[SOLVED] OpenHab Alexa
I am trying to get an item setup fro Alexia to control but it is not showing up as an Item in OpenHab cloud page. Any suggestions on what I am doing wrong? I have Openhab2, Windows, and a Orvibo IR blaster. It works if I use it fro the control panel but not the OpenHab cloud items. I can get other things to show up just not the item I want to control.
any help is appreciated.
Here is my Items and Sitemap
items:
Switch Presence_Mobile_Eric “Eric Cell Phone” { channel=“network:device:10_0_0_2:online” }
Switch LRTVPower “LRTVPower” [“Switchable”]
Sitemap:
sitemap default label=“My first sitemap”
Switch item=Presence_Mobile_Eric label=“Eric’s Mobile”
Switch item=LRTVPower label=“Power”
Rules (in case you need it):
rule “anything it doesnot matter”
Item LRTVPower received command ON
val results = executeCommandLine(“c:/Python35/python.exe@@C:/openHAB2/conf/scripts/orvibo.py@@-i@@10.0.0.190@@-e@@C:/openHAB2/conf/scripts/test-lr-tv-on.ir”, 5000)
logInfo(“execTest”, results)
Item LRTVPower received command OFF
Read the first couple of posts in this thread and you should be fine:
That solved my problem.
This is what I ended up with
items:
Switch LRTV “Living Room TV” [ “Lighting” ]
Sitemap:
Switch item=LRTV label="Living Room TV"
Rules:
rule “Living_Room_TV_On”
Item LRTV received command ON
rule “Living_Room_TV_Off”
Item LRTV received command OFF
