a few days ago, after having updated OpenHAB to 2.1.0 via the Ubuntu feed in bintray, I have noticed that my ELRO Intertechno devices are not working anymore as expected (they have been before in OpenHAB 2.0).
I am using a 433 MHz CUL, and integration was done via the culintertechno binding, with the entry
device=serial:/dev/ttyACM1
in culintertechno.cfg. I am using openhab inside a LXC container by the way and had to “forward” the device from the host via
The symptoms are: When starting openhab, the ELRO devices work a few times at the beginning, but then do not react to events anymore after a couple of times, and they do not react again.
The default settings do not show any suspicious information in openhab2.log and the expected events (when triggering them) in events.log.
My questions would be:
how to continue debugging (what flags? what to do?)
any similar experiences, especially with usage inside lxc?
One more update: Following https://github.com/openhab/openhab1-addons/issues/3910, I have tried to connect to the CUL directly using “screen”, and I could successfully switch my devices on and off by manually typing in the “is”-codes.
So it seems that the connection via LXC is working and that the problem indeed seems to be related to the latest openhab update (since the old version 2.0 was working in the same environment).
Any advice? If not, where should I re-post this question?
You might the consider to change the topic since you do suspect LXC being at least part of the problem.
For information I’m using a CUL with the Intertechno binding to switch power plugs with no problem on OH 2.1
Well, I am not sure whether this is in fact related to LXC, since I have another CUL for Homematic devices (dev/ttyACM0), which runs fine (via the homematic/homegear openhab binding).
Any hints on how to debug/trace the communication to the CUL? What have done in the meantime is to set logging to TRACE in /var/lib/openhab2/etc/org.ops4j.pax.logging.cfg with
Indeed, there are a few log messages appearing in /var/log/openhab2/openhab.log (see below) - but interestingly switching on/off an openhab item which binds to the channel
Just for the files: I just fixed the problem on my machine, but without the add-on: I have removed the culintertechno channel from the switch and instead created a rule that sends the raw command to the device directly:
rule intertechno_switch
Item IT_Switch received command
if (IT_Switch.state == ON) {
executeCommandLine("/bin/sh@@-c@@echo is000000FFFFFF >/dev/ttyACM1")
} else {
executeCommandLine("/bin/sh@@-c@@echo is000000FFFFF0 >/dev/ttyACM1")
So I still suspect the culintertechno binding to be buggy, since accessing the CUL device seems to work without a problem from the openhab user in the LXC container (with this work-around).
Obviously, if possible, I would like to switch back to the culintertechno binding directly (even though it works on other systems), so any further debugging hints are still appreciated.
Well, I do not know whether it’s due to intermediate kernel updates or the recent 2.2 OpenHab update, but the intertechno add-on seems to work correctly again on my system, so this topic can be considered as closed.
