NCO
(E. Gerland)
January 1, 2021, 10:55am
1
Hardware: RPi 4 8 GB and 32 GB micro SD + zwave: Aeotec Z-Stick Gen5 (ZW090) - UZB
OS: Raspian which comes with openhabian
openHAB version: oh3 stable
Hi everyone,
I am migrating to OH an encountered a http authentication issue:
This used to work with basic authentication in http.cfg under OH 2.5-xx
My new Thing / channel:
UID: http:url:Abus
label: HTTP - Abus Secvest
thingTypeUID: http:url
configuration:
authMode: BASIC
ignoreSSLErrors: false
baseURL: http://192.168.68.36:8060/
password: secretPWD
refresh: 10
commandMethod: POST
contentType: text/plain
timeout: 3
username: myself
bufferSize: 2048
channels:
- id: AbusMode
channelTypeUID: http:string
label: Abus Mode
description: ""
configuration:
mode: READONLY
stateExtension: getMode.cgi
stateTransformation: REGEX:Mode=(.*)
but, in the log I get:
2021-01-01 11:54:26.184 [WARN ] [p.internal.http.HttpResponseListener] - Requesting 'http://192.168.68.36:8060/getMode.cgi' (method='GET', content='null') failed: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
2021-01-01 11:54:36.086 [TRACE] [ttp.internal.http.RefreshingUrlCache] - Requesting refresh (retry=false) from 'http://192.168.68.36:8060/getMode.cgi' with timeout 3000ms
2021-01-01 11:54:36.091 [TRACE] [ttp.internal.http.RefreshingUrlCache] - Sending to 'http://192.168.68.36:8060/getMode.cgi': Method = {GET}, Headers = {Accept-Encoding: gzip, User-Agent: Jetty/9.4.20.v20190813}, Content = {null}
2021-01-01 11:54:36.187 [TRACE] [p.internal.http.HttpResponseListener] - Received from 'http://192.168.68.36:8060/getMode.cgi': Code = {401}, Headers = {Status: 401 Unauthorized, Content-Type: text/plain}, Content = {401 Authorization Required
Any suggestion would be greatly appreciated.
J-N-K
(Jan N. Klug)
January 1, 2021, 11:11am
2
You could try pre-emptive authentication (implement in 3.1-SNAPSHOT). The root cause is that the server is doing something wrong (see the WARN).
NCO
(E. Gerland)
January 1, 2021, 11:13am
3
Awesome - thanks, Jan.
You mean the 3.1 snapshot of the http binding only, right?
Is it the same procedure like with OH2.5 like dropping the jar into …/addons?
J-N-K
(Jan N. Klug)
January 1, 2021, 11:18am
4
Should work. Don’t forget to uninstall the other binding before.
Or you could use the console and
update org.openhab.binding.http https://ci.openhab.org/job/openHAB-Addons/lastSuccessfulBuild/artifact/bundles/org.openhab.binding.http/target/org.openhab.binding.http-3.1.0-SNAPSHOT.jar
NCO
(E. Gerland)
January 1, 2021, 12:18pm
6
Works like a charm, Jan.
Thank you very much.
NCO
(E. Gerland)
June 8, 2021, 11:24am
7
I would like to revive this thread because I have another http / authentication related issue.
This openhab URL with a generated token works fine with curl:
curl http://oh.secretToken@localhost:8080/rest/services/org.openhab.openhabcloud/config
and returns the state of the openhab cloud (remote vs. notification only):
{"mode":"remote","baseURL":"https://myopenhab.org/"}
My thing config looks like this:
UID: http:url:myohcloud
label: HTTP - MyOHCloud Connection State
configuration:
authMode: BASIC_PREEMPTIVE
baseURL: http://oh.secretToken@localhost:8080/rest/services/org.openhab.openhabcloud/config
delay: 0
refresh: 30
commandMethod: GET
timeout: 3000
bufferSize: 2048
channels:
- id: ConType
label: Type of Connection
description: ""
configuration:
mode: READONLY
But I don’t get anything into the String, but these logs:
2021-06-08 13:17:26.503 [TRACE] [ttp.internal.http.RefreshingUrlCache] - Requesting refresh (retry=false) from 'http://oh.secretToken@localhost:8080/rest/services/org.openhab.openhabcloud/config' with timeout 3000ms
2021-06-08 13:17:26.505 [TRACE] [ttp.internal.http.RefreshingUrlCache] - Sending to 'http://oh.secretToken@localhost:8080/rest/services/org.openhab.openhabcloud/config': Method = {GET}, Headers = {Accept-Encoding: gzip, User-Agent: Jetty/9.4.20.v20190813}, Content = {null}
2021-06-08 13:17:26.516 [TRACE] [p.internal.http.HttpResponseListener] - Received from 'http://localhost:8080/rest/services/org.openhab.openhabcloud/config': Code = {401}, Headers = {Content-Type: application/json, Date: Tue, 08 Jun 2021 11:17:26 GMT, Transfer-Encoding: chunked, Server: Jetty(9.4.20.v20190813)}, Content = {{"error":{"message":"Authentication required","http-code":401}}}
2021-06-08 13:17:26.518 [WARN ] [p.internal.http.HttpResponseListener] - Requesting 'http://localhost:8080/rest/services/org.openhab.openhabcloud/config' (method='GET', content='null') failed: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
I have tested all authentication modes with no luck:
Basic Authentication
Preemptive Basic Authentication
Digest Authentication
So how to translate the token URL used in curl into the http binding?
NCO
(E. Gerland)
June 8, 2021, 8:11pm
8
Just in case someone stumbles about this as well:
I just heard that token authentication is not supported by the http binding.
So I went with the user / password approach as above.
