- Platform information:
- Hardware: ZOTAC x86
- OS: ubuntu 18.04
- Java Runtime Environment: 1.8.0_232
- openHAB version: 2.5.1
- Issue of the topic: Error initializing OSRAM Lightify gateway
I have an older openhab 2.3 installation with a working OSRAM/Sylvania Lightify/SMART+ Binding
I tried to replace it with new openhab2 server runnung openhab 2.5.1
The system is working with different bindings, but I’ve problem to get the Lightify binding running.
In Paper UI I found
OSRAM/Sylvania Lightify/SMART+ Binding market:binding-3560149 - 1.0
When trying to install I’ve got an error:
“Bundle cannot be installed: Error reading bundle content.”
On “https://openhab.jfrog.io/” I found the newest jar file “org.openhab.binding.osramlightify-2.5.0-SNAPSHOT.jar”
I manually added the jar to openhab folder “/usr/share/openhab2/addons”
In karaf console the bundle is listed:
START LEVEL 100 , List Threshold: 50
296 │ Active │ 80 │ 2.5.0.201901120100 │ OSRAM Lightify Binding
Scanning in Paper UI for new devices the OSRAM Gateway was found, but the state is
UNINITIALIZED - HANDLER_INITIALIZING_ERROR
and no connected devices are found
Error log:
2020-01-26 12:32:18.459 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘osramlightify:gateway:XXXXXXXX’ to inbox.
2020-01-26 12:32:27.285 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.initialize()’ on ‘org.openhab.binding.osramlightify.handler.LightifyBridgeHandler@79a20eaf’: bundleContext
java.lang.NoSuchFieldError: bundleContext
at org.openhab.binding.osramlightify.handler.LightifyBridgeHandler.registerDeviceDiscoveryService(LightifyBridgeHandler.java:176) ~[?:?]
at org.openhab.binding.osramlightify.handler.LightifyBridgeHandler.initialize(LightifyBridgeHandler.java:87) ~[?:?]
at sun.reflect.GeneratedMethodAccessor71.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_232]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_232]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_232]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
2020-01-26 12:32:27.290 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing ‘osramlightify:gateway:XXXXXXXX’: bundleContext
Any idea how to solve this?
