I tried to convert a simple rule to work in OH3. I use MySQL-Persitence to story my energy consumption. Every 5 Minutes I want to calculate the difference between Start of day and now.
I tried this:
val ZonedDateTime zdt = ZonedDateTime.now()
var ZonedDateTime start_of_day = zdt.toLocalDate().atStartOfDay(zdt.getZone())
var SV0 = ZaehlerstandHeizung.deltaSince(now.with(start_of_day))
postUpdate(HeizungVerbrauchTag, SV0)
But when running, openhab.log shows this:
2021-01-02 14:35:03.678 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID '30fd72abc6' failed: val ZonedDateTime zdt = ZonedDateTime.now()
1. Ambiguous feature call.
The methods
postUpdate(Item, State) in BusEvent and
postUpdate(Item, Number) in BusEvent
both match.; line 5, column 194, length 10
Found a working solution calculating it in another way:
var SV0 = ZaehlerstandHeizung.historicState(start_of_day).state as Number
var SV1 = ZaehlerstandHeizung.state as Number
var SV3 = (SV1 - SV0)
postUpdate(HeizungVerbrauchTag, SV3)
The issue is that ‘var SV0’ doesn’t provide a type and hence the code can’t predict which postUpdate method to use.
I haven’t tested, but this should work:
var SV0 = ZaehlerstandHeizung.deltaSince(now.with(start_of_day)) as Number
rule "Tagesverbrauch Allgemein mig"
Time cron "0 0/5 * * * ? *"
var SV0 = ZaehlerstandAllgemein.deltaSince(now.with(start_of_day)) as Number
postUpdate(AllgemeinVerbrauchTag, SV0)
It gives me this error:
2021-01-03 16:17:56.614 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'migrated-1' failed: An error occurred during the script execution: Could not invoke method: java.time.ZonedDateTime.with(java.time.temporal.TemporalAdjuster) on instance: 2021-01-03T16:17:56.613471+01:00[Europe/Berlin] in migrated
This is why I ended up in getting historic state and substract
Here the complete rule again in case someone wants to use it:
var SV0 = ZaehlerstandAllgemein.deltaSince(start_of_day) as Number
Hello, thanks for the rule, is exactly what I was looking for, but how does this rule work for weeks, months and annual consumption?
I did it like this, but it doesn’t work because the same value is always displayed.
rule "Power Consumption"
Time cron " 0/5 * * ? * * * "
var ZonedDateTime start_of_week = zdt.toLocalDate().atStartOfDay(zdt.getZone())
var ZonedDateTime start_of_month = zdt.toLocalDate().atStartOfDay(zdt.getZone())
var ZonedDateTime start_of_year = zdt.toLocalDate().atStartOfDay(zdt.getZone())
var power_Today = ElectricityMeter_kWh.deltaSince(start_of_day) as Number
var power_Week = ElectricityMeter_kWh.deltaSince(start_of_week) as Number
var power_Month = ElectricityMeter_kWh.deltaSince(start_of_month) as Number
var power_Year = ElectricityMeter_kWh.deltaSince(start_of_year) as Number
postUpdate(PowerConsumptionToday, power_Today)
postUpdate(PowerConsumptionWeek, power_Week)
postUpdate(PowerConsumptionMonth, power_Month)
postUpdate(PowerConsumptionYear, power_Year)
Those are identical, why should it point to any different date/time? You need to do something if you want to point at last week, .minusDays(7) might be a useful method on a zonedDateTime..
