccuRiteHumi_Chart)
Number ar_HumidityMax "Outdoor humidity maximum [%.0f %%]" <temperature> (gAccuRite, gAccuRiteHumi_Chart)
Number ar_Humidex "Outdoor Humidex [SCALE(humidex.scale):%s]" (gAccuRite)
Number ar_WindSpeedMin "Wind speed minimum [%.0f km/h]" <wind> (gAccuRite, gAccuRiteWind_Chart)
Number ar_WindSpeedMax "Wind speed maximum [%.0f km/h]" <wind> (gAccuRite, gAccuRiteWind_Chart)
Number ar_RainToday "Rainfall today [%.2f mm]" <clouds_rain> (gAccuRite, gAccuRiteRain_Chart)
Number ar_RainLast24H "Rainfall last 24 hours [%.2f mm]" <clouds_rain> (gAccuRite)
Number ar_RainYesterday "Rainfall yesterday [%.2f mm]" <clouds_rain> (gAccuRite)
Number ar_RainWeek "Rainfall last 7 days [%.2f mm]" <clouds_rain> (gAccuRite)
Number ar_RainMonth "Rainfall last 30 days [%.0f mm]" <clouds_rain> (gAccuRite)
Number ar_RainQuarter "Rainfall last 90 days [%.0f mm]" <clouds_rain> (gAccuRite)
Number ar_RainYear "Rainfall last 365 days [%.0f mm]" <clouds_rain> (gAccuRite)
The interesting bit:
Since all items are a member of gAccuRite these should be persisted?!
Otherwise I would have to add gPersist_rrd4j to all items?
Is there no better way?
Unfortunately not. The only way to persist the state of a Group is to list it in the .persist file directly.
Yes, you have to add it to all Items. The .persist file config is not recursive. Only direct members of gPersist_rrd4j that are not Group Items themselves will be persisted.
