Hi, firstly, I’m new around here but I’ve installed OH2 about 5 times now, the most recent one is the beta3 online (on Ubuntu). I only have three devices - an Aeon USB ZStick Gen5, an Aeotec RGB Bulb, and a Philio PSR04 Switch. The ZStick and the RGB Bulb are identified fine, but I cannot get the PSR04 to be identified. There’s no nodeX.xml file created for it. According to @chris’s database, it’s supported here, but I’m now out of ideas. I’ve reinitialised the ZStick and re-paired the devices but the PSR04 always appears as “Unknown Device”. It doesn’t matter whether I use PaperUI or HABmin2 (0.1.6, 2016-05-27), it won’t show, and the only relevant thing I can see in the log is:
NODE 2: Device could not be resolved to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
How can I tell what version of the device database I have, and how do I update it (do I have to download the source from cloudbees and compile, or should the version in beta3 be enough)?
If the node isn’t generating an xml, please provide a debug log of the startup and I’ll take a look. If this is a battery device (I guess so) then please make sure that you wake the device up quite a few times so that we get a good log.
I found another manual which states the following -:
If the user want to wake-up the device immediately, please rotate to area A and pressing the touch button once. The device will wake-up for 10 seconds every single time.
Ledgend @chris, that did the trick! It’s showing properly now. I found that second manual you mentioned - the device operates differently depending on whether it’s mounted vertically or horizontally. I had it sitting on a table top, and when horizontal, turning the dial has no effect. You have to hold it vertically for the turns to register.
Thanks for the feedback. Do you mind writing a short explanation that I can write into the database? I added what I found in the manual already, but maybe you can improve it?
If so I think it would help others as this doesn’t seem to be well documented in the manual… Feel free to either update the database directly, or reply here and I’ll paste it in…
how I can read switch state and dimmer state from this button using openhab?
There is only two channels “battery level” and “scene”. But no channel like switch_state or so.
did anyone manage to get the device working properly?
It is well included in the ZWave network and Habmin recognize it correctly, but I am unable to switch a simple test button in my items file with it. Here my button:
Hi, just wondering if you’d got the device to work?
The zwave logs look good, e.g.:
DEBUG o.o.b.z.i.ZWaveActiveBinding[:466]- NODE 45: Got a value event from Z-Wave network, endpoint = 0, command class = CENTRAL_SCENE, value = {key=0, scene=1}
However I can’t work out what item definition to use.
Switch Newswitch "New switch" { zwave="45:command=CENTRAL_SCENE,scene=01" }
updates to “OFF” when I press the button, which is slightly odd behaviour, and I can’t seem to catch it in my rules…
This definition looks like it’s written for OH1 - not OH2. The format is different so please make sure that you have written the item for the OH2 format.
I’m using OH1 as well. I did not figured it out completely. The behavior of your item seems to be correct. Depending on the position of the wheel of you philio button, it simply works ass an off switch, not an ON/OFF switch. If you move the point on the wheel of the button to the on zone, the switch state should update to ON.
I found out how to get the dimmer value of the color button. Some days ago a new dimmer channel was added to the device xml, but the type was still OnOffType. I just changed the type to binding:*:PercentType and now I am able to receive values from 0 to 100.
