My problem is simple: After migrating to OH3, my “multi-state push buttons” in basicUI sitemaps aren’t pushing any more ;-). Once one of the buttons get pressed, it keeps its state. In OH2 they got released immediately.
I experienced the same for all my switches that I use as momentary buttons. My solution in OH3 was to use the built-in expire function. I set the expire time for 1 second and the action to be commanding off. So when you turn on the switch, it will change back to off after 1 second.
@Pedals2Paddles, that’s a good solution - and you can even use 0s as timer, then it will be released immediately. I use an empty command which leads to “UNDEF” state (which also “releases” the pressed buttons) Thank you!
